Is it weird...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 650H1, Feb 1, 2012.
  1. Feb 2, 2012 at 3:39 PM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Lol, nothing will happen. I work at a GM shop as a trans tech, and I have NEVER seen a parking pawl with an issue. And trust me, I have rebuilt A LoT of 4l60 and 4l80 transmissions. In the 80, the pawls are not that big, and it is holding 7-8,000lbs trucks! It will be fine.
  2. Feb 2, 2012 at 4:28 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    X2. You are more likely to break a u joint slamming it into park then doing any thing to the trans. The detent spacing is fairly wide so some times it will move a little bit before it locks.
  3. Feb 2, 2012 at 5:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Thanks for chiming in on the parking pawl thingy. Alright once and for all since you're the Trans Tech.... CAN YOU SHIFT A MANUAL TRANS WITHOUT THE CLUTCH (rev-matching they seem to call it) and not hurt the transmission or synchros? Thanks for your insight on this issue!
  4. Feb 2, 2012 at 6:34 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    From another gear specialist, shifting without the clutch is hard on synchros on a synchro transmission, unless the rpms are matched perfectly. The likelyhood of that is VERY slim. Rev matching with the clutch, ie double clutching, is easiest on them.
  5. Feb 2, 2012 at 6:42 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Makes me cringe as well when someone lets a vehicle rest on the trans.
  6. Feb 2, 2012 at 6:58 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Why? :notsure:
    That's the 'Park' is for...
  7. Feb 2, 2012 at 7:07 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    There is a parking pin in the transmission. Not all weight it going directly into the transmission. There is a separate thing for parking altogether. For all you guys saying that it would wreck the transmission, if there wasn't something locking the car the tires would just roll over the engine. As you can start a car in first by giving motion and the key switch to on(bad thing to do). Although putting the parking brake on is a good habit to get into because it does lock your tires from moving.
    I believe are trucks are servoing type drums(Correct me if I am wrong) and using the parking brake often allows for the adjustment of the drum.
  8. Feb 2, 2012 at 7:09 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    idk it just does. more so on steep inclines like a boat ramp.
  9. Feb 2, 2012 at 7:10 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    correct
  10. Feb 2, 2012 at 7:12 PM
    Night
    Canada
    Thank you good sir.
    Another thing to add, if manufacturers made so with the the vehicle putting weight on the transmission they would also make the auto's use the neutral and parking brake method vs using "park".
    Don't worry they make vehicles quite dummy proof now a days.
    As well if you plan on using your truck as a hitching point to pull something (while in park) make sure to put you parking brake as the parking pin can only handle so much till failure.
    Little late on that comment bud.
  11. Feb 2, 2012 at 7:16 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This ^^ and before I put it in park.
  12. Feb 2, 2012 at 7:18 PM
    Night
    Canada
    Also, (last time I am doing this.) if you are going to use your parking brake, be sure to put it on, put the vehicle into neutral, take your foot off the brake, then put it into park to not put pressure on the parking pin.
  13. Feb 2, 2012 at 7:23 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Aamco brochures recommends
    1. Put transmission in neutral.
    2. Engage the parking brake.
    3. Let go of the foot brake.
    4. Put transmission in park.
  14. Feb 2, 2012 at 7:24 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Automatics have a park pin because there is no connection between the driveline and the engine when the engine isn't running, which drives the transmission pump, which applies the clutch packs. You can't bomb start an auto because if this. Anything but park will act as neutral when the engine isn't running.
  15. Feb 2, 2012 at 7:33 PM
    #35
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    destroys is an understatement......:anonymous:
  16. Feb 2, 2012 at 7:45 PM
    #36
    AlaskanTaco
    Anchorage Alaska
    Yes, you can shift gears without applying the clutch. It is worse in larger vehicles with destroying the syncros. Sport motorcycles don't need to use the clutch at all. I hardly ever use the clutch on my r6 when I'm racing. No need to. The parking pawl will not destroy itself even if you are binder on a hill. It is just releasing. That is all. I have seen only one parking pawl go out. That was because his brakes went out, and had no other choice but to destroy the transmission. :-/. Sucks, but it saved his life. When the engine is not on, everything is in neutral. There is no direct connection in the transmission until 35 mph or higher (torque converter clutch is applied).
  17. Feb 2, 2012 at 7:48 PM
    #37
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    COMPLETELY different design entirely. All gears in your R6 transmission are meshed constantly, the engagement of a dog gear on a splined shaft is what transmits the power. So yes that is fine on the bike, not so much in a car trans unless you can do a perfect rev match every time.
  18. Feb 2, 2012 at 8:00 PM
    #38
    AlaskanTaco
    Anchorage Alaska
    Ahh, you caught me. I COMPLETELY forgot about that! As stupid as this may sound, I understand Automatic transmissions better then manuals. I have rebuilt over 100 autos and 2 manuals. Lol. I was that weird kid in school that did division better then multiplication.
  19. Feb 2, 2012 at 8:26 PM
    #39
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
  20. Feb 2, 2012 at 8:34 PM
    #40
    Night
    Canada
    Sorry, I was talking about manuals in that post haha.
