Is My Tacoma Pre-Wired?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007PNWtaco, May 14, 2017.
  1. May 14, 2017 at 11:49 AM
    007PNWtaco
    007PNWtaco [OP] Well-Known Member
    Isael
    2010 silver tacoma
    My truck is a 2010 SR5 4x4 Toyota Tacoma
    I recently purchased some Cali Raised LED Foglights and I'm not sure if my truck is pre-wired for foglights.
    Their was wiring where the blank switches were located on the dash. I read in other forums that that connection in the far left is for the fog lights which is great.
    My issue is I cannot find the plug-ins near where the fog lights are located on the bumper/hood.
    Does anybody know where they'd be if they were there? Is my truck even pre-wired even though there are connections on the dash?
    I can post more pictures for you guys if it can give you a better idea of what is going on.
    thank you !
  2. May 14, 2017 at 11:53 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    My sr5 has the fog light switch on the top row far left. That may be it. Good luck
  3. May 14, 2017 at 11:55 AM
    007PNWtaco
    Isael
    2010 silver tacoma
    So your SR5 was pre-wired? Were you able to find the pre-wired connections to the fog lights on the bumper?
  4. May 14, 2017 at 12:00 PM
    Justanotherhemi
    Rick James
    Mine actually came with fog lights already. Just pointing out the location of my fog button for reference. Hope it helps
    007PNWtaco[OP] likes this.
  5. May 14, 2017 at 12:04 PM
    VA SOFTACO
    VA SOFTACO ...because who buys hard tacos
    Beauregard
    Virginia Beach, VA
    2015 Tacoma MGM OR DCSB
    Check behind the fog light panel on the bumper to see if you have the wires there and match up the colored wires to either of those connectors. Keep in mind one may be grounded to the body somewhere and not continue to the stage other.
    All stock switches for fogs are top left in 2nd Gen.
  6. May 14, 2017 at 12:09 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    My 09 had no fogs, nor switch harness, nada. From what I read before, if you lay on your back and look up to where the fogs should be, if your truck is pre wired, you should see a harness tied up above where the lights go.
    Also, I believe the harness that plugs into the fog switch is either green or black.
    Looking at your photo, I think you're pre wired. (Left most switch bay), if you have that black plug, I'm betting you have some plugs up above, behind your fog openings.
    007PNWtaco[OP] and VA SOFTACO like this.
  7. May 15, 2017 at 7:19 AM
    007PNWtaco
    Isael
    2010 silver tacoma
    This is what I see above where the fog lights go. I don't see a harness or anything. Do you know where it would be if its not near the fog lights?
  8. May 15, 2017 at 7:49 AM
    Doogz
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Skip to around 9 minutes in this video. He discovers his truck is pre wired. If you don't have those plugs then you will have to wire it yourself, which isn't difficult.
    https://youtu.be/Lj17HmMYgXQ
  9. May 15, 2017 at 1:26 PM
    007PNWtaco
    Isael
    2010 silver tacoma
    Hey thanks man! Really appreciate your help. :cheers:
  10. Jun 5, 2019 at 10:53 AM
    slebkuecher
    slebkuecher Active Member
    Sawyer
    San Luis Obispo, CA
    '07 tacoma prerunner
    What is the wiring on the far right for? My truck has that one as well.
  11. Jun 5, 2019 at 10:57 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    inverter in the box I believe.
