Is moog lower control arms the best way to go
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glamis, Aug 15, 2018.
  1. Aug 15, 2018 at 9:13 AM
    Glamis
    Glamis [OP] date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    I have popping in my tie rods "the inner one left side" also my lower control arms bushing are looking bad also. I'm thinking of getting all moog parts. Is this the best way to go.
    MOOG RK621293 Control Arm with Ball Joint
    MOOG RK621294 Control Arm with Ball Joint
    Moog EV800529 Tie Rod End
    Moog ES80895 Tie Rod End
  2. Aug 15, 2018 at 9:29 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Moog is not even as good as they used too be,after they sold out.
    GSHEP4 likes this.
  3. Aug 15, 2018 at 9:36 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I need to buy these same parts too. I don't have a 2nd gen but for the 1st gen, Rock Auto lists Moog LCAs as the economy line. I decided to go with Mevotech LCAs & Moog TREs since Moog TREs are geasable. That is unless anyone tells me otherwise about Mevotech.
  4. Aug 15, 2018 at 9:42 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    i used Moog on my FJC lower ball joints. I pressed the oem ones out, installed the Moogs. i like they have a zerk fitting for maintenance. and a low profile grease boot rather than the oem fat one that is susceptible to getting poked/tearing. So far im pleased with them. should be identical for second gen tacos.
  5. Aug 15, 2018 at 9:48 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Lower ball joints are a different story. The argument is that factory Toyota lower ball joints use a liner for the ball that none of the after market ones use & therefore doesn't require periodical lubing. The Moogs don't have this type of lining & are not even machined well inside so they require the constant lubing.
    I had no idea when I replaced my LBJs, I went with Moogs cause I thought the greasable feature was a plus. Had them for years now & they're still doing fine but I'll go back to the OEM on the next set. If the truck never sees offroad & is stock height, it may not matter much.
  6. Aug 15, 2018 at 9:52 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    interesting.
  7. Aug 15, 2018 at 9:55 AM
    Glamis
    im looking to get 3 more years out of the truck as of now. mostly a street truck and some light towing 3,500 trailer.
  8. Aug 15, 2018 at 11:18 AM
    ColoTacoPrerunner06
    ColoTacoPrerunner06 Truck of my dreams
    Speedway Blue 06 Prerunner built like I like it.
    5.5 lift front 4 rear on 33s with an endless amount more work to do
    I work in the aftermaket repair industry. Moog has an economy line that is Chinese junk and their better line. That being said I have been having really good luck with the mevotech heavy duty line.
  9. Aug 15, 2018 at 11:29 AM
    Breadbox
    Breadbox Well-Known Member
    Northern VA
    TRD Sport, MT, 4X4, SR5
    4" lift; ION and Camburg, custom progressive rear springs no overload; ION Bumps; Roadmaster Active suspension, quick disconnect sways front and rear, Nitro 4.10s, Detroit TrueTrac, ECGS bushing, Aluminess Rear bumper w/swing outs and flood lights, 285/70/17 on ProComp Steelies, Kenwood NAV, URD Short Shifter, CB, front rally bar with LED flows and fogs, RockSliders, FWC.
    I had the alignment bolt freeze up issue on stock lower arms.
    To make my life easy I went with Moog lowers. I off road frequently and over 2 years have had no issues with the Moogs.
    I also installed with the Moog grease-able alignment bolts. So far so good, no re-freeze up there and no issues.
  10. Aug 15, 2018 at 11:35 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Moog will be fine for this
  11. Aug 15, 2018 at 11:47 AM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    I would steer clear of Rock Auto. I recently learned that their customer service sucks and you can’t even call them!!!! Everything is done over online “chat” or email.
    Running Board Man and Norton like this.
  12. Aug 15, 2018 at 11:50 AM
    anthony250f
    Anthony
    San Diego, CA
    Yup!! Just had to return something from there and it was a nightmare
    Pork Chopper[QUOTED] and Slamuel like this.
  13. Aug 15, 2018 at 11:56 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That's how they are able to get the rock bottom pricing.. by ignoring every return/warranty issue! The parts pipeline is one direction only
  14. Aug 15, 2018 at 12:10 PM
    anthony250f
    Anthony
    San Diego, CA
    I was able to return after sending an email thankfully
    b_r_o[QUOTED] likes this.
  15. Aug 15, 2018 at 4:30 PM
    Glamis
  16. Aug 15, 2018 at 5:18 PM
    Slamuel
    Slamuel Well-Known Member
    Sam
    Tacoma
    Use OEM.
    Rebuild your current ones. It doesn’t take very long at all. I am prepared to do a write up just haven’t gotten around to it yet. If you go this route I’ll show you how!
  17. Aug 15, 2018 at 5:19 PM
    Slamuel
    Sam
    Tacoma
    I lol’d at this:rofl:
    Running Board Man likes this.
  18. Aug 15, 2018 at 5:28 PM
    vertrx7
    vertrx7 Well-Known Member
    Rolf
    I was looking at the same issue as the alignment bolts were frozen and the a-arms cannot be removed without cutting the bolts. Everything is rusted. Researched the Moog parts and did a lot of reading. There is more bad than good, so I decided to go with used LCA's. Had a hell of a time finding a rustfree set. I bought the new alignment bolts at the dealer since I was reading some of the issues with the aftermarket bolts as well.
    All that to say that I ordered a set out of California. They are literally like new. No rust, the bushings look fine, shipping across the country was $15 each and the cherry on top is that they provided all the alignment bolts...yep, those really expensive ones I bought new, came with the LCA's. The only rub is that they cost $85.00 each though I looked real hard for cheaper ones.
  19. Aug 15, 2018 at 5:58 PM
    Glamis
    I'm in the Peoples Republic of California. Rust in not an problem 90% of the time.
  20. Aug 15, 2018 at 8:58 PM
    Syphrum
    Syphrum Well-Known Member
    Thousand Oaks
    2006 DCLB
    BFF Hybrid Front Bumper BFF High Clearance Rear Bumper - soon HomerTaco Grill BAMF Sliders CMC - soon Bilstein 6112/5160 Dakar Leaf Pack - medium Total Chaos UCAs OEM LCAs - thanks @gunny1005 ! Retrofit Smoked Projector Fronts/LED Rears - soon - thanks @LSC15 ! WeatherTech Floormats Sony Touch Receiver
    Send @gunny1005 a message. Cheapest way to get oem parts. Ive placed several orders with him. Awesome guy!
    Not worth rebuilding the LCAs. Dont mess around with cheapo aftermarket crap either. Best case if u do, u'll be doing this again soon. Worst, if u wheel then ur going to be f'd at some point when they fail.
    Recommend to replace all of the adjustment hardware, bolts n cotter pins as well. He will help u with the parts. Rent tie rod puller for free (have to put a deposit) from national auto parts chains
    AKg42 and Pork Chopper like this.
