Is sand corrosive?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoManTaco, Dec 16, 2018.
  1. Dec 16, 2018 at 9:07 PM
    TacoManTaco
    TacoManTaco [OP] Well-Known Member
    Did some offroading over some sandy dirt roads, wondering if I need to take it for an undercarriage wash. Not sure if sand itself will corrode the frame. There hasn't been any snow yet this winer (ie no road salts). There is a layer of sand all over the undercarriage.
    FWIW, I did get a corrosion undercoating put on before going offroading.
  2. Dec 16, 2018 at 9:28 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Salty beach sand, yes! Other sand, not so much.
    Any material coating the frame over time with give a place for moisture to absorb and stay in contact with the frame.
    In the short term that’s not a problem, but in the long term, a clean dry frame is best.
  3. Dec 16, 2018 at 9:33 PM
    TacoManTaco
    Just sand from forest access roads. Shouldn't be any salt in it. Has never come near the beach.
    The sand has only been on there about two months, and I did get the whole thing professionally undercoated before I started offroading. I notice the undercoating causes the sand to stick to the frame like a glue, and was worried this would cause rust.
    Hoping this truck outlives my old ass, so I want to make sure my lack of knowledge doesnt lead to problems.
    No sign of snow at all in the weather forecast yet.
    Thanks all.
  4. Dec 16, 2018 at 10:06 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Sand itself is not corrosive, but it is abrasive, which can lead to corrosion issues down the line.
    I’d wash the truck off gently with a garden hose after the beach. Worked great for me. Only place I ever had issues was on the rocker panels...must have smashed the sand into the paint getting in and out of the truck. Easy enough to touch up though.
    cwdog and Hank Heel like this.
  5. Dec 17, 2018 at 5:37 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Sand traps water, which you really don't want laying anywhere on your truck for extended periods. 10/10 ... would hose it down.
  6. Dec 17, 2018 at 6:46 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    You absolutely will not know unless you taste it first.
    deeezy, ctmedic, tonered and 2 others like this.
  7. Dec 17, 2018 at 7:37 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Depends on what all is mixed with the sand.
    Pure sand? Nope.
    stun gun and doublethebass like this.
  8. Dec 17, 2018 at 7:43 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    I would remove any foreign material from the vehicle... sand by nature is abrasive and can easily get in between components with small tolerances, thus increasing the wear of any moving parts. Fresh water rinse applied to the undercarriage and wheel well areas would be practical and help the paint and other protectants remain effective. After all... will only take a few minutes to perform now, and can save you headache and heartburn later.
  9. Dec 17, 2018 at 8:05 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  10. Dec 17, 2018 at 8:10 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The issue is more the salt the sand brings with it.
    The sand is not corrosive, the salt is.
    Sand also causes issues in any greased area.
  11. Dec 17, 2018 at 8:14 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Depends on where the sand is. We have a lot of sand out by Wendover that is close enough to the Bonneville Salt Flats, I have a hard time believing there isn't some corrosive elements in it naturally.
    The sandy dirt in some parts of the SLC area contain arsenic as well which can brittle metal over time, making frame damage potentially more likely.
    Stocklocker[QUOTED] likes this.
  12. Dec 17, 2018 at 11:13 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    My brother made a recktangle out of 3/4 PVC pipe. Installed a few lines across from side to side.....Drilled small holes on the upward side.
    He would hook this up to the hose and then drive back and forth over it. Removed a lot of sand and soil from the undercarridge. He made sore to not have the power on full, so it would not wash off the undercoating.
    tonered likes this.
  13. Dec 17, 2018 at 12:38 PM
    Stocklocker
    17TRDORDCSBAT
    For sure. I guess I was speaking in generalities.
    I would wash beach sand off the same day, right after getting home. The sand from a gravel road I am ok with being on the frame until I have a chance to wash it. However, if I knew I was driving some corrosive alkali road as you have described, I’d treat it the same as beach sand. It’s just not a typical thing where I live.
    Gunshot-6A[QUOTED] likes this.
  14. Dec 17, 2018 at 1:06 PM
    Gunshot-6A
    Conner
    Everett, WA
    So fun story: The new facebook data center they are building in the Utah desert got slated for a piece of land where they found arsenic infiltrated dirt. But rather than move the build site to a location 10 miles away that was good, they elected to scape up all the bad dirt at the zoned site, truck it to the area with good dirt, dump it, refill the truck with good dirt, and truck the good dirt in to fill in the hole. Yeah...
  15. Dec 17, 2018 at 2:33 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    How about abrasive as in sandpaper or sand blasting?
    doublethebass likes this.
  16. Dec 17, 2018 at 2:44 PM
    stun gun
    Aaronski
    Tacomas.
    Ooh another fun story. It’s been theorized that while life forms on earth are carbon based, that doesn’t mean all life in the universe follows that same plan, and that it is entirely possible for life to be silica based. Imagine that. Aliens made of sand!
    Stocklocker likes this.
  17. Dec 17, 2018 at 3:03 PM
    Dacon
    Danny
    Gilbert, Arizona.
    That would be hard to have fun with their females...
  18. Dec 17, 2018 at 3:08 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Just go to the drive through touchless car wash with the undercarriage wash once in a while...
  19. Dec 17, 2018 at 3:14 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Were just lumps of coal then so I guess it couldn't be to hard to imagine.
  20. Dec 17, 2018 at 3:15 PM
    FFBlack
    2019 TRD OFF ROAD
    When in doubt bring the sprinkler out , put it under the truck and leave it a an hr or so. :mudding:
    over60 likes this.
