is it possible to drink too much water?
Discussion in 'Health' started by 97yota4wd, Apr 7, 2011.
  1. Apr 7, 2011 at 5:25 PM
    97yota4wd
    97yota4wd [OP] Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i just had kind of a basic question... is it possible to drink too much water? if so how much is too much? thanks
  2. Apr 7, 2011 at 5:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Apr 7, 2011 at 5:26 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
  4. Apr 7, 2011 at 5:27 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yep, some college kids died at a frat where they hazed using water instead of beer (obviously sounded like a good alternative at the time).
  5. Apr 7, 2011 at 5:27 PM
    97yota4wd
    Eric
    Mesa, AZ
    shoulda searched.... thanks guys!
  6. Apr 7, 2011 at 5:27 PM
    MrJKC
    MrJKC KCCO!!!
    Nor-Cal
    Indigo Ink Toyota, TRD Sport, PreRunner, SR5
    6000k Bi-Xenon, 6000k Fogs, 3inch lift, Tint, Horns, Grill, Weather Tech floor mats - front and back
    yes... you can drown yourself from the inside.
    i found this
    Can You Really Drink Too Much Water?
    In a word, yes. Drinking too much water can lead to a condition known as water intoxication and to a related problem resulting from the dilution of sodium in the body, hyponatremia. Water intoxication is most commonly seen in infants under six months of age and sometimes in athletes. A baby can get water intoxication as a result of drinking several bottles of water a day or from drinking infant formula that has been diluted too much. Athletes can also suffer from water intoxication. Athletes sweat heavily, losing both water and electrolytes. Water intoxication and hyponatremia result when a dehydrated person drinks too much water without the accompanying electrolytes.
    What Happens During Water Intoxication?
    When too much water enters the body's cells, the tissues swell with the excess fluid. Your cells maintain a specific concentration gradient, so excess water outside the cells (the serum) draws sodium from within the cells out into the serum in an attempt to re-establish the necessary concentration. As more water accumulates, the serum sodium concentration drops -- a condition known as hyponatremia. The other way cells try to regain the electrolyte balance is for water outside the cells to rush into the cells via osmosis. The movement of water across a semipermeable membrane from higher to lower concentration is called osmosis. Although electrolytes are more concentrated inside the cells than outside, the water outside the cells is 'more concentrated' or 'less dilute' since it contains fewer electrolytes. Both electrolytes and water move across the cell membrane in an effort to balance concentration. Theoretically, cells could swell to the point of bursting.
    From the cell's point of view, water intoxication produces the same effects as would result from drowning in fresh water. Electrolyte imbalance and tissue swelling can cause an irregular heartbeat, allow fluid to enter the lungs, and may cause fluttering eyelids. Swelling puts pressure on the brain and nerves, which can cause behaviors resembling alcohol intoxication. Swelling of brain tissues can cause seizures, coma and ultimately death unless water intake is restricted and a hypertonic saline (salt) solution is administered. If treatment is given before tissue swelling causes too much cellular damage, then a complete recovery can be expected within a few days.
    It's Not How Much You Drink, It's How Fast You Drink It!
    The kidneys of a healthy adult can process fifteen liters of water a day! You are unlikely to suffer from water intoxication, even if you drink a lot of water, as long as you drink over time as opposed to intaking an enormous volume at one time. As a general guideline, most adults need about three quarts of fluid each day. Much of that water comes from food, so 8-12 eight ounce glasses a day is a common recommended intake. You may need more water if the weather is very warm or very dry, if you are exercising, or if you are taking certain medications. The bottom line is this: it's possible to drink too much water, but unless you are running a marathon or an infant, water intoxication is a very uncommon condition.
  7. Apr 7, 2011 at 5:34 PM
    97yota4wd
    Eric
    Mesa, AZ
    okay so it will be totally fine if i drink a gallon a day? but no more right?
  8. Apr 7, 2011 at 5:35 PM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    thats no problem, there for awhile i drank two gallons a day without any problems
  9. Apr 7, 2011 at 5:35 PM
    jaw154
    jaw154 Well-Known Member
    Jared
    CA
    2016 Quicksand TRD Off road
    Soon...
    You'll be fine with a gallon. i try to do that everyday :D
  10. Apr 7, 2011 at 5:36 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    yes it is possible. I have done it and it is no fun. A gallon a day is very easy to do and you should be fine. plus it all depends on your activity level.
  11. Apr 7, 2011 at 5:36 PM
    97yota4wd
    Eric
    Mesa, AZ
    okay cause i just starteddrinking alot of water, was going to shoot for 2 gallons a day, but from what i have read that might be a little excessive. thanks guys!
  12. Apr 7, 2011 at 5:40 PM
    davestaco
    David
    Schofield Barracks
    it all depends. if you work out a lot or do alot of activitys youll be fine with 2 gallons a day. i try to drink up to 5 liters a day when doing minimal things
  13. Apr 7, 2011 at 5:53 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    the rule of thumb for sports nutritionists is if you are exercising for an hour or less drink water; for anything over an hour have a sports drink
  14. Apr 7, 2011 at 5:54 PM
    NewMexiTaco
    NewMexiTaco Abron Cabron
    Abraham
    Santa Fe, NM
    2007 4x4 DC LB TRD Sport
    Weathertech mats; Wet Okole seat covers; Kobalt Lowpro truck box,(sitting in the shed) Snugtop Hi-liner camper shell; AFE Pro Dry air filter, Tailgate Hoseclamp mod; 5100s all around, Light Racing UCAs, OME 885 coils, OME Dakar Leafs, CB Drop, Driveline spacer. Epoxy Satoshi; Redline Hood Struts. 4x Mil Spec. bed D rings; Brute Force Fab custom DCLB Hybrid Sliders, ARB w/ Warn M8000 wench, Diff Breather mod, Alpine Deck w/ ipod cable. Iphone ziptie to rearview mirror 4wd-cam mod!
    what they said,a gallon/day, etc... but also dont overdo any electrolyte mix (or gatorade.)
    dont under do it either.remember its the diluting of the electrolyes that kills you.
    just make sure you are taking multi-vitamins, emergen-c packets, or a gatorade here and there. Gatorade is not that much better then soda in the respect that it has a ton of hi fructose corn syrup (bad)
    one really good way of getting all your electrolytes is Coconut water. It has all the good stuff with no sugar. Its kind of $$, but IMO worth it every now and then. and good for hangovers too. :]
  15. Apr 7, 2011 at 5:55 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    And some people died on a radio show to win playstation
  16. Apr 7, 2011 at 6:02 PM
    NewMexiTaco
    Abraham
    Santa Fe, NM
    that sounds good as long as you go back to water after one or two sports drinks.
    For clinical dehydration (heat exhaustion, dehydration, exposure,etc)
    We would give diluted gatorade. double the water half the mix. that way theres not too much sugar and electrolytes all at once.
  17. Apr 7, 2011 at 6:07 PM
    homesweettaco
    homesweettaco Well-Known Member
    Mark
    Nederland, CO
    2000 TRD Black
    Camper shell, yak rack, pop-n-lock, ultragauge, 2 inch suspension lift, K&N Intake, blacked out grill, BHM with clear lenses, debadged, favorite mod: center console from '01 with REAL CUPHOLDERS!
    Two gallons a day would likely be pretty excessive unless you're exercising strenuously and perspiring heavily for long periods of time. Taking multi vitamins or products like emergency would be good, but don't over do these either. Most vitamins are safe in larger doses but not all, follow instructions on bottle. These things will provide only a limited amount of electrolytes however so it's most important to be sure you are eating enough. Salty snacks like trail mix, pretzels, and some fruits and veggies will provide good electrolytes that your body needs. Basically, just eat a normal healthy diet along with your gallon of water each day and you'll have nothing to worry about. However if this is a big dietary change for you, consult your doctor. There are some products like Nuun and Hammer out there for endurance athletes that have limited sugar from natural sources (no high fructose) and will supply good electrolytes. $0.02
  18. Apr 7, 2011 at 6:12 PM
    davestaco
    David
    Schofield Barracks
    i came close to it. I drank way way to much at one point and kept passin out at work. and seein how im a roofer, thats not safe at all. came home and started a month long recovery to get my electrolytes balanced again.
  19. Apr 9, 2011 at 1:03 PM
    97yota4wd
    Eric
    Mesa, AZ
    dam thanks guys...
  20. Apr 13, 2011 at 8:55 AM
    jmo
    jmo Member
    Mississippi
    SR5 4WD 4.0 V6 TRD Off Road
    TRD CAI, TRD Catback, nurf bars, 3"procomp suspension lift
    Drinking to much water=hyponatremia (low salt). Salt is one of your electrolytes and is essential for your body to function. It can kill you. Seen it happen in the military.
