Is my starter bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StinkPickle, Nov 6, 2019.
  1. Nov 6, 2019 at 2:54 PM
    StinkPickle
    StinkPickle [OP] Well-Known Member
    Brandon
    SuperWhite 2012 TRD OR
    3" OME
    Why would my truck randomly not start? It's done it twice now in the last week. It will start cold just fine but if I stop somewhere and go back to start it it will take 2 or 3 tries to get it going again. It's random and I'm going on a out of state hunting trip next week and don't want to get stranded in the middle of bfe. Battery terminals were cleaned with baking soda prior to this happening too
  2. Nov 6, 2019 at 3:05 PM
    StinkPickle
    Brandon
    3" OME
    I should mention it turns over. Just doesn't fire so I guess that wouldn't be starter huh?
  3. Nov 6, 2019 at 3:15 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Correct not starter then.
    Fuel or spark?
  4. Nov 6, 2019 at 3:18 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Are you throwing any codes?
  5. Nov 6, 2019 at 3:18 PM
    StinkPickle
    Brandon
    3" OME
    Maybe? I replaced plugs not too long ago too
  6. Nov 6, 2019 at 3:18 PM
    StinkPickle
    Brandon
    3" OME
    Nope
  7. Nov 6, 2019 at 3:34 PM
    StinkPickle
    Brandon
    3" OME
    I'll throw the obd scanner on it again and see
    TomTwo likes this.
  8. Nov 6, 2019 at 3:36 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    You may want to check your charge level on your battery. I noticed that happening on hot starts shortly before my battery totally crapped out on me.
  9. Nov 6, 2019 at 3:43 PM
    StinkPickle
    Brandon
    3" OME
    It's a 2012 and I assume original battery
  10. Nov 6, 2019 at 3:44 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    My 2016 battery crapped out after 2 years. You may be in need of a replacement. Just saying if you're going on an adventure trip soon it would be good to double check you battery's health.
  11. Nov 6, 2019 at 3:49 PM
    StinkPickle
    Brandon
    3" OME
    I took it to local auto store and was 12.8 volts and 650cca.
    BillsSR5 and sdsurfer[QUOTED] like this.
  12. Nov 6, 2019 at 3:52 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Okay... sounds like that's not the problem then... :fistbump:
  13. Nov 6, 2019 at 4:04 PM
    Timinatorx92
    Timinatorx92 Well-Known Member
    2006 Black Tacoma AC TRD Offroad
    3" toytec lift Method 16x8 Grid Coopers at3 xlt 295/75/16
    when it craps out on you.. try to jump start the battery.. if it fires up? then its the battery.
  14. Nov 6, 2019 at 4:06 PM
    wilson23
    wilson23 Well-Known Member
    if the thing is turning over then its not the battery
  15. Nov 6, 2019 at 4:20 PM
    Timinatorx92
    it'll still be the first and easiest thing that i would check. I wouldn't eliminate the battery just because the voltage test reads good. When the battery is going bad, it'll start the car just fine and crap out on the next startup(even if its a warm start-up).
    nagorb likes this.
  16. Nov 6, 2019 at 4:20 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Not always true. You can have a dead short in the battery and jumping will not start it. Of course this only happens with a standard plate style battery, not AGM batteries.
  17. Nov 6, 2019 at 8:52 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Yup. I've had this happen just before a battery completely craps out.
    POOLGUY likes this.
  18. Nov 6, 2019 at 9:53 PM
    Clavin
    Clavin Well-Known Member
    Calvin
    2005 TRD Taco 4door long bed
    General badassery
    When it won't start, turn the key to on without starting it and listen for the fuel pump charging the system.
    cruxofthebisquit likes this.
  19. Nov 7, 2019 at 2:13 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Have you tried hitting the starter with a hammer .i used to drive a 98 tacoma at work and the starter was going and we would hit it and it would fire right up
    whatstcp likes this.
  20. Nov 7, 2019 at 2:36 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I'm going with battery also, it tests fine just sitting there, but under load of starting, it might not have enough.
