Is my timing chain set up right?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chueflee, Jul 24, 2023.
  1. Jul 25, 2023 at 9:32 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It looks good to me.
  2. Jul 25, 2023 at 6:04 PM
    chueflee
    chueflee [OP] Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    I started the engine, but i get this code? P0343 camshaft position sensor.. Any idea on how I can fix it?
  3. Jul 25, 2023 at 6:08 PM
    TnShooter
    Deogee
    STOCK
    Are you sure the VVT (cam) sensor is plugged in good on bank 1?
  4. Jul 25, 2023 at 6:28 PM
    chueflee
    Chue
    I forgot to plug in passenger side solenoid sensor. Fixed a bunch of codes. But now I just have this one P0343 code after i plug the solenoid sensor in. I think I have all of them plug in?
  5. Jul 25, 2023 at 6:45 PM
    chueflee
    Chue
    This sensor lets the computer know the position of the camshaft and adjust air and fuel. That's why its running a little rough
  6. Jul 25, 2023 at 7:06 PM
    TnShooter
    Deogee
    STOCK
    That code was for the passenger side.
    Did you clear the codes after you plugged it back in?
  7. Jul 25, 2023 at 7:07 PM
    chueflee
    Chue
    A bunch of codes cleared... But I still get P0343
  8. Jul 25, 2023 at 7:13 PM
    TnShooter
    Deogee
    STOCK
    See my reply in your PM:thumbsup:
  9. Jul 25, 2023 at 7:15 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That's typically an open circuit, are you sure the sensors are fully plugged in and no pins are bent?
    wayupnort and TnShooter like this.
  10. Jul 25, 2023 at 7:22 PM
    TnShooter
    Deogee
    STOCK
    It wasn’t plugged in.
    But now it is, and still throwing the same code………..
    And apparently he did clear the code after plugging it in.
    Might as well carry over our PM conversation to here.
    I have him checking the the 5v reference on pin 3. (Blue wire)
    Unless you have a better suggestion?
    Torspd and wayupnort like this.
  11. Jul 25, 2023 at 7:26 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Actually need to check all 3 wires at the sensor, the 2 outside pins should be about 5v and center should be a ground.
    wayupnort and TnShooter[QUOTED] like this.
  12. Jul 25, 2023 at 7:29 PM
    TnShooter
    Deogee
    STOCK
    Looks right to me:thumbsup:IMG_1252.jpg
    wayupnort likes this.
  13. Jul 25, 2023 at 7:32 PM
    chueflee
    Chue
    I'll check tomorrow thanks guys
    Torspd and TnShooter like this.
  14. Jul 26, 2023 at 6:42 AM
    chueflee
    Chue
    I check the voltages blue and red wire read 5 volts. I reconnected it and the check engine light for code P0343 went away
    TnShooter likes this.
  15. Jul 26, 2023 at 6:45 AM
    #35
    chueflee
    Chue
  16. Jul 26, 2023 at 6:46 AM
    #36
    chueflee
    Chue
    I give it gas but keeping it under 2000rpm and I get the check engine light P0300,P0302,P0304,P0306 misfire codes. I turn the truck off
  17. Jul 26, 2023 at 6:48 AM
    #37
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You sure you got the exhaust cam timed right on bank 2?
    You only had pictures of the intake cams.
  18. Jul 26, 2023 at 6:50 AM
    #38
    chueflee
    Chue
    yes. I didn't take a picture. Only get the codes when I give it a little gas
    Also I forgot to mention these are kelford camshafts with stiffer spings
  19. Jul 26, 2023 at 7:43 AM
    #39
    TnShooter
    Deogee
    STOCK
    Are you using stock exhaust cam gears. Or aftermarket ones?
    If you’re using the aftermarket advanced ones. It’s even more crucial you get it timed exactly right.
  20. Jul 26, 2023 at 7:44 AM
    #40
    chueflee
    Chue
    i got the -3 deg ones from URD. The marks were lined up
