is sandblasting wheels sketchy?
Discussion in 'Wheels & Tires' started by Broseph Stalin, Nov 22, 2013.
  1. Nov 22, 2013 at 10:55 PM
    Broseph Stalin
    Broseph Stalin [OP] Well-Known Member
    Justin
    Santa Barbara
    '10 white dbl cab LB trd sport
    15% tint , Bak Flip G2 tonneau cover, poplock WeatherTech mats, FX-R retrofit, BHLM, eyelids, smoke Lamin-X, daystar leveling kit, studded snow tires and a shitload of sand bags
    came across these pitted 17" sport wheels and was thinking of making a project out of them and having a set of wheels for winter. Would it be bad to buy these (not for the asking price of course), sandblast, and powdercoat them?
    read on different threads and still haven't found a straight answer, just curious about structural integrity and if it would visually turn out nice.
    http://rockies.craigslist.org/pts/4148212728.html
  2. Nov 22, 2013 at 11:02 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I think it would depend on the media you used.
    Is there a point to blasting aluminum anyways since it doesnt really form rust or scale.
  3. Nov 22, 2013 at 11:13 PM
    Broseph Stalin
    Justin
    Santa Barbara
    the only reason i'm thinking of sandblast them is to smooth out the pitting and make it more of a consistent look, but im open for suggestions
  4. Nov 25, 2013 at 8:37 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Sand blasting will not in any way shape or form affect the integrity of the wheel I can assure you this. If anything it's the curing in the oven after powder coat that would have the greatest chance of affecting the integrity but even then as long as you don't over bake them and do it at the right temperature it's perfectly fine. Just take it to a reputable shop and not some guy on Craigslist powder coating in his back yard shop.
  5. Nov 25, 2013 at 10:14 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    +1, take it to a reputable shop and you'll be perfectly fine. They'll probably turn out better than the factory finish. I see a lot of these sport alloy wheels with the factory clear peeling. Keep in mind that you can't powercoat the plastic center cap. Some really good shops might be able to do it, but most won't deal with plastic.
