Is it possible to run 285/70/17...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gmazz73, May 21, 2018.
  1. May 21, 2018 at 2:42 PM
    gmazz73
    gmazz73 [OP] Well-Known Member
    Greg
    2018 Tacoma TRD Offroad Cement
    Would like to run some bigger tires on my 18' OR 4x4 without changing out the whole suspension system. Unfortunately 275 are only offered in the BFG KO2 and i'm not the biggest fan of their look. Was hoping to go with Nitto ridge grapplers or Toyo. This is my first truck and first run at this so please, any help would be appreciated.
  2. May 21, 2018 at 2:57 PM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    Possible to fit 285s on Stock suspension? Yes.
    Will it rub all over the place? Yes.
    Do you need a lift to clear 285s? Yes.
    Will it still rub after getting a lift? Maybe.
    Lift + CMC + More trimming = 285s
    Blazingbluesport and bobrown14 like this.
  3. May 21, 2018 at 3:14 PM
    Southern81
    Southern81 Well-Known Member
    2018 Cement DCSB OR
    Without lifting, I wouldn’t attempt 285’s. It’ll rub like crazy.
    Blazingbluesport likes this.
  4. May 21, 2018 at 5:31 PM
    gmazz73
    Greg
    Thank you for the info
  5. May 21, 2018 at 5:40 PM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    You know they should make your answer a sticky for that frequently asked question. Summed it up perfectly
    siznarf[QUOTED] likes this.
  6. May 21, 2018 at 5:50 PM
    Blazingbluesport
    The OC!
    Nitto makes the Ridge Grapplers in a 255/80/17. It’s a taller but narrower tire. Just put in 255/80/17 in the search, there is a couple hundred posts. Some claim no lift and no rub, but I don’t know if it’s true. It would seem very close to me.
