Is my LED dome light still good?
Discussion in 'Lighting' started by austinramsay, Dec 25, 2012.
  1. Dec 25, 2012 at 9:41 AM
    austinramsay
    austinramsay [OP] Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    I was putting it in and the sticky part on back covering all the panel connections was off. I didnt even think about the connections touching anything but they did and it sparked which turned off my clock, radio, and the light. I replaced the blown dome fuse under the hood with the cig 15a fuse, and the radio is good but now the lights not working. Am i gonna have to replace the light or could it be that its not working cause the cig fuse is missing under the dash?
  2. Dec 25, 2012 at 9:49 AM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Do you have a meter to see if there's power to the light?
  3. Dec 25, 2012 at 10:44 AM
    TACODOC1
    TACODOC1 Well-Known Member
    SoCal
    2024 Tacoma Trailhunter - Bronze Oxide
    Ohmmeter... Check fuses... Try a different bulb...
  4. Dec 25, 2012 at 10:49 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2.
