Is my CV boot angle OK?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mount Sannine, Mar 15, 2012.
  1. Mar 15, 2012 at 8:21 PM
    Mount Sannine
    Mount Sannine [OP] Well-Known Member
    Mount Sannine
    2000 6cyl 4x4
    Old Man Emu Suspension, ARB Bull Bar, X Dyna Winch, 32x11.5x15 Inch Cooper STT Tire, Pioneer Sound System
    Hello everyone,
    I Installed a spacer over the front OME coilovers, I love the new leveling but I'm concerned about m y CV boot angle.
    Do you think I will be blowing the rubber soon? or is the angle not as bad as I think it is?
    Thanks for your help guys.
  2. Mar 15, 2012 at 8:25 PM
    GreenTaco28
    GreenTaco28 Well-Known Member
    Tyler
    Truckee, CA
    01 4x4 SR5
    ARB bumper-Icon 2.5 ext. travel coilovers with King coils and Total Chaos uca's-hella lights-2 12'' JL Audio subs- 285/75/r16 BFG AT's- Marlin Crawler 1.5 in. wheel spacers- Toytec AAL with 5100's in rear-Flowmaster dual exhaust- Black UWS Toolbox- Bushwacker fender flares- Viper alarm system.
    Doesn't look too bad but if you don't have a diff drop I'd get one. It'll help a bit
  3. Mar 15, 2012 at 8:28 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    The only thing to worry about is premature wear of the cv boots. Sucks when those tear open.
  4. Mar 15, 2012 at 8:29 PM
    Mount Sannine
    Mount Sannine
    2000 6cyl 4x4
    The things that I read about the diff drop are not encouraging me to proceed with it. :S
  5. Mar 15, 2012 at 8:30 PM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    Its a little steep, but not bad. Just keep an eye on the boot wear, Id check it at after each tank of gas, or every 200-300 miles for the first few months. If it is looking ok, then just check it every oil change when you are lying under there anyways.
  6. Mar 15, 2012 at 8:35 PM
    GreenTaco28
    Tyler
    Truckee, CA
    01 4x4 SR5
    Were you reading about 2nd gens? People say it's not worth it for the 2nd gen but for the first gen its usually worth it. I installed mine and have no problems.
  7. Mar 15, 2012 at 8:40 PM
    Mount Sannine
    Mount Sannine
    2000 6cyl 4x4
    No, I was googling some diff drop reviews not specific to first gens.
    But its good to hear that you did not have a problem, cause I will be considering it if I start tearing rubber.
  8. Mar 15, 2012 at 8:41 PM
    Darth_Yota
    Cam-moron
    Somewhere USA
    I have a diff drop on my 2nd gen. No issues.
  9. Mar 15, 2012 at 8:49 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
  10. Mar 15, 2012 at 10:10 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    do you have OME lift coils too on top of that spacer?
    thats lot of lift on stock UCA's and IFS...
    hope you dont bind at full droop. Diff drop is probably a good idea.
  11. Mar 16, 2012 at 4:27 PM
    JRockTaco
    JRockTaco Just some guy
    Sandy Eggo, CA
    '04 4x4 V6 Manual TRD Ext. Cab Lunar Mist
    Donahoe 2.5" coilovers, Camburg UCA, Deaver leaf springs, Bilstein 5100 rear shocks, Elite front plate bumper, Demello Offroad rear bumper & rock sliders, K&N FIPK, Line-X, BAKFlip G2
    I have about the same angle & my boot tore about 2 weeks ago. I'm looking at getting the diff. drop spacers, you may wish to do the same. The spacers are cheaper than the CV boot kits & alot less messy too
  12. Mar 16, 2012 at 4:30 PM
    Manwithoutaplan
    ID
    i heard the diff drops dont do anything :$
  13. Mar 16, 2012 at 4:46 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    on 2nd Gens
  14. Mar 16, 2012 at 5:06 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    What coils you running? Just get 882's and ditch the spacer. Or get a smaller one, like 10 mm or 1/4". The bigger the spacer the sooner the shocks will bottom out before hitting any bump stops.
  15. Mar 16, 2012 at 8:38 PM
    Mount Sannine
    Mount Sannine
    2000 6cyl 4x4
    Guys,
    04 LTtacoma, That is one hell of a lift you’ve got there.
    TacoMX, I don’t think I have anything else other than the Coilovers and the spacer that I have added.
    JRockTaco, I’m thinking about the boot slide mod posted previously in this thread, I’m thinking its simpler than flipping the diff.
    Lonzorizo, I have no Idea which coils I have installed.
    Guys all I know is that after the ARB bumper and the winch installs, the whole front end of the truck went down and I needed to lift it, now I’m reconsidering.
  16. Mar 16, 2012 at 8:44 PM
    TacoMX
    Jonathan
    Deltona, Florida
    like others have said...ditch the spacer and run some 882 coils...that will hold up the ARB bumper.
  17. Mar 16, 2012 at 8:49 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    With the ARB and winch, I'd avoid the spacers and go with OME 886s. The 882s won't do justice with the ARB.
    You'd be better off in the long run.
    I practically have the same set up, and went with heavier coils.
  18. Mar 16, 2012 at 8:50 PM
    OZ-T
    Peter North
    British Columbia
    886's on a first gen ?
  19. Mar 16, 2012 at 8:56 PM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    My Bad, I was thinking 881s
    882s do give the support for some added weight.
    However the 882 have a 500lb rating. I'm running 620lb Eibachs
  20. Mar 16, 2012 at 9:07 PM
    Mount Sannine
    Mount Sannine
    2000 6cyl 4x4
    Ok, say I go with stronger coils,
    with that give me the lift I have now?
    will I have have the same CV boot angle?
    Thanks
