Is regearing worth it for me?
Discussion in 'Performance and Tuning' started by shaunemoore, Feb 18, 2016.
  1. Feb 18, 2016 at 4:03 PM
    shaunemoore
    shaunemoore [OP] Active Member
    Shaune
    2017 Toyota Tacoma TRD Off-Road
    I have a 2015 Tacoma. I put on a 2 inch OEM lift with 32 in tires. The truck has stock 4.30 gears. When I put the lift on I could definitely feel a drop in power and gas mileage. The drop in power was minimal. My gas mileage went from average of 21, down to 18 (19 on a good day).
    Im thinking about uping it up to 4.56. That will put it in my stock power band. The catch is that its very expensive. $3800 expensive. So my question is, is it worth it to to regear my truck at that price?
    Ive included my invoice for the price estimate to look at the prices quoted. Im in Alaska, so prices are a bit higher, But is he charging way too much?
  2. Feb 18, 2016 at 4:07 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I would say absolutely not. There are tonnes of people with lifts an 32" tires doing fine with stock gears. Are you running heavy tires? Mud tires?
    I would say re-gearing is only worth it if you do the work yourself and even then I wouldn't do it.
  3. Feb 18, 2016 at 4:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    Depends on what you want to accomplish.
  4. Feb 18, 2016 at 4:08 PM
    shaunemoore
    Shaune
    Im running BFG All Terrains. Yeah I didn't lose much power, but it bugs me that I did lose some.
  5. Feb 18, 2016 at 4:10 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    That's about how much I'm expecting to pay to regear and lock for both my front and rear. But he's only charging you for the rear lock?
    I may have missed, are you 2WD?
  6. Feb 18, 2016 at 4:11 PM
    shaunemoore
    Shaune
    No
    Im 4wd, but no its a quote for front and rear.
  7. Feb 18, 2016 at 4:13 PM
    shaunemoore
    Shaune
    I just use it for a daily driver and light off roading for fun and to camping/fishing spots.
  8. Feb 18, 2016 at 4:13 PM
    Yota64
    Yota64 Professional Threadjacker
    That's a lot of money just to get the power back. You're on stock sized tires anyway, so you'll be overgeared. How exactly did you feel a power loss? Wind resistance should only be a real issue at higher speeds.
    Edit: Did you get a lift and different tires or just a lift?
  9. Feb 18, 2016 at 4:14 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Ah.
    Eesh. It does seem a little steep, but that's for me and I'm in Texas. Perhaps some Alaska members will chime in on the costs.
  10. Feb 18, 2016 at 4:16 PM
    shaunemoore
    Shaune
    I
    I could just feel the loss when I stepped on the gas. It didn't have the same pep. I'd have to push harder to get the same power. And I of course could see the loss in my fuel averages.
  11. Feb 18, 2016 at 4:18 PM
    Yota64
    Straight off the line should only be affected by your wheel and tire combination. Their weight and diameter will take up some power if increased. Did you get new tires or were the BFG all terrains stock?
    As for MPG, yes the lift may decrease that, but honestly not all that much. My truck had a 3 inch lowering kit and when I raised it to stock+2.5", I recorded a ~1 MPG loss. That, of course, was at around 60MPH. at 75 it would be more, how much I'm unsure.
  12. Feb 18, 2016 at 4:21 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Wait since when has Toyota put in 4.30 gearing on the 2nd gens?
    Last I saw it was 3.73...
    RogueTRD likes this.
  13. Feb 18, 2016 at 4:21 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You sure you don't have 3.73 gears, I don't think they didn't switch to 4.30 until 2016.
    ^^^ Ya beat me.
  14. Feb 18, 2016 at 4:23 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    For me, I do 70/30 DD/wheeling. I'm still on 32s and pretty plated up, only missing the rear bumper. The truck feels like it has plenty of pep for me. But I know when I get larger tires and a rear bumper, I should probably regear. I'm just holding out until I'm ready to buy lockers. Because shouldn't all DDs be dual locked?
    It's your choice, and your truck. I believe you should only do the diff work once. So make sure that's end game for you, or will at least make you happy for several years.
    Yota64 likes this.
  15. Feb 18, 2016 at 4:57 PM
    Yota64
    Oh wow, I assumed this was a 2016 since you claimed to have 4.30 gearing. Yeah, you definitely have 3.73 unless you had some sort of special order, and if you had a V6 2015 on 4.30s, you wouldn't feel a thing but torque.
    You haven't responded yet but I'm going to assume the tires are different? They're probably heavier. If you don't do heavy offroading, switching to a lightweight wheel and tire combo would help your gas mileage and power.
  16. Feb 18, 2016 at 5:12 PM
    shaunemoore
    Shaune
    Yeah you are right, not sure where I got 4.3 from.
  17. Feb 18, 2016 at 5:14 PM
    shaunemoore
    Shaune
    Exactly. I also plan to plate up. Here in the near future i'll be investing in a rear and front bumper along with their Rack Pack. That will add a lot of weight.
  18. Feb 18, 2016 at 5:16 PM
    shaunemoore
    Shaune
    Ive gone through the formula and it says 4.56 is just right for what I want it for. That is also what is recommended by the shop I'm going through.
  19. Feb 18, 2016 at 5:23 PM
    shaunemoore
    Shaune
    4.88 is also in the Gear Ratio spectrum I could go to to return it to stock performance. I just don't want to over do it. The calculator I put it through recommends 3.97.
  20. Feb 18, 2016 at 6:12 PM
    shaunemoore
    Shaune
    Sorry, I missed your post. Yes, the tires are different. I went from OEM 30' tires to 32' BFG AT KO.
