Is it Taco lean??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FLYH2O, Jun 30, 2020.
  1. Jun 30, 2020 at 8:23 PM
    FLYH2O
    FLYH2O [OP] Well-Known Member
    2016 Tacoma TRD Sport Blue
    I just finished installing 6112s in the front of my 2016 double cab sport trd 4x4. Put 5100s on the ass end as Bilstein told me the 5160s are having tons of leaking issues and said I’d be better served with 5100s.
    I set the 6112s at notch 5 on the drivers side and notch 4 on the passenger side.
    It now leans to the drivers side a lot. It looks like the back end is sagging on the drivers side.
    Is this the infamous “Taco Lean” ? I thought the notch 5 on the drivers side would compensate enough?
  2. Jun 30, 2020 at 8:24 PM
    doorsidedown
    doorsidedown Well-Known Member
    got any pics?
  3. Jun 30, 2020 at 8:28 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Are you sure you didnt do 4 on drivers and 5 on passenger? Easy mistake so just asking. Taco lean is usually not that noticeable unless you really look hard or measure. :notsure: but once you see it you'll always notice it.
    whatstcp and Skydvrr like this.
  4. Jun 30, 2020 at 8:41 PM
    FLYH2O
    I was thinking that but no. Its leaning on the ass end and the front sits level
  5. Jun 30, 2020 at 8:49 PM
    20tacoma17
    2017 DCLB Sport AT
    Not sure what to tell you there. Taco lean is mostly in the front. Any mods to the rear other than shocks?
  6. Jun 30, 2020 at 8:51 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Full tank of gas will squish the left rear
  7. Jun 30, 2020 at 8:53 PM
    FLYH2O
    Its half full.
  8. Jun 30, 2020 at 8:54 PM
    FLYH2O
    Is there a cure to bring the ass end up on the drivers corner?
  9. Jun 30, 2020 at 8:55 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Better leafs. It's pretty universally agreed the OEM leafs are weak.
  10. Jun 30, 2020 at 8:57 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Squats worked for my wife. Brought that ass right up :p
  11. Jun 30, 2020 at 8:57 PM
    20tacoma17
    2017 DCLB Sport AT
    Have you driven it around yet to let the suspension settle in? Also have you put it on level ground and taken measurements at all 4 corners?
  12. Jun 30, 2020 at 9:01 PM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    So two thoughts.
    The leafs will typically have a + or - on them if you changed the leafs or added an AAL. You might want to swap leafs. That's a lot of work.
    The other thought is that changing your shock shouldn't have changed the lift. The springs handle lift and shocks handle the ride dampening.
    What changes did you do to the rear leafs, or blocks, or AALs. That might help us narrow this down some.
    TacoRated and 20tacoma17 like this.
  13. Jun 30, 2020 at 9:01 PM
    Vlady
    Issy, WA
    From my aviation days, you have about 60 to 70 lbs at that corner with 1/2 tank pushing on soggy back
    You should get measurements at 4 corners to see if there is a lean
  14. Jun 30, 2020 at 9:09 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'm willing to bet the truck is a long bed?
    Mine has always had some lean in the rear only. The gas tank is back there and the adjustment at the front has less of an effect back there simply due to the length of the chassis
    FLYH2O[OP] likes this.
  15. Jun 30, 2020 at 9:50 PM
    FLYH2O
    i did do one inch blocks in the rear.
  16. Jul 1, 2020 at 5:15 AM
    20tacoma17
    2017 DCLB Sport AT
    Are the blocks tapered? If so is the taper towards the front on both?
  17. Jul 1, 2020 at 5:23 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
  18. Jul 1, 2020 at 5:25 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Rear was torqued in the air or on the ground?
    Skydvrr likes this.
  19. Jul 1, 2020 at 6:46 AM
    FLYH2O
    in the air. Never thought of this? Will it cause an issue?
  20. Jul 1, 2020 at 6:55 AM
    splitbolt
    NW Arkansas
    Yes.
    Lt. Dangle likes this.
