is my steering shaft toast?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Jul 8, 2012.
  1. Jul 8, 2012 at 11:29 AM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    everytime i offroad my toe gets out of whack and my steering wheel is crooked...yesterday ii hit a bump hard and it got knocked out....then i hit another bump and now it is straight again.....i took some pix of my steering shaft, it doesnt look right...the shaft has somem play also...
    i almost thought that maybe the yoke sleeve was loose and slipping....but it was tight
  2. Jul 8, 2012 at 11:33 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
  3. Jul 8, 2012 at 11:34 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    pass it!
  4. Jul 8, 2012 at 11:37 AM
    anthony250f
    Anthony
    San Diego, CA
  5. Jul 8, 2012 at 11:42 AM
    BAMFTACO
    Juan
    Kings bruh
    How does it drive and also as long as your tires aren't getting uneven wear youll be fine
  6. Jul 8, 2012 at 11:58 AM
    anthony250f
    Anthony
    San Diego, CA
    it drives fine....but when i hit that second whoop when turning....i thought my steering shaft snapped! the noise was so bad
  7. Jul 8, 2012 at 11:59 AM
    BAMFTACO
    Juan
    Kings bruh
    Hopefully someone will chime in with an answer
  8. Jul 8, 2012 at 12:03 PM
    BAMFTACO
    Juan
    Kings bruh
    This happened to there's a wierd clunking noise when I hit a bump hard pm haitt he had a fix for that just put a zip tie some were on the steering shaft and helped with the noise
  9. Jul 8, 2012 at 12:04 PM
    anthony250f
    Anthony
    San Diego, CA
    i have that same clunk....i will pm him
  10. Jul 8, 2012 at 12:04 PM
    JeremyGrey
    JeremyGrey Well-Known Member
    Ahwatukee, AZ
    2012 DCSB TX Pro Prerunner
    Did you check your stearing box mount? Check carefully, might be a small crack when not under stress.
  11. Jul 8, 2012 at 12:05 PM
    anthony250f
    Anthony
    San Diego, CA
    where is that located?
  12. Jul 8, 2012 at 12:08 PM
    BAMFTACO
    Juan
    Kings bruh
    Do you mean rack and pinion
  13. Jul 8, 2012 at 12:09 PM
    anthony250f
    Anthony
    San Diego, CA
    solid axles have steering boxes..that about all i know haha
  14. Jul 8, 2012 at 12:13 PM
    JeremyGrey
    Ahwatukee, AZ
    Yeah! The hydraulic thing that helps the truck turn.
    Edit: just looked on my truck. Not like other trucks I've owned. There is no steering box. My truck is still stock, haven't played under it yet. I feel dumb. Sry guys
  15. Jul 8, 2012 at 12:22 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Well from the vids ive seen of your truck, you kinda drive it hard. I seriously think cam tab gussets would really help you out. Arent your tabs bent anyways?
  16. Jul 8, 2012 at 12:38 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Some ifs use steering boxes. Most solid axles use steering boxes. Ours uses a rack an d pinion. Check for play in the ujoints on the steering shaft. Check tie rod ends. check bushings on rack.
  17. Jul 8, 2012 at 12:50 PM
    anthony250f
    Anthony
    San Diego, CA
    One of the cam tabs is bent...slightly...camber and castor never change...only toe
