Is it tire height or width that causes problems?
Discussion in 'Wheels & Tires' started by NC15TRD, Aug 24, 2011.
  1. Aug 24, 2011 at 12:42 PM
    NC15TRD
    NC15TRD [OP] Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I've been thinking about new tires and I'm trying to decide on what size to get. I'm wondering if a 255/75/17 would rub like a 285/70/17? I do realize that there is a 1/2" height difference in those sizes.
    I'm also considering a 265/70/17 or 275/70/17 as well. My mind keeps telling me that it is the width of a 285 that causes the rubbing not the height.
    So anyone with info is more than welcome to chime in, and I thank you!
  2. Aug 24, 2011 at 5:23 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    could be either or...
    figure, with taller tires, when your suspension is stuffed, the taller tire will rub on the inner fender walls when the wheel travels up... on turns, the inner corner sidewall may end up rubbing on the frame...
    with wider tires, the outer corner sidewall may end up rubbing on the pinch weld or fender flares on turns, and maybe the front bumper valance...
    get a good size lift and decent wheel backspace, and you could solve the wider tire issues...
    get a good size lift and swap out to glass fenders and bedsides and you could solve the taller tire issues...
  3. Aug 24, 2011 at 6:40 PM
    NC15TRD
    Nick
    PA
    Well I would never put on different fenders and I'm not buying new wheels. (yet)
  4. Aug 24, 2011 at 6:43 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    255/80/17 has less rubbing issues than 285/70/17
    You need 2 1/2" - 3" up front
    255/75/17 should not rub , it's only a 32" tire
  5. Aug 24, 2011 at 6:44 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    the 255/75/17 will not rub on stock wheels and stock height.
  6. Aug 25, 2011 at 7:04 AM
    NC15TRD
    Nick
    PA
    I have Eibachs with 5100's at .85 so I have enough lift to cover these tires, I was just not sure if it was width or height that caused people's issues with rubbing.
  7. Aug 25, 2011 at 7:06 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    its a mixture of both, it depends on where the tire is rubbing at
  8. Aug 25, 2011 at 7:24 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Is rubbing a "problem" ???
