Is LT265/70R17 E rated too much? Keep or cancel the order?
Discussion in 'Wheels & Tires' started by tacoma384058, Dec 23, 2022.
  1. Dec 23, 2022 at 11:16 AM
    tacoma384058
    tacoma384058 [OP] Member
    I ordered LT265/70R17 E rated 10PLY Falken Wildpeak AT3w and I’m unsure if I should cancel the order or not? Should I cancel the order and get 265/70R17 SL instead? Looks like the weight difference is 6.4 lbs per tire and the max psi difference is 54 vs 80.
    Or does it not matter? I noticed some people say E is better to have because it’s stronger while others say it’s too much for a Tacoma. I have a Gen3 TRD Sport 4x4 that I’ll be lifting the front 1.1” (3rd notch) using the Bilstein 5100 adjustable shock kit on 17x8.5 0mm wheels. The rear will remain stock height.
    blob:https://www.falkentire.com/61aca0d1-3e37-4366-82f8-af5b3cd24c63
  2. Dec 23, 2022 at 11:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    How you use the truck matters.
    E have more puncture resistance at the expense of weight
    Unneeded weight is never good.
  3. Dec 23, 2022 at 11:19 AM
    Bishop84
    Bishop84 Well-Known Member
    If you offroad often or hit service roads hard, stick with the E's.
    Otherwise the lighter SL's will do you fine.
    I run e's simply because of brutal service roads and my ability to damage sidewalls.
  4. Dec 23, 2022 at 11:21 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    You will notice tires that big and that heavy to have an inertia of their own.
    The steering rack burned out prematurely on my fifth generation 4runner, I’ve always wondered if it was the heavy ass E rated tires and steelies.
