Is Manual trans. worth giving up CC and rear diff. lock ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jdob, Jan 19, 2019.
  1. Jan 21, 2019 at 8:04 AM
    #81
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The purpose of the Clutch Cancel Switch is to get you out of a hairy situation, with the truck off press the switch, put it in 1st gear and ride the starter out. It is my theory that the reason the manuals still have a key instead of push button start is to allow proper use of the Clutch Cancel Switch.
  2. Jan 21, 2019 at 9:44 AM
    #82
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    This sums up the clutch cancel and keyed features perfectly. Only other benefit is that you can pop-start your manual Tacoma if the battery ever runs out. You’re SOL getting your auto to start if the battery dies without a jump start or a portable charger.
    And your theory is a fact. Clutch cancel would be useless without a key ignition.
    stun gun and shakerhood[QUOTED] like this.
  3. Jan 21, 2019 at 9:46 AM
    #83
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    Simple answer for simple question.
    YES!!!
    The fact that you are asking means you want it, better do it sooner than later while dealer will still give you good value trade.
  4. Jan 21, 2019 at 9:50 AM
    #84
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Why? Its super easy to get a Canadian citizenship. The test has 2 questions
    "Do you want to be a Canadian citizen?"
    'Yes"
    "Really"
    'Yes'
  5. Jan 21, 2019 at 10:47 AM
    #85
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Yes. I thought this was fact already.
    GillyLink and shakerhood like this.
  6. Jan 21, 2019 at 10:59 AM
    #86
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    OP unfortunately TRDOR 6MT w/ 6' bed is THE unicorn now. Have you, or anyone for that matter, looked into getting one from :canada:?
    There is always the *chance* of a :canada: 3'rd gen in this configuration being found at a US dealer taken in on trade as well.
    Otherwise you might just be better off looking for a 2'nd gen TRDOR 6MT w/ 6' bed.
    FWIW I feel the 6’ bed is the bare minimum on any truck. I wouldn’t be able to lay down, put my skis in the back of or haul this bad bitch with a short bed. That alone is reason enough not to settle for less.
    SilverBulletII likes this.
  7. Jan 21, 2019 at 11:39 AM
    #87
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    Will gfc let you switch your order from 5’ to 6’ bed?
  8. Jan 21, 2019 at 1:22 PM
    #88
    GillyLink
    GillyLink Well-Known Member
    2018 Cement TRD Off-road DCSB AT
    Still stock completely capable!
    Yea pretty much true! Lol I think since Trudeau took over you don’t even need to answer those question anymore.
    Wixo[QUOTED] likes this.
  9. Jan 21, 2019 at 1:26 PM
    #89
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Why would you get a sport? It's no better than the SR5, just more expensive.
    Or do you have to go to the TRD trim now to get the standard trans?
    FYI, if you decide on second gen don't get the standard trans. They suck! It's the exact opposite of third gens where standard seems to be we're it's at!
    GillyLink likes this.
  10. Jan 21, 2019 at 1:29 PM
    #90
    shakerhood
    Southern Ohio
    The only Manuals available today are sport, Off Road, or Pro.
  11. Jan 21, 2019 at 1:30 PM
    #91
    TireFire
    Olympic Peninsula
    Wow, that's BS! I thought you could at least get the no frills 4bangers with a standard
    shakerhood[QUOTED] likes this.
  12. Jan 21, 2019 at 1:31 PM
    #92
    shakerhood
    Southern Ohio
    The SR 4 Cylinder Manual ended after 2017.
    CygnusX191 and GillyLink like this.
  13. Jan 21, 2019 at 1:32 PM
    #93
    TireFire
    Olympic Peninsula
    So then the OP could get a PRO with stick shift as an access cab?
  14. Jan 21, 2019 at 1:34 PM
    #94
    shakerhood
    Southern Ohio
    No, the Pro does not come in Access Cab configurations
  15. Jan 21, 2019 at 1:35 PM
    #95
    TireFire
    Olympic Peninsula
    :annoyed::pout:
  16. Jan 21, 2019 at 1:49 PM
    #96
    stun gun
    Aaronski
    Tacomas.
    Agreed.
    GillyLink and shakerhood[QUOTED] like this.
  17. Jan 21, 2019 at 1:51 PM
    #97
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    If you wanted a locker in the rear you could always get an ARB later.
    stun gun likes this.
  18. Jan 21, 2019 at 2:03 PM
    #98
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    You sure you know what you are talking about with the clutch start cancel???
    https://youtu.be/pPdzlNE-klo
  19. Jan 21, 2019 at 3:29 PM
    #99
    jdob
    jdob [OP] Well-Known Member
    jeremy
    Mandeville, LA
    19 DCSBOR MT
    Yea, and the only access cab manual is a sport. :der:
    CygnusX191 likes this.
  20. Jan 21, 2019 at 3:31 PM
    #100
    jdob
    jeremy
    Mandeville, LA
    19 DCSBOR MT
    yes, its not being built till august.
