Is it the hill that's killing me.... Gas
Discussion in 'Performance and Tuning' started by rhowell, May 24, 2014.
  1. May 24, 2014 at 11:51 PM
    rhowell
    rhowell [OP] Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    Just got my best tank ever today. Light came on at 237miles. Wish I was getting the 300+ that everyone keeps talking about.
  2. May 25, 2014 at 12:15 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    need more info
  3. May 25, 2014 at 7:28 AM
    Tmill
    Tmill Well-Known Member
    Tyler
    Florida Panhandle
    07 Sport Black DCLB
    How much idling do you do? I was getting that in the Alaska winters when my truck would idle as much as it moved.
  4. May 25, 2014 at 7:46 AM
    rhowell
    Robert
    Canada
    Almost zero idle. Live on the top of a hill. Elevation change in driving every day would probably be around 1500 to 2000 ft. Average road grade that I would be driving would be about 9-10%
  5. May 25, 2014 at 7:48 AM
    rhowell
    Robert
    Canada
    I'm getting about 14mpg
  6. May 25, 2014 at 8:08 AM
    jsi
    jsi Well-Known Member
    native earthling
    Talking about miles per tank is just stupid, how many mile per gallon are you getting? My light may come on at a different time than yours. However you can calculate MPG no matter how full or empty the tank is. I get between 17 to 22 mpg depending on how much city vs highway driving. (and the 17 mpg came from city driving with many jack rabbit starts.)
  7. May 25, 2014 at 8:15 AM
    jsi
    native earthling
    OK 14 mpg is a number I can understand. Ouch! Even my lifted Jeep with big ol tires did better than that. Do you have a bunch of mods?
  8. May 25, 2014 at 8:17 AM
    DeSean Thick
    DeSean Thick TuRD TACO
    Sean
    Snowmass, CO
    05 TRD Sport Speedway Blue
    Robert, I have a similar, albeit smaller, elevation change everyday of around 1000 feet. I don't keep track of my mpgs because it's too depressing, but I know it's around 15. Unfortunately because of the aerodynamics of our trucks and the friction on the road of 4 truck tires, going downhill does not make up for all the lost gas it takes to get uphill. I'd say take as much excess weight out of your truck as possible and be conservative with the gas pedal, even downhill. That's probably your best chance at saving whatever fuel you can
  9. May 25, 2014 at 8:29 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Since i've been looking at my scanguage a lot while driving I find any kid of accelerating kills your mpg. Cruising speed is the only place you see good mpg, so you have to accelerate to go up hills is really going to hurt it. Also coast as much as you can, even a little throttle when you don't need it can hurt your mpg.
  10. May 25, 2014 at 9:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What is your tire pressure? If it is to low, you will greatly diminish mpg.
  11. May 25, 2014 at 12:29 PM
    rhowell
    Robert
    Canada
    Running Duratracs at 32psi.
  12. May 25, 2014 at 1:03 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Try them at 35psi and see if it helps. My worst tank in my '09 with 285 Toyo MT's was about 230 for 17 gallons. I averaged 16.8 in that truck. In my '14 I've been averaging 18.2 mpg with mixed city/highway driving with 265/75/16 AT's I run 35psi.
  13. May 25, 2014 at 1:10 PM
    whoareyou133
    whoareyou133 Well-Known Member
    Claremont Los Angeles
    02 Prerunner TRD
    No pre runner trim, no mud flaps,no step ups,I do have the Deck plate though. Kings @ 0 and 5100's in rear. stock leafs. Total chaos UCA.
    Lol x2
  14. May 25, 2014 at 8:23 PM
    Tmill
    Tyler
    Florida Panhandle
    07 Sport Black DCLB
    How many miles? When's the last time the truck was serviced like plugs filter and such? I changed my plugs in the middle of a trek from Seattle to San Antonio and the mileage jumped a little after the change.
  15. May 25, 2014 at 10:08 PM
    rhowell
    Robert
    Canada
    Plugs changed at around 60,000 miles. Have 72,000 miles right now. Just had all the oil changes done yesterday. Front & rear, engine, transmission.
  16. May 25, 2014 at 10:25 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    What's the elevation in your area? And are you driving with the shifter in "D" or "4"?
    Do you have 33" tires? You need to account for odometer error when calculating milage. 14 mpg x 33/31 = 15 mpg actual.
