Is It Worth It to Lift my Non-TRD 4 Cyl Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jcman01, Aug 20, 2014.
  1. Aug 20, 2014 at 4:44 PM
    jcman01
    jcman01 [OP] Well-Known Member
    Buck
    Colorado
    2015 Offroad, 6-manual, Blue Ribbon Metallic
    I have a 4WD, 4 Cyl, 5 sp manual Tacoma Access Cab. Even though it is 4WD, it is not "TRD". I spend time in Colorado, and find myself in situations where are few inches (don't go there :p) of lift would be helpful.
    Is it worth lifting a relatively low-end truck like this, or should I upgrade to something more capable before I do?
    Weston Case likes this.
  2. Aug 20, 2014 at 4:45 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Completely your choice. If you have the funds and want a lift go for it. Figure out what lift best meets your needs though.
  3. Aug 20, 2014 at 4:48 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Go for it.
  4. Aug 20, 2014 at 4:48 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Lifting TRD makes less sense than lifting non TRD. Go for it
  5. Aug 20, 2014 at 5:53 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Heck yea. I had a 2002 Reg. cab 4cyl 4x4 non-trd. Lifted, big ole tires & re-geared. Make it your own rig. Just because it's not TRD and 6cyl, doesn't mean it can't be badass.
  6. Aug 20, 2014 at 5:57 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Do it you'll love it. 3 inch ome with 285's 2.7 5 speed 4x4. It settled down to about 2.5 inches with the sliders and a ifs skid.
  7. Aug 20, 2014 at 6:02 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    If it's a 4x4, absolutely.
  8. Aug 20, 2014 at 6:27 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    What tires are you currently running? How much $ do you have to spend?
    David
  9. Aug 20, 2014 at 6:29 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    This!
  10. Aug 20, 2014 at 6:31 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Yes! With the low range box power shouldnt be an issue offroad. A set of shocks will give you a better ride, more clearance and the room to fit some bigger tires.
  11. Aug 20, 2014 at 6:39 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    For every feature in the TRD (except maybe the sport seats) that your truck doesn't have, there exists a more capable aftermarket alternative. By all means, upgrade as your budget permits.
  12. Aug 20, 2014 at 7:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you NEED the extra "help" clearance then yes, it is absolutely worth it.
    If you don't NEED the extra " help" and can still make it past the obstacle in your path, then you'll need figure out what the value is to you.
    I've owned and lifted 3 different trucks. None of which I need to lift.
    I just did it for looks, like 95% of people with lifted trucks.
    That being said, I have owned stock trucks that need clearance and didn't have it. Wrong truck in the wrong place and the wrong time.
    But that's called life I guess?
    I still vote YES, it shouldn't hurt anything.
  13. Aug 20, 2014 at 7:25 PM
    TnShooter
    Deogee
    STOCK
    This is very true.
  14. Aug 20, 2014 at 7:28 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Yes lift it.
    No don't "upgrade"
  15. Aug 20, 2014 at 8:18 PM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    Op, just in case you weren't aware of it already Non-TRD = Professional use, so yes it is totally worth it.
    You only need lockers, A-Trac, Traction nannies, if you are a novice to wheeling, and want the truck to do it all for you. Watch, the 2018 Tacoma TRD-Offroad-Pro Edition will have a CVT transmission and Hybrid dirve.
    My first truck had a 22RE, had a lever for 4-Hi & 4-Lo, and you had to get out and manually lock the hubs. I will be dammed if I couldn't take that truck further and harder than most of these TRD Offroad versions today.
    *Disclaimer* TW please don't take my post serious, I'm kidding.
  16. Aug 20, 2014 at 8:26 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    This made me laugh :rofl:
  17. Aug 20, 2014 at 9:49 PM
    weezer
    weezer Well-Known Member
    southeast
    tacoma 4x4
    Bilstein 5100 shocks, OME lifting springs, Ivan Stewart 16x8 wheels, AT tires
    yeah lift it. trd doesn't mean anything. a 4x4 is a 4x4. you can mod it to be better than a trd if you wanted to.
  18. Aug 20, 2014 at 9:50 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Except for the whole 4cyl thing , lol
  19. Aug 20, 2014 at 9:53 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    That's why I didn't lift my I4. It was an I4 - no power. So I got a factory lifted Baja V6.
    Glad I did instead of sinking money into the I4.
