Is My Alignment or New Parts Causing Heavy Steering?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awoit, Jun 4, 2023.
  1. Jun 4, 2023 at 7:31 PM
    awoit
    awoit [OP] Well-Known Member
    CA
    08 TRD, SR5
    Just installed:
    - Freedom OffRoad UCA
    - new balljoints and whiteline bushings in OEM LCA
    - inner/outer tie rods
    - new sway bar end links
    Current Alignment specs (Left // Right)
    Caster: 3.5 // 3.5
    Camber: .1 // .1
    Toe: 0 // 0
    Currently running Toytec 3" lift (coils in front AAL in rear) with Bilstein 5100s
    After digging through a lot of threads there doesn't seem to be any exact/particular alignment that is 100% agreed upon, but it seems like those with lift kits (and the capability when running aftermarket UCA) tend to want the caster above the recommended value, so I insisted doing the same when discussing the alignment with the shop I went to.
    I've read everything from 4, to as high as possible, and am wondering if the heavy steering (a little more force required when turning than normal/before, and the wheel doesn't want to return after a turn when going back to a straight away as easy) is likely due to all these brand new parts or the caster being higher than recommended by factory.
    I've also read too much caster and prematurely cause wear (which is why I didn't op for 4+).
    Really just trying to determine if I should head back to the shop and eat another alignment cost and get it down to fall within factory spec (Caster 1.3-2.8), or give all the new parts some time to loosen up a little. The last thing I want is to wreck my steering equipment following all these parts I just bought =)
  2. Jun 4, 2023 at 8:14 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    And everything was torqued down when the truck was sitting on its own weight, correct?
  3. Jun 4, 2023 at 8:22 PM
    awoit
    CA
    08 TRD, SR5
    I assume so - The mechanic that did the alignment helped me press in my bushings/balljoints before I put everything back together and visited the shop he works at.. He was the one to remind me about doing so (though I'd planned to do that in the first place). I doubt he'd forget to do that since he was insistent about me doing it when I left his house with my LCAs..
  4. Jun 4, 2023 at 8:30 PM
    eon_blue
    Azusa, CA
    I'm not sure what your caster setting was before, but higher caster numbers (3°+) will give the steering a different feel, alignment wise.
    The wheel not wanting to return to center is something I experienced when I tightened the rack guide too tight on the steering rack, but that shouldn't have been adjusted given the work you had done
    I'm guessing it's because your caster numbers are higher than they were before. Most aftermarket UCAs automatically give you more caster
  5. Jun 4, 2023 at 8:32 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    New ball joints tend to be a little tight. They also have a direct impact to what you feel in the steering wheel. I’ve had the same experience with tight steering after installing new parts. Give it a month and it should ease up a bit.
    eon_blue and awoit[OP] like this.
  6. Jun 4, 2023 at 9:10 PM
    Bishop84
    Bishop84 Well-Known Member
    Toe is too low, but nothing crazy. Should be 0.6 each at least, we usually bump higher for bigger tires.
    But this is definitely a byproduct of high caster and new components. Nothing to worry about.
    eon_blue likes this.
