Is it possible for spark plugs to take a dump at 28K?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueT, May 6, 2010.
  1. May 6, 2010 at 6:51 AM
    BlueT
    BlueT [OP] Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    So last few days my truck is running ruff. Especially when cold in the morning. When you throttle down it sounds like want to misfire.
    It does not skip the beat but its just heavy sound. The misfire part on the throttle down is what is curious. So is it possible that my spark plugs are that wear out at 28K ?
    Any ideas ???:confused:
  2. May 6, 2010 at 6:54 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    anything is possible
  3. May 6, 2010 at 6:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    Anything is possible. You could also have a bad wire. Did the CEL light up?
  4. May 6, 2010 at 6:58 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    What octane fuel are you using?..... My 4.0 V6 runs poorly on 87. I run 89 at all times of the year.
  5. May 6, 2010 at 7:03 AM
    BlueT
    NorthEast
    No, no CEL I will install my computer chip and make a full run on it to see if anything is unusual.
    Always 91/93 ...
  6. May 6, 2010 at 7:04 AM
    JimBeam
    JB
    2015 Tundra
    your computer chip?
  7. May 6, 2010 at 7:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2 on the chip
  8. May 6, 2010 at 7:08 AM
    BlueT
    NorthEast
    Its a OBDII thing that plugs in and collects info for you you can later hook up to laptop and get all graphs and info...
  9. May 6, 2010 at 7:09 AM
    Jeremiah Stewart
    Jeremiah Stewart New Member
    Jeremiah
    Colorado Springs, CO
    06 4X4 AC Impluse Red
    TRD Intake, Momo Pedals, Flowmaster Duel Exhaust
    Blue T,
    It is possible for the plugs to have already gone bad from the factory at only 28k. The 1GR in both the Taco and FJ are the only engines that Toyota didn't put platinum plugs in from the factory. They are simply an old school copper plug. The life of a copper plug is only about 25-30k. My recommendations is to run the Denso Iridium plugs in the truck. They are a little more expensive, but worth the investment. if needed, I can get you the part number
    Hope this helps out.
    Iridium Power IKH20
    Iridium Long Life SK20HR11
  10. May 6, 2010 at 7:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    Awesome. Sounds like a great tool. Name/product info?
  11. May 6, 2010 at 7:17 AM
    TacoOwner?
    TacoOwner? Well-Known Member
    Joshua
    Camas/Spokane, WA
    '10 4x4 Double Cab 6M
    Anti-thief tailgate, anytime rear-view camera, anytime locker mod
    I think this would take less than 30 minutes to find out. You should pop your hood and pull some plugs. This will also help narrow down the problem if it is not the plugs.
    Josh
  12. May 6, 2010 at 7:24 AM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    Could also be a bad O2 sensor. Had these types of symptoms when they went bad, especially with a cold engine, and rough low idle when at a stop sign, or light.
  13. May 6, 2010 at 7:26 AM
    JimBeam
    JB
    2015 Tundra
    typically your truck will throw a CEL with a bad O2 sensor tho
  14. May 6, 2010 at 7:32 AM
    BlueT
    NorthEast
    Thanks those are Denso Iridium right?, if indeed those copper plugs took a dump on me there is no reason to put the same ones back.
    Davis carchip http://www.carchip.com/
    its very nice tool
  15. May 6, 2010 at 7:34 AM
    BlueT
    NorthEast
    yeah I am near replacing interval anyway so they are getting replaced. I will be surprised if this is caused by spark plugs they should last more then that.
  16. May 6, 2010 at 7:35 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    When you are pulling the plugs look at the plug wires too, just in case, one could be frayed or worn.
  17. May 6, 2010 at 7:35 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Anybody know how many miles can we expect out of the Iridium Long life?
  18. May 6, 2010 at 9:56 AM
    BlueT
    NorthEast
    So it looks like I can only get Denso from dealer by Saturday.
    I am now keen to use i4 plugs since according to Denso they are interchangeable
    YEAR 2007 ENGINE TYPE V6 LITER 4.0 CC 3956 ENGINE DESIGNATION 1GRFE
    STANDARD PLUG NO K20HR-U11
    STANDARD PLUG STOCKNUMBER 338
    1 PLATINUM PLUG NO -
    PLATINUM PLUG STOCKNUMBER -
    IRIDIUM LONG-LIFE PLUG NO SK20HR11
    IRIDIUM LONG-LIFE PLUG STOCKNUMBER 3421
    IRIDIUM POWER PLUG NO IKH20
    IRIDIUM POWER PLUG STOCKNUMBER 5344
    GAP 0.044
    YEAR 2007 ENGINE TYPE L4 LITER 2.7 CC 2694 ENGINE DESIGNATION 2TRFE
    STANDARD PLUG STOCKNUMBER 3381 PLATINUM PLUG NO -
    GAP 0.044
  19. May 6, 2010 at 10:00 AM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Just curious here - I have an 09 v6, do I too have the cheapo coppers? If so, is there a noteable performance/mileage improvement running the platinum sparkplugs? I just rolled 10k and I would rather get ahead of this one if I could.
  20. May 6, 2010 at 10:08 AM
    BlueT
    NorthEast
    Something Interesting
    "Part number 9091902248 was superseded by part number 90919A2001."
    Apparently there was something wrong with our coils so Toyota made new one with new part number :confused:
