Is my tacoma totaled?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by yolataco1, Oct 26, 2021.
  1. Oct 27, 2021 at 6:59 AM
    #41
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Hopefully it's one of the supposedly new and improved frames that won't rot...
    shakerhood likes this.
  2. Oct 27, 2021 at 7:02 AM
    #42
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    I'd like to think it already had a new and improved frame. Truck is 6 month old.
  3. Oct 27, 2021 at 7:04 AM
    #43
    PennSilverTaco
    Charlie
    My 2010 just got approved for a new frame due to perforation in the right rail by the catalytic converter; I heard that up through 2017 is eligible for the recall now...?
  4. Oct 27, 2021 at 7:05 AM
    #44
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    No
  5. Oct 27, 2021 at 7:10 AM
    #45
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    How the hell would any of us know? Take truck as per your Insurance to get truck inspected and evaluated. By the way that hood gap, body line does not look good. Trailer hitch/bumper is bolted to frame with 7 bolts per side. If hitch is bent downwards chances are so is your frame.
    Edit: ah, see that you got pushed into the vehicle ahead of you as well, so plastics damage, and gap misalignment up front, possible sub frame/rad support damage there. Could be just a simple pull if nothing wrinkled in the crumple zones.
    Chew likes this.
  6. Oct 27, 2021 at 7:12 AM
    #46
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    Jesus. It's clever to say "take it in" as if anyone thinks he would just say "nevermind, Tacomaworld says it's not totaled. I don't need to take any further action."
    Bro got his truck messed up, and it's a big deal to him right now, and he wants to chat about it. The conversation here won't, in any way, affect the outcome. The body shop will know all. But until then, nothing wrong with bullshitting and chatting and placing bets about the final result...
  7. Oct 27, 2021 at 7:35 AM
    #47
    Tallgrass05
    Tallgrass05 Well-Known Member
    Interestingly, the body shop did not do the estimate on my truck. It sat there until the Progressive adjuster looked at it and did his own estimate. Progressive sent me a list of all the parts needed and repairs that would need to be made. To determine the value of the truck, they looked at Tacomas at 5 dealers in the region. There were no OR DCLBs on any lots, so they looked at SR5s and bumped up the value.
  8. Oct 27, 2021 at 8:17 AM
    #48
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    Shoulda fell out onto the highway screaming bloody murder and grabbing your neck.
  9. Oct 27, 2021 at 9:09 AM
    #49
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    he said his bed hit the cab of the truck behind him. not his own cab.
  10. Oct 27, 2021 at 9:12 AM
    #50
    cryptolyme
    Virginia
    if it needs a frame that may be the factor that pushes it over. my last tacoma was in the same situation. they wanted to replace the frame. the frame was on backorder for 4+ months so they ended up just totaling it out.
    Superdave1.0 and Beerpayzdabillz like this.
  11. Oct 27, 2021 at 10:28 AM
    #51
    yolataco1
    yolataco1 [OP] Member
    2016 tacoma TRD sport
    6 inch suspension lift, exhaust, rock lights
    It hit my cab also
    cryptolyme[QUOTED] likes this.
  12. Oct 27, 2021 at 10:36 AM
    #52
    Taco_Craig
    Craig
    I was rear-ended by a Tundra, my bed dented the back of my cab. Kinked my frame. It was repaired, not totaled. Every situation is different. I'm not a body shop expert or anything. But, yeah, my truck was still totally drivable. I got home. I drove it to the body shop. I don't remember the exact number, but my repairs ended up around $15-16k. (edit: that's fake insurance money, I never paid a dime)
    I was upset for a while, but I'm over it now. Truck is still awesome. I've done work on it since. I still trust it. I don't plan to sell it, but if I do I hope they don't check carfax.
    yolataco1[QUOTED][OP] likes this.
  13. Oct 27, 2021 at 10:37 AM
    #53
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    not an accurate appraisal using a cheaper taco
    lazy adjuster
  14. Oct 27, 2021 at 3:17 PM
    #54
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Mmmm hmm. Nice
  15. Oct 27, 2021 at 6:10 PM
    #55
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    If not totaled, I’d guess $18-20K to fix it.
  16. Oct 28, 2021 at 5:34 PM
    #56
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    That’s was my come on line at the clubs in the 80’s.
    If you are that high up, you may be ok unless you got hit by another truck sitting high. Who knows.
    Let’s wait it’s almost Friday
  17. Oct 28, 2021 at 5:44 PM
    #57
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Are people paying book value on Toyota trucks? I can't believe anybody is paying $75,000 for a new or used 4Runner.
  18. Oct 28, 2021 at 7:23 PM
    #58
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Dealer called me about that recall, they want the truck overnight so they can spray some goopy shit all over the frame.
  19. Oct 28, 2021 at 7:29 PM
    #59
    PennSilverTaco
    Charlie
    What's your frame look like after four years in Ohio?
    shakerhood[QUOTED] likes this.
  20. Oct 28, 2021 at 7:56 PM
    #60
    shakerhood
    Southern Ohio
    Still looks new, I sprayed it down with 3M Body Cavity Wax the first couple days of ownership.
