Is my battery dead or am I going insane?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by riplipper, Dec 14, 2023.
  1. Mar 3, 2024 at 6:30 AM
    #61
    Clearwater Bill
    Billy
    Largo Florida
    Connect + first, then - and you'll have no spark. Allowing that arc to happen has potential to damage the ECU. It's rare, but it happens.
    shakerhood likes this.
  2. Mar 3, 2024 at 6:35 AM
    #62
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Man I wish I was in the battery bussiness. Wonder how many perfectly good batteries are in the recycle bin. Don't know why but for some reason I looked at the date stamp on my diesel tractor battery yesterday it's 15 years old! The one in the Tacoma is 12 years old. If you gat a weak crank and ever thing else is ok replace it because you just did a battery check.
  3. Mar 3, 2024 at 6:37 AM
    #63
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Once a lead acid goes flat completely, it's almost always time to give it the old heave ho. Sure, keep it around the house in something else that isn't a big deal to jump but in a vehicle, nope.
  4. Mar 3, 2024 at 9:38 AM
    #64
    tiap
    tiap Active Member
    If you don't drive it for extended periods, connect a battery maintainer, makes batteries last a long as possible.
    This one charges, maintains and desulphates wet and agm batteries.
    Have used it for years.
    CTEK MXS 5.0
    Canadian Caber and 3JOH22A like this.
  5. Mar 3, 2024 at 5:22 PM
    #65
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I get a spark when connecting the - after the + is connected. It's just a little spark but it's a spark.
  6. Mar 3, 2024 at 6:38 PM
    #66
    tiap
    tiap Active Member
    The purpose of connecting the positive first is to eliminate a spark at the battery where there may be explosive gases present.
    Connect the pos+ to the pos+ terminal and then connect the neg- to the engine block or similar good ground that is away from any potential battery gases. Any sparks created won't matter.
  7. Mar 3, 2024 at 7:31 PM
    #67
    CaptainBart45
    Bart
    Work in progress...
    Now that I understand, thank you.
  8. Mar 4, 2024 at 12:31 PM
    #68
    nds0000
    nds0000 Well-Known Member
    … but one can conserve the battery that it lasts longer. Putting it regularly on a batter minder, keeping it fully charged and don’t get it drained, keep it in a decent temp range, … That can give your battery some more lifetime. Plus the 80Ah, 582CCA is a pretty weak fit for the 2023 Tacoma. A 610+CCA would be more appropriate. And keep in mind the electronics are never really off. Some are constantly operating-how else would a fob and GBS work anytime? Or the GPS etc. it is a lot to it… And then we have of course all kinds of additional gadgets sucking lifetime out of the battery.
    Well maintained even modern batteries could last 5+ years with no issues.
