Is my catalytic converter bad already?
Discussion in 'Performance and Tuning' started by ToyotaNovice, Oct 9, 2011.
  1. Oct 9, 2011 at 12:37 PM
    ToyotaNovice
    ToyotaNovice [OP] Active Member
    Rocky
    Utah
    13 Tacoma Double Cab
    I only have 64,000 miles on my 2001 1st generation. My check engine light is coming on with a P040 code. My catalytic converters couldn't be bad already could they?
    I have an AFE ProDry drop in filter, so I don't think my mass air flow sensor is dirty (I already cleaned it off just in case). Dealership wants thousands to replace the two cats and oxygen sensors. Muffler shop wants $900+.
    I'm still having a hard time believing it's the catalytic converter. Has anybody else had this problem?
    Suggestions?
  2. Oct 9, 2011 at 1:06 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    So which code is it? P0040 or P0440?
    Info from http://www.obd-codes.com/trouble_codes/
    P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
    P0440 Evaporative Emission Control System Malfunction
  3. Oct 9, 2011 at 2:47 PM
    ToyotaNovice
    Rocky
    Utah
    Oops, I forgot a two. The code is P0420. Thanks!
  4. Oct 9, 2011 at 2:49 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Might be cheaper to try an 02 sensor first?
  5. Oct 9, 2011 at 2:53 PM
    KenLyns
    Belly of the Beast
    According to the same web site:
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    Some suggested steps for troubleshooting a P0420 error code include:
    Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required.
    Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady).
    Inspect the downstream heated oxygen sensor (HO2), replace if necessary
    Replace the catalytic converter
    According to this list, the worst-case scenario would be to replace a single front cat on bank 1. There is no sensor monitoring the performance of the rear cats.
  6. Oct 9, 2011 at 2:58 PM
    s1nner
    s1nner Well-Known Member
    michael
    chesapeake,va
    06 trd offroad
    6" fabtech suspension lift, 3" body lift, 36x15.5 mtz on mt classic II wheels with red fake beadlock, shaved tailgate handle, custom paint, trd sport hood
    i just went through this on my 2006. federal emissions laws say toyota has to cover cats up to 100000 miles. i just had one put on at 60000, and im about to go for the second cause the code came back up for the other bank. same code description you have.
  7. Oct 9, 2011 at 3:05 PM
    KenLyns
    Belly of the Beast
  8. Oct 9, 2011 at 3:14 PM
    s1nner
    michael
    chesapeake,va
    06 trd offroad
  9. Oct 9, 2011 at 5:18 PM
    ToyotaNovice
    Rocky
    Utah
    Thanks, this helps. I'll check out the O2 sensors and see what that does. I've already checked for exhaust leaks. Looks like changing the cats is last resort if the other things don't work.
    I hate seeing that stupid check engine light every day. Looking forward to getting rid of it.
  10. Oct 9, 2011 at 5:22 PM
    ToyotaNovice
    Rocky
    Utah
    How many miles does your truck have? You're on to your second cat replacement already? That sucks! From what I've looked into it is not a cheap process that's why I'm trying other options first. Did you replace both cats your first go around?
  11. Oct 9, 2011 at 5:58 PM
    s1nner
    michael
    chesapeake,va
    06 trd offroad
    well it was the dealers call. the lights were sorta random, i would clear the code and it would last a while then come back. when i took it to toyota they only replaced the left upstream cat, now its the right one. they paid for the whole thing. it was a one day repair but it took them like 2 weeks to get the part. the only thing that sucked is they wouldn't give me a car to drive for the day. i would say check into it, never hurts to ask hopefully you're still covered
  12. Oct 9, 2011 at 6:06 PM
    s1nner
    michael
    chesapeake,va
    06 trd offroad
    oh and i have 62000 now and my first one was at 55000
  13. Oct 10, 2011 at 5:27 PM
    wger06
    wger06 New Member
    Wayne
    New Jersey
    01 TRD SR5
    I just had the exact same problem on my 01 tacoma. The 1st mechanic told me it could be as much as $3000, he was going to change both cats and both o2 sensors. The 2nd mechanic told me about $1000. I finally decided to try it myself. Turns out only 1 o2 sensor was bad, the upsteam one. The whole job took a day and cost $100. If it turns out you have the same problem, make sure you buy the oem o2 sensor. Denso is the only one that works, I read that on this forum somewhere and it saved me from having to do it twice. Good luck I hope this was helpful
  14. Oct 10, 2011 at 7:02 PM
    ToyotaNovice
    Rocky
    Utah
    This is perfect. Thanks!! I was told the same thing by mechanics... Almost down to the exact dollar amount. My truck was like s1nners above where I would turn off the light and it would come back on in a few weeks; not immediately.
    I'm gonna start by trying to change the sensors. Thanks again.
  15. Oct 10, 2011 at 7:05 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    my truck did the same thing, I reset it with the scangage and it hasn't come on since. this was 2 years ago:confused:
    edit: I had 150k at the time, Im at 174k now.
  16. Oct 10, 2011 at 7:11 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    wow mine has 190??? miles and i have yet to replace my cat, but next year gotta replace it or wont pass smog stupid cali law
  17. Oct 10, 2011 at 7:46 PM
    wger06
    wger06 New Member
    Wayne
    New Jersey
    01 TRD SR5
    Yea that's how mine started, I would reset the light and it would stay off for a while. The time in between the light coming back on kept getting shorter and shorter until eventually it would come back immediatedly. That went on for about year.
  18. Oct 10, 2011 at 8:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    lol if mine ever go bad ill probably just get the URD O2 sensor sim and forget about it. no inspections here:cool:
  19. Dec 3, 2017 at 2:37 PM
    Iceman67
    Iceman67 New Member
    Darren
    2006 V6 tacoma
    Just place a peice if black electrical tape nicely over the dash engine light and Bam , problem solved . I changed all 4 cats and sensers and within a months light came back on with same code so a friend did the same and kinda laughed and say do same as me and use the tape trick . So I did last year on my 2006 and haven’t seen the engine light sense lol I just use my own computer and check truck every six months to make so no other issues have taken place . Tape works great and so does my beautiful tacoma :) 2K was wasted !!
  20. Dec 3, 2017 at 2:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    Well, you just posted in a thread that ended over 6 years ago.
    And some states have emissions testing, which the 'black tape trick' won't help pass.
