Is my power steering pump dying?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JasonY, Nov 13, 2017.
  1. Nov 13, 2017 at 10:34 AM
    JasonY
    JasonY [OP] Active Member
    Austin, Texas
    09 Access Cab, Prerunner, SR5, Alloys,
    2009 2.7L Access cab, 99,000 miles
    On cold mornings (less than 60 degrees) when I start up my truck and turn the wheel at a standstill or at slow speed there is a whining under the hood. Once the truck heats up everything sounds fine.
    On warm/hot days there isn't any sound.
    I'm about to do a bunch of work at 100k, does it sound like my PS pump is going?
    Thanks!
  2. Nov 13, 2017 at 10:50 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    mine has done this when cold for past 150k miles
  3. Nov 13, 2017 at 10:54 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Maybe just a flush would solve it? When was the last time gex th power steering fluid?
  4. Nov 13, 2017 at 12:41 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Had like dead spots with mine around 120k. Used a transfer pump to suck out the resivor filled with fresh. Started truck cranked the wheel to each stop and repeated it a few times. Did this a few occasions and mine is fixed now. People use turkey basters also to suck the old stuff out also.
  5. Nov 13, 2017 at 1:20 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is the belt making noise/slipping?
  6. Nov 13, 2017 at 1:28 PM
    jon.e.b3030
    jon.e.b3030 Well-Known Member
    john
    Try changing fluid , then if you have -deadspots- clean and lube the flex joint ion bottom of of column, i changed my pump and didn't have to.
    Jeffch likes this.
  7. Nov 13, 2017 at 3:54 PM
    JasonY
    Austin, Texas
    Some minor squeaking when it rains but otherwise it's pretty quiet under the hood.
    I'm coming up on 100k and was going to replace the serpentine belt. As long as I was under there might as well go for the water pump. And heck, now that it's all off why not he power steering pump if that's going wonky? And it's about time for new hoses, I guess-- and new fluid then. And new plugs (these are original). Gotta do the front brakes and discs as well (original and pulsing slightly when I brake). Rotate/balance/align tires. Oil/filter/diff. Manual tranny fluid? Oh, and the battery is going on 5 years now. Need new wipers. Did I mention the engine and cabin air filters? Should also check the bearings and CV joints.
    Sheesh, I want this truck to last to 200k but the 100k maintain is going to kill the budget.
