Is it worth it to change non-JBL speakers in a Gen 2?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Jun 22, 2024.
  1. Jun 22, 2024 at 1:46 PM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Recently, I swapped the failing stock head unit with this one.
    It's nice being able to listen to music again. The stock head unit has been a nightmare since day 1.
    Now I'm kicking around the idea of doing speakers.
    Is it worth it? I won't be doing an amp.
    I don't want to spend more than $250.
    I'm pretty sure that I have a non-JBL truck as I don't see "JBL" anywhere.
    Thanks for any replies.
  2. Jun 22, 2024 at 3:02 PM
    Turbo Dog
    Turbo Dog Active Member
    Dwight
    2008 Tacoma SR5
    I put a set of Kenwood 6x9 3 way speakers in the doors, all others are stock and it made a huge difference. My truck has a run of mill Kenwood head unit.
  3. Jun 22, 2024 at 3:10 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Don’t know how much they cost now but the Subaru tweeter upgrade used to be highly recommended and was sub 100$. Used to be able to do that and get a decent set of 6x9’s for the front doors.
    >250$
    Sound deadening is supposed to be worth its weight in gold as well. Could do a 100$ worth of material for the doors and speaker upgrade of your choice. Tweets or doors.
  4. Jun 22, 2024 at 3:57 PM
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    Yes, its worth it, if you get good speakers. The factory speakers are shit. I got some cheap chinese made Rockford Fosgates from a friend and sound clarity improved 10 fold over the factory speakers. You will need mounting adapters
  5. Jun 22, 2024 at 4:04 PM
    planetbuster
    planetbuster Well-Known Member
    San Diego
    2014 DCSB TRD OR Lifted+supercharged
    if youre gonna get in there, then get in there.. throw some sound mat stuff on the doors at least, you can get kilmat from Amazon and it works, i used it in a couple cars in the past.
  6. Jun 22, 2024 at 4:27 PM
    Plasmech
    Not to ask a stupid question, but does my Access Cab truck have rear speakers? If it does, I don’t see where they are.
    Also, are there factory crossovers in the doors? I have factory component tweets.
  7. Jun 23, 2024 at 12:57 PM
    Plasmech
    By setting the fader to -15, I was able to find the rear speakers. They are in the headliner. Interestingly, Crutchfield’s Master Sheet shows them in the rear Access Cab doors and mentions nothing about the headliner.
    I’m guessing the rears are no fun to change and probably not worth it.
