Is it worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bloggerstomper, Oct 27, 2023.
  1. Oct 27, 2023 at 10:25 AM
    bloggerstomper
    bloggerstomper [OP] Well-Known Member
    CA
    Crumpy
    Hi all!
    I recently discovered that both my front axles have leaky boots and the grease is making quite the mess.
    I got quoted $918 to replace both axles and I just wanted to see what people thought about rebooting both axles myself.
    The axles are original from 2006, is it better to just get brand new ones or reboot them and use the old ones?
    Any opinions appreciated!
    Thanks!
  2. Oct 27, 2023 at 10:29 AM
    Tenmile Tacoma
    Tenmile Tacoma IG: tenmile_tacoma
    Nate
    Colorado
    2016 DCLB TRD Sport 4x4
    F&R locked on 33s
    For peace of mind, I'd probably just replace them given they're the OGs from 2006. There could be damage to the CVs given the boots were open to dirt & other elements and/or ran low on grease and wore out even more.
    If you check out some YouTube videos, have some common tools, and good workspace, you could replace them yourself at home, but fully recognize that sometimes it's just easier to take it somewhere. I would definitely recommend replaces w/ OEM axles. You never know what you're getting w/ aftermarket parts.
  3. Oct 27, 2023 at 10:33 AM
    bloggerstomper
    CA
    Crumpy
    I usually do my own repairs at home but lately I've been feeling quite lazy about it. I might just bite the bullet...
    And absolutely, I only want OEM for repair on most systems!
    thank you!
  4. Oct 27, 2023 at 10:36 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    If they're just leaking and not clicking you can reboot them yourself with OEM boots for about $60 and <2 hours of your time (unless the price of boots went way up since I last checked).
  5. Oct 27, 2023 at 10:36 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  6. Oct 27, 2023 at 10:38 AM
    bloggerstomper
    CA
    Crumpy
    they are not clicking yet, and usually my two hour jobs turn out to be a whole day ordeal...
    and reman sounds good! Althought it seems quite cheap to be both axles!
    Bivouac likes this.
  7. Oct 27, 2023 at 10:40 AM
    TnShooter
    Deogee
    STOCK
    That’s the price for one axle.
    I’d call before you order.
    It’s 50/50 whether they are actually in stock.
    They sell out quick. Copy the part # and check around.:thumbsup:
  8. Oct 27, 2023 at 11:19 AM
    bloggerstomper
    CA
    Crumpy
    I called and the part is discontinued.
    I might just reboot them myself, it seems pretty straightforward... but then again when do I ever have the time lol
    TnShooter[QUOTED] likes this.
  9. Oct 27, 2023 at 12:46 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Definitely can happen like that. Depends on your luck and the steps taken to repair. I can usually reboot an axle while it's still on a vehicle without pulling it from the trans. Usually needs lock ring pliers but after that it's pretty easy. Haven't done them on a 2g but it looks like there's a decent amount of room to do it without removing on my 3g and I know they're similar. I'm pretty sure they're the same axles too.
  10. Oct 27, 2023 at 12:51 PM
    TnShooter
    Deogee
    STOCK
    They are the same axles for both the 2nd and 3rd Gen trucks. :thumbsup:
    Speed Freek and drizzoh[QUOTED] like this.
  11. Oct 27, 2023 at 1:56 PM
    tyjoja
    tyjoja Well-Known Member
    Oregon
    2008 off road trd, Rugged Trail
    lift
    I rebooted my stock ones that were leaking couple of years ago... never tried anything like that b4 but fairly handy... first side was 3 hours second half that much. I carefully pried mine out of diff with crow bar, careful to only to only pry back out towards the wheel, otherwise you can mess up the diff seal... and pry and rotate, pry and rotate. then put the new boot kit on and greased, and clamped... which a couple of the clamps didn't stay and ended up using some nice radiator clamps, tightening till i was afraid they'd break, and no problems since. there's a nice step by step here on TW and watch a couple ytube's when i put back in the diffs, line up the splines like they tell you and kind held with my hands and a knee and hammered from the end and they popped back in. I'd do it again, good luck.
  12. Oct 27, 2023 at 4:42 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Check cvj axles they have reman factory axles.
  13. Oct 27, 2023 at 4:56 PM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    How many miles and do you know how long the boots have been leaking? If you think it has been a few months, then I would lean towards replacement rather than just re-boot. The joints will have to cleaned and re-packed at a minimum as there is probably contamination in there now. How big is the mess? If none of it looks fresh, there's probably not a lot of grease left in the boots/joints. The bigger the mess under there from grease flying everywhere, the longer the time is since it started. I'm asking because of the old: "age vs mileage" consideration. Eighteen years is a long working time regardless of mileage.
  14. Oct 29, 2023 at 9:27 AM
    bloggerstomper
    CA
    Crumpy
    I noticed on the passenger side a couple months ago but it was a small leak. The one on the driver side I discovered soonish
  15. Oct 29, 2023 at 10:11 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    What part of CA are you at? We have a trusty mechanic down here in San Diego area who is a TW member and Toyota trained. I had excessive play on driver side. I provided the parts and he replaced the needle bearing and CV shaft. I went with Cardone heavy duty. It has less than 10K but I’ve off-roaded and it is holding up well thus far. Like you, I could have done it, but felt lazy also, having to get the right tool for the needle bearing and fighting the CV to come out.
  16. Oct 29, 2023 at 10:43 AM
    bloggerstomper
    CA
    Crumpy
    I’m in Santa Barbara, but I have friends down in SD, so it’s not out of the realm of possibilities for me to get it done down there
  17. Oct 29, 2023 at 1:09 PM
    TacoTuesday1
    SD CA
    A properly designed CV axle can last a million miles when rebooted every ~100k which is standard maintenance.
    There is no "could be damaged". It is pass or fail.
    It is either worn out, damaged, and clicking, or it is not.
    OP has stated some grease leaked out. He did not take them apart, dunk them into a barrel of sand and shattered glass, throw them at a wall, and then put it in the truck.
    It is not hard to reboot an axle. It's significantly cheaper, and routine maintenance. If you were performing maintenance, you'd be rebooting them regardless of whether or not there's a crack or leak. The boots are rubber. They have a service life.
    While you are in there, you can put red longer CVJ boots to handle mods like articulation from lift.
  18. Oct 29, 2023 at 1:12 PM
    Tenmile Tacoma
    Nate
    Colorado
    F&R locked on 33s
    lol
  19. Oct 29, 2023 at 10:36 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Speed Freek likes this.
  20. Oct 29, 2023 at 11:55 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    I’m in port Hueneme. Remans are good, boot kit is good and really messy job but it’s worth it. About 2.5 hours per side. Cheers!
    bloggerstomper[OP] likes this.
