Is my clutch starting to go?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JManders, May 9, 2010.
  1. May 9, 2010 at 7:55 AM
    JManders
    JManders [OP] Assistant to the Regional Manager
    Jon
    Fort Collins, CO
    2k Black SR5 TRD romper
    Warn driving lights, Aries brush guard, tow package, removed mudflaps, Uniden CB radio, Firestik antenna, PA horn, deck plate mod, K&N air filter, blacked-out badges, Hella SuperTone horns, 20% tint all around, fog light mod
    I've begun to notice with my 2000 that when I shift into 4th gear, on my manual, it goes into gear just fine then revs up to almost redline after a second, as if the clutch is fully engaged until i let my foot off the gas and let it catch again. It's as if it slips out of gear.
    Does this mean my clutch is starting to go? It only does this when it's in 4th gear however.
    Any help would be appreciated.
  2. May 9, 2010 at 7:56 AM
    JManders
    Jon
    Fort Collins, CO
  3. May 9, 2010 at 7:59 AM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    it is starting to go, same thing happend with my 99. Clutches are expensive and difficult to replace. take it to a transmission shop and have then do the job
  4. May 9, 2010 at 8:15 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Yes, it sounds like it's time for a new clutch. It will probably last for quite a while if you drive normally, mine slipped for 30,000 before it burned up hotrodding.
    A clutch is maybe $150 online, and doing it yourself is pretty easy if you have a hoist. I did mine at a buddy's in one day and under $200 total. A shop will want $800 to do it easy.
  5. May 9, 2010 at 8:19 AM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    I agree with the ease of replacing. I know its a different gen, but my dad and I replaced my clutch in 3 hours and it was about $180 from the dealership.
    If you know what to do, I'd say replace it yourself, maybe ask a friend to help.
  6. May 9, 2010 at 9:58 AM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    Is the clutch getting harder and harder to push? Cause that's also a good sign that its on the way out
  7. May 9, 2010 at 10:10 AM
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    That's how mine started two months ago and now its getting a new clutch put in.
  8. May 9, 2010 at 3:20 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I know this doesn't help you much, but a sign that a clutch is going is usually most seen in 1st gear, in addition to the friction point being close to the top of the pedal. When its worn down, whats happening is the clutch pad doesn't have as much material to fully engage against the flywheel so it slips when there's more stress on it.
    As far as your problem goes, I'd probably have to lean more towards a transmission problem. Does it do it from 3 to 4 as well as from 5 to 4?
    I dont know much at trans, but there is a syncro that helps the gears align between shifting. Each gear should have two syncros, one for up shifting and one for down shifting. That's about the limit of my knowledge of it. Usually a broken syncro will cause gear grinding though, so maybe something inside is stuck engaged or maybe isn't where its supposed to be so it doesn't disengage properly. Not really sure on the intracacies of a trans to that extent.
    I have no idea how the syncros actually do what they're supposed to or what happens when one has failed, but it is the only component I could think of that relates to shifting from one gear to another that would only affect one gear.
  9. May 9, 2010 at 3:30 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    usually you notice the clutch slipping in the higher gears first. 4th and 5th is what mine was slipping in when I did my clutch job. When I was on the freeway in 4th or 5th if I stepped oin the gas anymore that a light touch it would rev way up. hope that helps a little
  10. May 9, 2010 at 3:31 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Sounds like the clutch to me too.
  11. May 9, 2010 at 3:33 PM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    Yeah man... that's how mine went. Dylandercole knows, we went through the same process about thanksgiving time haha
  12. May 9, 2010 at 3:36 PM
    dylandercole
    Dylan
    worst 32 hours of my life
  13. May 9, 2010 at 3:36 PM
    grant22
    grant22 Member
    Grant
    Lake Havasu
    N/A
    If there's 100k to 150k miles on yer clutch and it's doin' what yer sayin', then I'd say clutch (my '92 did the same).
  14. May 9, 2010 at 3:37 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    yes, time for a new clutch
  15. May 9, 2010 at 9:08 PM
    JManders
    Jon
    Fort Collins, CO
    yeah it sometimes does it in 5th but it's not nearly as noticeable. this clutch has to have at least 75k on it.
    I've also noticed it can be pretty rough starting from a dead stop. It shakes and rumbles until I get going then it seems to be ok until I get high rpms in 3rd and then 4th is just brutal.
    How much does a new clutch usually run?
  16. May 9, 2010 at 9:11 PM
    JManders
    Jon
    Fort Collins, CO
    it's not getting any harder to put in I think but it does have a really high catch point and sometimes gets stuck halfway down. I don't think the guy before me replaced the clutch so this bad boy could have 160k on it as far as I know...
  17. May 9, 2010 at 11:08 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    171 if you do it yourself. And I can't believe the clutch only went 75k! They normally go at least 140k
    http://cgi.ebay.com/ebaymotors/AISI...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
  18. May 9, 2010 at 11:18 PM
    JManders
    Jon
    Fort Collins, CO
    well it could have lasted that long, that's just how many miles I've put on it since I bought it. It probably has never been replaced. I don't really have a lot of experience with this kind of stuff but is it straightforward enough to do it?
  19. May 9, 2010 at 11:20 PM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    The original clutch on mine got me to 200k haha, the P.O. was an old guy...
  20. May 9, 2010 at 11:21 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Not very straight forward. I've personally never done it but the hardest part is probably pulling the tranny. You also have to get the flywheel resurfaced so add a few bucks for that.
