Is it possible to ruin a 2009's brakes in 9,000 miles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fireguy615, Mar 17, 2011.
  1. Mar 17, 2011 at 11:59 AM
    Fireguy615
    Fireguy615 [OP] Member
    Scott
    Abq,NM
    2009 TRD Offroad DC 4x4
    So I just bought a 2009 double cab TRD 4x4 with 9,200 miles. There are tell-tale signs that the 1 previous owner towed with it. Holes in the right side cubby where he had a trailer-brake mounted. Some damage to the tailgate where he forgot to use the backup cam to align his hitch:D. But its the brakes that concern me a tad. Now I haven't taken the wheels off yet to inspect. But the pedal feels firm, hard and flat with only about 2-3" of travel. I am new to tacomas and don't have anything to compare to. But much different from my '08 Tundra I traded in to get this.
    The truck stops ok but the pedal just doesn't feel right to me. Especially for a truck with only 9,000 miles on it. Fluid resevoir is fine. I guess I'm happy it seems he was using a trailer brake. So I guess the question is....can you fry a Tacomas brakes (pads, or rotors, or calipers) in only 9,000 miles??
  2. Mar 17, 2011 at 12:05 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Can u? Yes
    Should u? No
    You should get 60-70k out of them.
  3. Mar 17, 2011 at 12:13 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I would change the fluid out and bleed the brake system then address any issues after that.
  4. Mar 17, 2011 at 12:14 PM
    Fireguy615
    Scott
    Abq,NM
    It is the TRD Offroad, not the Sport.
  5. Mar 17, 2011 at 12:16 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Let me tell you my "motto" I've rather loose with a smart, guy, partner, etc.
    than win with an idiot. I run away when I see them on highway, I do not do business with them, nothing. And if I see a truck with the rear gate banged from neglect, stupidity, etc., I don't need that truck. (9000 miles with bad breaks?), How about the engine? Did he ever changed that oil? did he pull a 6000 lb trailer next day after he purchased the truck new? Not me.
    Take care
    vbibi:(
  6. Mar 17, 2011 at 12:23 PM
    Fireguy615
    Scott
    Abq,NM
    Well I didn't really put everything together until after I bought the truck. Bad on me. I was given such a good deal on it ($26K) vs booking at $32K I probably jumped the gun on it. But it is hard loaded and otherwise mint. And the damage to the tailgate is just some light scratching. And the engine looks and feels great. So maybe i goofed. Or maybe not. I dunno, the brakes just don't feel right to me.
  7. Mar 17, 2011 at 12:26 PM
    Fireguy615
    Scott
    Abq,NM
    That makes me feel a little better. Thanks for the help.
  8. Mar 17, 2011 at 12:28 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Naahhhh your probably fine. Just take it into the shop and have a mechanic take a look.
    :D
  9. Mar 17, 2011 at 12:43 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Prolly fine. Have mechanic check it at your 10k oil change.
    And 26K isn't unusually low for a 2 year old truck. So you don't need to be "looking" for something to be wrong with it.
    Also, if you search TW, you'll find lots of 2nd gen owners griping about "spongy" brake feel that turns out to be normal, if not exactly desirable.
  10. Mar 17, 2011 at 1:06 PM
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    Go test drive some brand new trucks and see how those feel. I highly doubt you can fry brakes in 9k. Highly doubt. Also if it only has 9K miles that truck should still be under warranty. Take that bastard in and have them look and fix if need be.
