Is it safe to wash the engine with a hose?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, May 6, 2015.
  1. May 6, 2015 at 12:53 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    There are many generic instructions out there on how to clean the engine and everything else that's under the hood. Most of them involve flushing with a hose. I was wondering if that's always safe in the case of Tacoma or if there are parts that should not get wet.
  2. May 6, 2015 at 1:07 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    IMHO
    When truck is off and cold than hose. Simply that kind of volume of water will cool anything very quickly. If Engine is cold than no possibility of things cracking.
    When its running power wash but with some distance and low PSI to not damage seals.
    foampile[QUOTED][OP] likes this.
  3. May 6, 2015 at 2:02 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    I have this mist setting on my hose nozzle that I usually use. It's probably a little overcautious, but it works pretty well., Like BlueT said, I'll do it when the engine is cold. I will normally just wet down the engine, and related components, and will soap underside of the hood. My engine bay has never had a chance to build up anything worse than heavy dust, and salt on the underside of the hood, so that's usually enough to keep it looking good. After that I will take the leaf blower to it, to dry it off.
    Abby and foampile[OP] like this.
  4. May 6, 2015 at 2:18 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    I once power washed under my hood at a local car wash...low pressure and didn't stay in one spot very long. Maybe I got lucky and didn't **** anything up, just my experience though
  5. May 6, 2015 at 2:22 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I was my engine bay all the time. Make sure the truck is cold. A few sprays of simple green. Let is sit 5 minutes. Then hit it with the hose on a light shower type function.
  6. May 6, 2015 at 2:24 PM
    CO Ryan
    CO Ryan Well-Known Member
    Colorado
    13 TRD Offroad
    stuff
    Squirt Simple Green all over everything, then hose off. Avoid battery, fuse box, electrical components. Cold engine. No problemo.
  7. May 6, 2015 at 2:39 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Just put a plastic bag over the fuse panel and you should be fine. But like everyone says, avoid using a lot of force in the same area for a long period of time.
  8. May 6, 2015 at 2:41 PM
    Mademan925
    Nick
    Discovery Bay, CA
    if you use simple green it doesnt take any force to clean anything
  9. May 6, 2015 at 2:43 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Simple green is magic.
  10. May 6, 2015 at 2:43 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    A lot of car washes have a low pressure setting for washing and rinsing engines. That's what I use.
  11. May 6, 2015 at 2:46 PM
    Mademan925
    Nick
    Discovery Bay, CA
    I use it for everything. I even keep a bottle of it in my bathroom by the garage so I can use it to wash my hands after working on my truck, cars, or the yard.
  12. May 6, 2015 at 2:46 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Never tried simple green before. I also have avoided washing my Taco's engine. The only engine I ever wash is the one in my 98 Maxima and that I use the tire cleaner (green stuff) that they had at the car wash, then rinse it down (with the engine cold). It works okay on the metal but cleans the plastic till it looks brand new. Maybe I'll try some Simple Green on the Taco soon.
  13. May 6, 2015 at 2:48 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Everything is marine grade under there anyway. If it wasn't, think of the electrical failures from people driving in heavy rain. You couldn't drive a Tacoma in in the Pacific Northwest or Florida.
    DoorDing likes this.
  14. May 6, 2015 at 2:49 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    I've found the clear degreaser they make is great for really dirty engines. Spray that on there, do a little scrubbing where necessary, rinse, then use the regular simple green.
    I like to follow up with a little Aerospace 303 on the plastics and rubber.
  15. May 6, 2015 at 2:49 PM
    vtdog
    vtdog Well-Known Member
    NH
    Why does the engine have to be cold? It can be a thermal shock issue as the trucks drive all the time in the cold weather and get splashed with water that is a lot colder than what is coming out of the garden hose without problem. If there is something else I don't know what it could be
  16. May 6, 2015 at 2:55 PM
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    Spray em with simple green. Relax with a cold beer then pressure wash it. Never have any problem.
    Scrub them if its still dirty. Old toothbrush really helps on hard to reach part. Dont get to close with a pressure washer.
    Ill do it when its engine is cold.
    @vtdog... A few splash is different from a gallon or so of water coming out of the garden hose.
    foampile[OP] likes this.
  17. May 6, 2015 at 4:28 PM
    TacomaZL
    Illinois
    You are correct, it doesn't HAVE to be cold, when I did mine at the car wash it was kinda warm, but why not do it cold? Why risk the slight possibility of causing issue when you can just wait a little for it to be cold and clean worry free? You know what I mean?
  18. May 6, 2015 at 4:51 PM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    It would seem like a good idea to bag the alternator also, especially when using chemicals.
    Have not needed to wash mine yet but seems like I remember seeing some corrosion on the alternator of a previous truck after using Bleche Wite and water to clean engine.
  19. May 9, 2015 at 1:55 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I have washed mine semi-regularly since new, hot or cold, high or low pressure, Simple Green or just water. Never had a problem after a wash.
  20. May 9, 2015 at 4:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I used to use Simple Green, but I was never impressed with it.
    I've used Dawn Power Dissolver.... and that shit worked awesome!! (cold engine, regular hose, no other prep, running or not). But like most things that I like, I can't find it anymore anywhere!!!
