Is it possible to replace the rear window on a camper shell?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Jan 3, 2019.
  1. Jan 3, 2019 at 2:22 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    I am going to look at a camper shell for $70. It needs paint and upholstery which is very easy for me to do. But the rear window as seen in the picture attached, is it possible to replace it with a new sheet of plexi glass?
  2. Jan 3, 2019 at 2:30 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I replaced mine with a piece of 3/16" Lexan after I shattered it when my gas grill slid into it (inside). Only pic I have of the back of the truck, sorry. Maybe you can see it better by enlarging. Pulled that damn trailer from GA to Western Colorado to Michigan this summer!
    It's not a fast process putting that glazing back in the back door of a topper, but it can be done if you're patient!
    2002Tacoma4x4 likes this.
  3. Jan 3, 2019 at 2:33 PM
    Dogs
    Dogs Well-Known Member
    Nick
    Missouri
    02 tacoma TRD SR5
    You could, but it could be kinda difficult to get it cut exactly right I think. But I bet it could be done if you used your existing glass as a template for it?
  4. Jan 3, 2019 at 2:39 PM
    Kleenax
    Ray
    Michigan
    I just used the aluminum frame to make my template out of cardboard. Cut the Lexan with a fine-toothed jigsaw and it worked after doing a little more "whittling" on the rounded corners ;-) I re-used the stock rubber gasket and also utilized a tube of weather-stripping adhesive. And to me, it looks stock!
    Jlarios956 and MitochondriaMan like this.
  5. Jan 3, 2019 at 4:05 PM
    MitochondriaMan
    MitochondriaMan Well-Known Member
    MitoMan
    Florida, USA
    04 3.4 TRD 4WD
    Tundra hyper-silver double 5-spokes with 265-70-17 BFG All-Terrains. Compact Cobra CB in the ashtray slot. Cut a small hole in the plastic and mounted the antenna to the drivers side windshield wiper mount using an old Harley Davidson blinker bracket. 1 1/4" drywall screw is holding door handle together nicely.
    Masking tape along your cut lines, make it easy to see your marks and protects plexiglass from tool scratches.
  6. Jan 3, 2019 at 5:02 PM
    MitochondriaMan
    MitoMan
    Florida, USA
    04 3.4 TRD 4WD
    Alot of toppers use the same windows & frames. I'd look for one craigslist, you might find a matching one or new one for cheap. I got mine for $50.
  7. Jan 3, 2019 at 8:19 PM
    tony2018
    tony2018 Well-Known Member
    Lexan glass,
  8. Jan 3, 2019 at 8:21 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    Or spend $100 and have a glass guy fit you up right.
  9. Jan 3, 2019 at 9:37 PM
    Cutter_
    Where and how much did you get your trailer for? A dealer? Craigslist? I am in the market for an enclosed single or double axle for a motorcycle
  10. Jan 5, 2019 at 6:24 PM
    Kleenax
    Ray
    Michigan
    Bought it from the factory in GA. Cajun trailers is the website I think. Jerry is the guy to talk to. Was about $1800 cheaper than anywhere else, but had to pick it up myself in BFE Georgia.
