Is my frame bent? Warning Graphic Images
Discussion in '1st Gen. Tacomas (1995-2004)' started by xcmtb83, May 24, 2013.
  1. May 24, 2013 at 4:36 PM
    xcmtb83
    xcmtb83 [OP] Well-Known Member
    Iowa
    As the title says, Is my frame bent? If so how bad? I haven't been able to inspect the vehicle too closely after all of this happened so I am asking for help in determining the severity of things.
    I have the option to buy my truck back and I really want to but I am unsure if it is repairable and if it is how much would it cost just for frame machine time? If I get it back I plan to box the frame and strengthen it back up post frame machine. I am not looking to restore it to the street queen status that it once instead I would like to make it into more of a mild build/work truck/flatbed.
    THE GOOD
    1996 V6 reg cab
    164,000 miles
    5 speed
    Has a meticulous maintenance record
    timing belt, water pump, idlers and tensioner, coolant flush, crankshaft seal, camshaft seals, valve adjustments, plugs, plug wires all within the last 8,000miles
    E-Locker equipped
    Bucket Seats and nice interior
    Stereo system with thunderform enclosure
    33x10.5 tires
    Manual hubs
    Tundra Coils and 5100s
    Fresh OEM boots on CVs
    THE BAD
    Frame looks tweaked in the rear (or is it an optical illusion)
    All-Pro Leaf spring destroyed on driver side from being rear-ended on the side
    Box has a very small ding in it haha
    One window out of the slider is broken
    Passenger fender destroyed
    Possible bent axle housing?
    Possible bent wheel?
    Please give your educated opinion on what I should do. I really dug this truck when it was nice and still do...
  2. May 24, 2013 at 4:40 PM
    Jbbarrette
    Jbbarrette Well-Known Member
    Jay
    Orange County
    2020 TRD Sport, 4X4
    Man, what happened? I'd say no it's not bent.
  3. May 24, 2013 at 4:46 PM
    Mikehole
    Mikehole Well-Known Member
    SF Bay Area
    '12 4x4 Short Bed TRD Off Road
    TRD Supercharger, Toytec 3" Ultimate Lift w/ 285/75/16s and planning on OBA for sometime in the future. Also thinking about the HWMS and a Warn 8000 for it.
    My stupid and uneducated opinion would be that yes, the frame will probably be bent.
    Repairable? I couldn't tell ya. It looks like you could make a wicked LT machine with new fiberglass bedsides and front fenders.
    Back to the frame, if you could sneak under there and snap some upskirt photos of her (showing the frame), then some smarter people than me will probably chime in with their assesments of the situation.
    Sorry to see your truck get smashed. I hope everyone is ok. What happened? Tree fall on it?
  4. May 24, 2013 at 4:50 PM
    xcmtb83
    Iowa
    I was rearended rolling up to a stop sign, rear end swung to the right from the impact (having the drivers side of the rear axle pushed ahead of the passenger side axle made it turn like a forklift) I couldn't correct got pushed 90+degrees, hit a curb, rolled over into a tree which stopped me from rolling more. I am just glad I hit the tree far enough behind the cab so it didn't crush down on me!
  5. May 24, 2013 at 4:51 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    not even one lousy picture of the frame :confused:
    the bed is no doubt fubar...
    But without seeing the frame...
    I'll recommend a frame shop instead of guessing ;)
    once you determine it isn't bent...
    install a flat bed and call it good
  6. May 24, 2013 at 4:55 PM
    xcmtb83
    Iowa
    I know sorry no frame pics...this happened over a month ago and at the time just being around it made me sick so I didn't spend too much time taking pics.
  7. May 24, 2013 at 5:41 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    That thing looks pretty Eff'd. If you could get it super cheap, maybe. Chances are it's going to be expensive to get all back together.
  8. May 24, 2013 at 5:43 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    I wouldn't mess with it imo.
    Hard to say about the frame.
  9. May 24, 2013 at 6:14 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I would "guess yes" ... because the way that the bed is positioned after the crash.
    Even the "bed mounting bolts" did some "pulling & pushing" and that force (energy) had to go somewhere ... :eek:
  10. May 24, 2013 at 6:14 PM
    Madjik_Man
    Colorado Front Range
    Dude.... "NSFW" tags the next time...
    ... please :(
  11. May 24, 2013 at 6:19 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I'm gonna go out on a limb and say the frame is bent. ;)
  12. May 24, 2013 at 6:24 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Even if its not, the other damage is too much to even be cost worthy ha cost me 3500 to get my truck fixed and i only had small dents in the bed, door, and roof
  13. May 24, 2013 at 6:36 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    I would hazard a guess from the pictures and your description of what happened and say that your frame probably is bent. Couldn't know for sure, as we cannot directly see the frame in these pics. Sorry this happened to you man- that's a hefty loss.
  14. May 24, 2013 at 7:50 PM
    xcmtb83
    Iowa
    To return my truck to what it was before is out of the question. I guess I should stress that I only want to make it driveable again. I am not concerned about how pretty it looks. Besides the frame straightening I will be doing all of the remaining work myself to cut costs and I already have replaced the truck so no need to rush the repair. Does this change anyone's opinion? Thanks for all input!
  15. May 24, 2013 at 7:54 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Grab me the rear leafs! :)
  16. May 24, 2013 at 8:08 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I'd get a professional opinion/measurements from a frame shop...
    but it's likely not bent...
    at least not the main spars of the the frame...
    but I'll bet those two "C" channel end rails may need some massaging.
    I only say this after looking closer at your pictures...
    The cab's rocker looks to be level and in line with the suspension ride height.
    Maybe you'll get lucky :)
    I'd keep it if the frame's primary spars aren't fubar
    other then that...
    If the cab is intact... is all you need :D
  17. May 24, 2013 at 8:19 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I would guess it's repairable to at least trail rig status. That is a really sweet truck though. I wasn't aware you could get a reg cab with a v6 and a locker, is that all factory?
  18. May 24, 2013 at 8:21 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    I am sorry about your loss, such a beautiful truck. It was a 96 too :( :( :(
    Glad your ok though
    How much to buy it back? If the frame is bent it still might be worth parting out then..."shiver"....scrapping.
  19. May 25, 2013 at 1:11 AM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    Sorry about your truck......
    Think you can get the mirrors off that silver 2012 that's sitting right beside yours? Lol
  20. May 25, 2013 at 1:16 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I actually wouldn't be surprised if it wasn't bent.
    But impossible to tell in those pics.
    Either way gonna cost a pretty penny to fix it.
    For a toy cut up truck tho..if the frame isn't bad totally be worth it.
