is my wheel bearing ruined ? i pressed it and forgot 1 new bolt :(
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05BDS, Aug 8, 2013.
  1. Aug 8, 2013 at 11:48 AM
    05BDS
    05BDS [OP] Well-Known Member
    2005 TRD 4door Tacoma
    6 inch BDS lift 35x12.5 Nitto Trail Grapplers 18x20 KMC Rockstars
    hey guys, feeling like an idiot, got my bearing pressed into the new hub and used the old 4 bolts, only 3 worked :( Is my bearing toast now that its already been pressed into the hub assembly? Or can i just press it out, take out the 4 old bolts, put new bolts in and then re-press?
    Thanks guys ! First time doing the bearing , all felt like it was going so smooth and then bam, rookie mistake.
    Cheers
  2. Aug 8, 2013 at 11:56 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What do you mean one bolt didn't work? You might be able to take it apart, I would be prepared with a new bearing though..
  3. Aug 8, 2013 at 12:12 PM
    05BDS
    The top right bolt i guess was damaged somehow and it went unoticed , so it wouldnt thread back into the spindle
  4. Aug 8, 2013 at 12:14 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Gotcha. My bolts were all jacked up because I forgot to take the center nut off... :eek: I was working 3rd shift. I managed to clean up the threads with a set of files. Might give that a shot.
  5. Aug 8, 2013 at 12:15 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Your bearing is fine. Press it out and put in new bolts on the hub block. Press your bearing back in and you are golden. Same thing happened to a friend of mine. :p
  6. Aug 8, 2013 at 12:34 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Really? HOw can you press bearing out with out damaging seal ?:confused:
  7. Aug 8, 2013 at 1:32 PM
    05BDS
    its fine? il take it back to the machine shop, god i feel like a f***ing idiot.. ah the joys of being a green on a wrench
  8. Aug 8, 2013 at 7:17 PM
    BamaToy1997
    Bill
    Navarre, FL
    If you, or the shop you take it to, has a bearing splitter, then it can be salvaged without damaging the seal. Just carefully press out the wheel hub enough to change out the nut, then carefully press it back in.
  9. Aug 11, 2013 at 2:01 PM
    05BDS
    well as it turns out the spindle bolt holes are stripped, 2 of them. The last mechanic i brought the truck to did both my front wheel bearings. Took it up to a buddy and he said it looked as if the mechanic had smashed the 2 bolts in with a hammer,then re-sprayed it black to get rid of the hammer marks... :( guess i need a new spindle
  10. Aug 11, 2013 at 2:05 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Use a tap to re thread the bolt holes, and use a die to re thread the bolts. Doing this may prevent you from having to try and press out the hub to install new bolts, and prevent you from having to buy a new spindle. Not sure of the thread size, but Bama or NJ may be able to find out since they are doing the wheel bearing thing.
  11. Aug 11, 2013 at 5:49 PM
    BamaToy1997
    Bill
    Navarre, FL
    Are you talking about the wheel studs are damaged?
  12. Aug 11, 2013 at 6:31 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I think he is talking about the bolt holes that mate the wheel bearing to the spindle.
  13. Aug 12, 2013 at 5:50 AM
    BamaToy1997
    Bill
    Navarre, FL
    Oh man, that would suck. I was curious because he mentioned something about painting over the bolts. I can see now how that would really suck. I would think if the threads were that damaged, trying to rethread it would not be the best. Sometimes you can rethread a hole if a few threads are damaged, but if the entire threaded hole is stripped out, rethreading will create a weak spot, which you do not want with a hub bearing assembly. One option would be to see if there is room on the back side of the spindle for a washer and a nut, then install a slightly longer bolt and a washer and nut on the back side. You have to check for clearance and such for the CV axle and other components. I don't have a 2nd gen in my shop right now to check. Otherwise you may be looking at having to replace the entire spindle.
  14. Aug 12, 2013 at 12:13 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    My best guess is his mechanic cross threaded them and cranked on them until they stopped turning.
    I had a sleep deprived accident with my truck where I dropped it off a jack with the back wheels loose (lug nuts still mostly threaded on). When I took one the lugnuts off one on each side pulled the threads off with it because those lugs nuts took all the pressure of the drop.
  15. Aug 13, 2013 at 5:24 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    No shit
  16. Aug 19, 2013 at 5:17 PM
    05BDS
    Yeah it was the holes that the bolts go into, and your right the mechanic just over-threaded them until they stopped turning, ruining all the threads on the spindle. I took it back to them, and as it turns out the guy who worked on my truck was fired, they wouldnt tell me why. will not be bringing the truck back to them. bummer :(
