Is it possible to order a sunroof and install it in a 1st gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Mar 14, 2019.
  1. Mar 14, 2019 at 8:03 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
  2. Mar 14, 2019 at 9:19 PM
    Jeremy Martin
    Jeremy Martin Well-Known Member
    1st Gen Taco
    It's possible, but I do not feel it's worth it.
    I've been in the auto body business for years and I have seen way more bad after market or factory sunroofs added than good ones. If you are set on doing it you will want to make sure the part # for the roof panel is the same on the trucks with the factory sunroof as the trucks without. I am pretty sure it's not. On most vehicles with factory sunroofs they have additional braces to support the sunroof frame and motor if it's motorized.
    Cutter_[OP] likes this.
  3. Mar 14, 2019 at 9:36 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Some companies make aftermarket sunroofs and install them.
    Webasto is one thats off the top of my head.
    Some 2nd gems had them installed on here, and seemed happy with them.
    If I recall correctly, they were maybe about $1000-$2000 installed.
