is it possible to go into first gear from neutral?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluejays, Apr 22, 2009.
  1. Apr 22, 2009 at 8:45 PM
    bluejays
    bluejays [OP] Well-Known Member
    hi guys. i have a question about manual stick driving. whenever i am in neutral and the light turns green, i can never put it into 1st gear. i always feel a resistance and i don't want to force it into 1st gear. i always try to get it into 1st gear when i am under 5 mph but it just never goes in. am i doing something wrong? is it possible to get it into 1st gear? since 1st never works, i put it into second and the car is like shaking. is this good for my car? what do you guys do in this situation when you are rolling in neutral and proceed under 5 mph? thank you!
  2. Apr 22, 2009 at 8:48 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    what you can try, is try moving ahead at the red light in second, then try to put it into first..The synchros may not be lining up perfectly. Do you just throw it in neutral when you come to a light, or do you down shift? 5-4-3-2-1-N
    If all else fails, take it to toyota.
    Also, fill your profile out
  3. Apr 22, 2009 at 8:53 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    I do it all the time. Coast up to the stop, drop it in first and take off. Do the same thing downshifting...no issues at all.
    Not sure what you got going on with yours.:confused:
  4. Apr 22, 2009 at 8:59 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Mine goes into 1st just fine if I'm sitting still, it's a little more resistant if I'm rolling when trying it but can be done
    Using 2nd to start off in is hard on the clutch cause you have to slip it which increases wear and decreases the life of it
  5. Apr 22, 2009 at 9:03 PM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    I know exactly what you're talking about. My old Neon did the same thing. I think it's a safety feature to prevent you from accidentally putting it in 1st at high speeds. You don't really need to "force" it, just press a little firmer. On mine, it loosened up after a while.
  6. Apr 22, 2009 at 9:08 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    if thats a safety feature then it dont work on mune
    when i was first learning to drive a manual i accualdentally put t in to ffirst going like 30 and all it did was rev my motor up high and made my rear tires kinda stop for a second
  7. Apr 22, 2009 at 9:29 PM
    bluejays
    thanks for the help. how much more hard should i do it? i've already tried pushing it pretty hard into 1st when i was rolling my car at about under 5 mph. it just feels so wrong like i am going to break it. what is the proper way anyways? do most people put it into 1st going under 5 mph or keep it in second? the car is rolling so slowly and i'm not sure what gear it should go to either 1 or 2.
  8. Apr 22, 2009 at 9:42 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    thats how my integra was and it had no torque, so i really couldnt not stop at lights. just plan ahead and take the turns quicker at speeds u normally would use second
  9. Apr 22, 2009 at 9:43 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    My does not like to go in to 1st when moving, except when I'm almost to a stop. It's a real pain... If I roll up to a red light, and I'm about to come to a stop, and the light turns green I'll usually just keep slowing down until the tranny lets me go in to 1st. It probably ticks off the people behind me but oh well... At that speed I don't like accelerating from 2nd because it lugs big time.
  10. Apr 22, 2009 at 10:21 PM
    bluejays
    what do you mean by lugs? do you mean it shakes or something? is this bad for the car? since i can't get it into 1st, i always put it into 2nd and feel the shaking. is this bad?
  11. Apr 22, 2009 at 10:48 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    Maybe try double clutching and give it a little gas to rev match a little better... I know what you're describing, but never really had that problem...
    Also, I try to never be in neutral unless I'm stopped at a long light... I upshift and downshift as necessary, but am always in a gear... I feel you have more control of your vehicle and it is safer in all situations that way...
  12. Apr 22, 2009 at 11:03 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    The rpm levels do not apply to your truck, but the concept is the same.
  13. Apr 22, 2009 at 11:58 PM
    Ragin
    Ragin Well-Known Member
    Lafayette, Louisiana
    07 4x4 SR5 TRD
    3inch Skyjacker front struts, Skyjacker hydro7000 rear shocks w/ AAL, K&N CAI, Instrument Cluster Mod, GrillCraft Mesh Grill w/ Pro Comp 9556 5" fog lights, fog light mod, Wet Okole Seat Covers, Remote Start, BHLM, Diamond D3 10", Twister F2 190 Amp,
    hey man, my prelude kinda had that problem every once in a while...when I was at a complete stop i would have to let the clutch out almost to the sweet spot and push my shifter into 1st gear and it would go in, then I proceed to the sweet spot and apply gas and what not.
    You're car should go into 1st at 5 mph, thats a pretty low speed, your synchros may need some adjustments but try the above and see if that works for you.
  14. Apr 23, 2009 at 12:45 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    My manual is tough to get into first quite often as well. What I find works, is either just holding some constant pressure on the shifter just as I'm almost coming to stop until it pops in, or sometimes I find it necessary to let the clutch out just a little bit while holding pressure on the shifter and it will then pop into gear.
    Hope this helps a bit......
    Also, you DO NOT want to put it directly into second like that and get that shudder. You're lugging it at far too low RPMs if it is doing that. If its really necessary to go into second instead of first, make sure you slip the clutch until it gets up to enough speed that it wont lug the engine. Its harder on the clutch and will wear it faster though so only slip it in 2nd if you cant hit 1st.
  15. Apr 23, 2009 at 12:45 PM
    bluejays
    hey thanks for the help. what is the general rule when the car is rolling at about 5 mph? when do you know to put it into 1st or 2nd, what mph is your indicator?
  16. Apr 23, 2009 at 1:15 PM
    RelentlessFab
    Eric
    Sparks, NV
    I'd say that 10 MPH is typically my cutoff for deciding which gear. You'd still need to slip the clutch a little when going to second at that speed, until you reach maybe 15 mph or so.:cool:
  17. Apr 23, 2009 at 1:15 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    For me, (your milage may vary) I use second as long as the truck is still moving. First if I am stopped. If you are sitting at a light in neutral, try putting it in second, not letting off the clutch, then right up into first. I had trouble with my 04 going into first, so I developed this method, and it is just habit now, so I can't really tell you if the 07 will go into first without first being put into second.
  18. Apr 23, 2009 at 7:56 PM
    bluejays
    so even if your car is moving very slowly, you put it into 2nd? you only use 1st from a complete stop? do you use first for anything else? so it is totally okay to put it into 2nd as long as the car is moving(even at 2mph)?
  19. Apr 24, 2009 at 5:18 AM
    maverick491
    South Jersey
    It seems totally ok to me, to put my 07 v6 6-speed into second as long as the truck is still moving forward. I experience no engine lugging when doing it this way. I'm not sure what year, engine or trans you are asking about, so I can not answer that with 100% certainty, but if memory serves I did the same with my 04 4-cyl 5 speed. I'll also use first on steep grades when towing, and not even bother going for second.
  20. Apr 24, 2009 at 5:50 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Double clutch it. My old Tacoma was same way when trying to get it in reverse.
