is it really worth lifting a 5 lug?
Discussion in '5 Lug' started by Hinanomon, Mar 20, 2012.
  1. Mar 22, 2012 at 8:01 PM
    #41
    TrdSurgie
    TrdSurgie revised
    Oahu
    So much fail. I kept reading hoping it was going to get better.
  2. Mar 22, 2012 at 8:12 PM
    #42
    LTRANGER661
    LTRANGER661 Well-Known Member
    X2! My truck sits low, With front and rear longtravel. Simple is better to me.
  3. Mar 22, 2012 at 8:23 PM
    #43
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It's 2012. The 2013 models are not out yet.
    Your truck is only 1 model-year old... you've had it for 2 years.
    I'd hardly call that "used" when you got it!
    Do you want 4x4 because you NEED 4x4, or simply because you want the "Brodozer" look?
    If you just want the look, it'll pass when you realize that gas isn't cheap and everything you want to do to make the truck look badass is going to knock your fuel economy down bigtime.
    I bought a '94 5-lug. Traded it in November 2002 on an '03 Tundra.
    I put over 220k on that 5-lug.
  4. Mar 22, 2012 at 9:04 PM
    #44
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Leave it stock, buy an older 4x4 22r/re Toyota pickup and beat that thing up and not your clean newer truck.
  5. Mar 23, 2012 at 6:51 AM
    #45
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    the level of derp has increased significantly in this thread since the last time i visited.
  6. Mar 23, 2012 at 7:13 AM
    #46
    Thorpedo26
    Thorpedo26 Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    I'd just like to say when I said a little lift and locked rear could keep up with a 2wd v6 I was talking about a stock prerunner not a xrunner ..
  7. Mar 23, 2012 at 7:55 AM
    #47
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    While everyone is here, I have a question. Is there ANY other way to lift the front end of a 1st gen 5 lug other than a body or spindle lift?
  8. Mar 23, 2012 at 9:36 AM
    #48
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    Spacer lift, Fabtech Uca with coils, I think doetsch tech makes an upper arm as well to give you lift
  9. Mar 23, 2012 at 9:51 AM
    #49
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Spacer lift, v6 coil, spindle, fabtech coil, jd or tc long travel, full custom lt.
  10. Mar 23, 2012 at 11:42 AM
    #50
    LTRANGER661
    33" tires in the front and 31" tires in the back
  11. Mar 23, 2012 at 11:57 AM
    #51
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    Lol.
  12. Mar 23, 2012 at 12:19 PM
    #52
    noSKills858
    Alex
    Poway, CA
    And you get to make a 10pt turn radius to save the tread!
  13. Mar 23, 2012 at 4:25 PM
    #53
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :facepalm:
  14. Mar 23, 2012 at 4:28 PM
    #54
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    all those lift coils ride like shit from what ive heard. spindles are your best bet. unless you wanna convert the front to coiovers but thats a waste of money might as well go lt
  15. Mar 24, 2012 at 7:11 AM
    #55
    jsutter
    jsutter Well-Known Member
    Jim
    Southeast Ohio
    08 Reg. Cab 4cyl 2wd
    cruise and intermittent wipers
    Your parents bought you a (nearly) new truck. Drive it and be happy.
    You don't want to cause any tension in the house by selling a gift.
  16. Jun 4, 2012 at 12:25 AM
    #56
    09TacomaSoCal
    09TacomaSoCal Well-Known Member
    Tim
    Lancaster ca
    09 Tacoma prerunner sr5
    2009 tacoma sr5 prerunner, 6speed manual 4.0L. 2.5 leveling kit, 285/75/16 mtr tires.
    Thought about it for a while.
  17. Jun 4, 2012 at 4:03 PM
    #57
    wahvtec
    wahvtec Member
    Statesboro, Ga
    96 tacoma
    Plate front bumper 3 inch lift Usual stereo stuff
    i decided on a 3 inch spindle lift, and add a leafs for my 96 5-lug. Selling it wouldn't give me enough money for a equally reliable 4x4, and i plan on lighter off-roading such as trails, cross a few streams, not quite rock crawling or mud-bogging. This whole decision to me would depend on what kind of off-roading you plan on doing. Another differences is if your parents would let you sell your truck you could get a nice 4x4, as your truck has a lot of value in its factory condition.
  18. Jun 4, 2012 at 4:20 PM
    #58
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    x2....
    make due with what you got. Look at my truck for example.
  19. Jun 4, 2012 at 6:32 PM
    #59
    Rich91710
    Rich
    Los Angeles
    08 Base
    What's wrong with your truck... other than a little bro-lean? :p
  20. Jun 4, 2012 at 6:38 PM
    #60
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    It can hit a wall of sand get some pretty good air and some what survive :anonymous:
