Is it worth paying for dyno time?
Discussion in 'Performance and Tuning' started by NumNutz, Jul 10, 2015.
  1. Jul 10, 2015 at 2:18 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I have a URD MAF Sensor Calibrator that is tuned for my TRD intake and TRD exhaust? I am currently having Doug Thorley LT headers installed with a custom Y-pipe. Is there any point to paying $200 for a new dyno tune?
  2. Jul 10, 2015 at 7:20 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    No gadget suggests fine tuning it via real drive time....... On the street.
  3. Jul 11, 2015 at 5:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Get a driver and watch the map. Datalog and make adjustments .
  4. Jul 11, 2015 at 7:07 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    The CD with the tuning software I got with the calibrator is long gone. Would anyone be willing to loan me their CD?
  5. Jul 12, 2015 at 12:53 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Are the drivers not available from Split Second? They are the manufacturer.
  6. Jul 14, 2015 at 5:28 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    For the software, contact gadget. He will give you an access for download. When you're alone, the best is to data log few run and then analyse the result and produce a map of the corrections you have to do. It would need you few try to correct the trims first and then the AFR at full throttle. For the AFR you will need a gauge. I'm using an innovate OT-1 that can be connect to the OBD port. I connect my boost and AFR gauge to create an MTS chain and run the truck.
  7. Jul 16, 2015 at 12:29 AM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    It's easy to tune, hook your lap top up and tune it section by section... Start with a preloaded map and just add fuel till it feels slower and go back 1 step you will be really close to 12/1...... build a map drive it and try a new map and drive again.... I have my most of my map perfect but I'm still tweaking my part throttle section.... Part throttle power or mpg such a trade off.... You can feel the difference every tenth, so it adjust fast....
    Good luck.....
