Is it the wheels, balance, alignment???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luvmytacoma, Apr 3, 2012.
  1. Apr 3, 2012 at 3:24 PM
    luvmytacoma
    luvmytacoma [OP] New Member
    I took my '09 Tacoma for new tires (Bridgestone Duelers). Prior to that the tire pressure sensor was lit. After they put the new tires on the rims (stock rims) they said it was very hard to balance the tires and the rims "may"be out of round. And the sensor is still lit. The tire guy does not know why. Also said I should get an alignment when I get new tire. There is a shimmy now.
    I just don't know where to turn, the dealership, a rim guy, another tire guy.
    Why would the sensor still be lit? Did they balance the tires properly?
    Any ideas would be a great help since I am tired of pouring money without answers.
  2. Apr 3, 2012 at 3:27 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Maybe they broke a sensor when they changed the tires
  3. Apr 3, 2012 at 3:36 PM
    OZ-T
    Peter North
    British Columbia
    No
  4. Apr 3, 2012 at 4:56 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    You guys realize he said it was lit before, and is still lit now. Lol.
    OP. If your tire light blinks for 30ish seconds and goes solid, you have a sensor issue. If it blinks once and goes solid, you have a pressure issue.
    That "shimmy" you have is because or improper balance. Worst case, it could be a loose wheel they didn't torque. (check for that ASAP). Take it to a proper tire shop that has a balancer that can check for an out of round wheel or tire, and that can properly balance your wheels.
    As for alignments. They are not necessary unless you replace suspension components, or you are experiencing an issue (tires not wearing properly, pulling to left or right, etc) Alignments used to be more common, but on newer vehicles, especially Toyotas, the specs rarely go out of spec on their own.
    Other questions? Feel free to Pm me.
  5. Apr 3, 2012 at 5:08 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    If you did not have a balance problem before the new tires were put on then it's the tires. As far as the tire pressure sensor that is another issue. A sensor may be bad. Not sure if the spare is considered part of the system. Check the pressure on it. I think the sensor is set for about 25 lbs. Check around each wheel for any wiring problems, like bad connections etc.
  6. Apr 3, 2012 at 5:33 PM
    OZ-T
    Peter North
    British Columbia
    If the tire was low pressure prior to bringing it in it would show a light and the sensor can fairly easily get damaged changing tires so , brought up to pressure and the TPMS reset could still show a light , no ?
  7. Apr 3, 2012 at 8:07 PM
    1GR
    Scott
    BC, Canada
    Skimmed it. Saw the "may have damaged part" and moved on to the next sentence. Lol.
    True. Now it all depends on the OP. Was the light flashing or solid before. And is it solid of flashing now?
  8. Apr 3, 2012 at 8:09 PM
    OZ-T
    Peter North
    British Columbia
    Jerk
  9. Apr 3, 2012 at 8:31 PM
    1GR
    Scott
    BC, Canada
    Asshat
    :cool:
  10. Apr 4, 2012 at 5:02 AM
    luvmytacoma
    Thanks for the replies (I think)
    Well the sensor was lit solid before and solid after the new tires were put on. So none of you addressed the shimmy nor the rims being out of round.
  11. Apr 4, 2012 at 5:20 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The shop should have addressed the rim issue when installing the new tires. It is standard proceedure to check the rim for runout when there is a balance issue. If the rim has been checked and still won't balance, the tire is suspect. If the rim is tweaked, the tire won't turn true.
    Take it back and complain that they f'd you when they installed the new tires. Since they didn't do their job correctly the first time, they owe you a free rim inspection.
    BTW, an alignment, after a PROPER tire installation, is standard proceedure too. Once a year, 6-8k miles, or after new tires. It really depends on the roads and driving style. Once your tires start to wear improperly, it is not reversable; especially when worn out of balance.
    It made me laugh when you noted this: "After they put the new tires on the rims (stock rims) they said it was very hard to balance the tires and the rims "may"be out of round." Ok, it maybe out of round, what does that mean, and what should I do about it? Your shop, after you get the problem fixed, should be left for a better one.
  12. Apr 4, 2012 at 5:32 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Find a shop that uses one of these. That machine will identify any problem with the rim or tire. Dealer locator on the site.
    http://www.gsp9700.com/
  13. Apr 4, 2012 at 5:37 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Did the guy even know how to reset the sensors? Maybe he never reset the sensors after install? Have you tried to reset them yourself? (Instructions in manual)
