is Tacoma's V6 weak?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4runnerToTacoma, Jun 29, 2023.
  1. Jun 30, 2023 at 9:10 AM
    #41
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Pretty much the same experience for me too. There would be moments where I knew there was some torque there, only to fall on it's face. Most of the time I could work around it with the MT though. I honestly thought these tunes for MT's were Kool aid drinking, not worth the money. The only reason I got a tune was thinking, hoping, it would help pulling my camper. It did that and more for me. I still can't believe how much torque there is between 2000 and 3000rpm that was left untapped by Toyota.
  2. Jun 30, 2023 at 9:29 AM
    #42
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    This is an almost daily topic. I would think any perspective buyer, doing any research at all, would know exactly what they are getting by now.
    2wdSR52022 likes this.
  3. Jun 30, 2023 at 9:32 AM
    #43
    Firn
    Firn Well-Known Member
    White OR
    You mean a bunch of people constantly arguing if its slow or not?
    I test drove a manual Tacoma before I purchased (DC Sb just like mine), I don't remember any of this with that one. I'll be the first one to admit that was some time before my truck arrived and I only did 30 minutes or so, but I was on the lookout for it being slow because of the discussions on TW and I know I didn't think that the truck I test drove was slow, then.
  4. Jun 30, 2023 at 9:35 AM
    #44
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    I’ve never had fast cars.. actually the most powerful car/ truck that I have owned is my current taco. So… it is slow but to me is also the most powerful… fast I don’t mind because it is a truck and it does gets to 100mph. Which is already too much… I am good…
    swervin91 and Junkhead like this.
  5. Jun 30, 2023 at 9:41 AM
    #45
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Did your old 4Runner have an actual accelerator cable? The reason I ask is because originally I had a 2000 Tacoma with 3.4 that had an actual accelerator cable. When I bought my ‘08 I was introduced to this new fangled “fly by wire” setup. Definitely took a while to get used to. My 2000 jumped when I wanted it to jump. This ‘08 seems to think about it for a second before doing anything. From what I’ve read it’s supposed to give us better mpg. Like I said, it’s gonna take a while to get used to it. It’s been close to three years so far. Still not a fan…
  6. Jun 30, 2023 at 9:41 AM
    #46
    cropduster78
    cropduster78 Well-Known Member
    NW CT
    '17 DCLB SR5 White
    OV-TUNE 2.0, ADDED/REMOVED STUFF
    I thought it was weak at test drive and still bought it....
    After having it tuned its better but still FN weak.... :facepalm:
  7. Jun 30, 2023 at 9:43 AM
    #47
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I have found that the power is best when you’re NOT at full throttle. It’s like it doesn’t know what to do at full throttle between protecting itself from detonation and giving you the power you’re asking for. Mid to 3/4 throttle seems best. Tunes I’ve tried don’t help any of that behavior either.
    It can be a frustrating motor to drive. I have found the regear to be the only way to truly help, and that’s expensive and still doesn’t fully solve the problem. I can easily bog it down with 5.29s and small tires, but it’s a lot better than stock.
    Firn[QUOTED] likes this.
  8. Jun 30, 2023 at 9:43 AM
    #48
    Claudiomartinof
    try the 4 cyl
    Junkhead and ToyoTaco25 like this.
  9. Jun 30, 2023 at 9:45 AM
    #49
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    A tune won't void your warranty. At least with the VF tune software it's supposed to be undetectable unless someone is specifically looking for it.
    I tuned my truck at 15k miles. Brought it in for all the complimentary services up to 30k. They never said a thing.
    Kbar[QUOTED] likes this.
  10. Jun 30, 2023 at 9:45 AM
    #50
    BLtheP
    Plano, TX
    This is the most illogical argument to me. Test drive it all you want. What if you like the rest of the truck but not the power? Do we pass on it until we find our 100% perfect truck? For most of us, that perfect truck doesn’t exist, and we can only choose from what’s available. So for many of us that means the Tacoma, but that doesn’t mean the engine is great to us just because we bought the truck.
  11. Jun 30, 2023 at 9:48 AM
    #51
    oconnor
    oconnor Where am I?
    Midwest
    Depends, are you constantly whining about the power?
    Illogical is buying it knowing you don't like it, then whining about it to anyone who will listen.
    Those who consistently whine in these threads seem to populate three categories:
    :jpow: #1 Test-drives truck doesn't like the power but buys anyway then whines on the internet.
    :jpow: #2 Doesn't test-drive, buys anyway, then whines on the internet.
    :jpow: #3 Doesn't have a Tacoma, or a life, then whines on the internet.
  12. Jun 30, 2023 at 10:08 AM
    #52
    BLtheP
    Plano, TX
    No, I’m not, but that doesn’t change the fact that for the purpose of the truck, it could be significantly better. It’s “fine” in that it gets the job done. I don’t find that most folks complaining have unfounded complaints, though. Some of them are over the top but the majority aren’t wrong.
  13. Jun 30, 2023 at 10:13 AM
    #53
    oconnor
    oconnor Where am I?
    Midwest
    I agree, it could be better. There isn't anything on this truck that couldn't be done better. There also isn't a perfect truck out there so you pick what you can live with.
    Junkhead likes this.
  14. Jun 30, 2023 at 10:19 AM
    #54
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Is this dumpster fire still burning?
    ToyoTaco25, Chew and HondaGM like this.
  15. Jun 30, 2023 at 10:29 AM
    #55
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I traded a 2002 F150 4X4 crew cab with the 4.6L V8 for my 2007 4X4 crew cab Tacoma. I gave up 10 HP and 300 lbs of tow rating. I also gave up 1500 lbs of truck to move around. The Tacoma was significantly more powerful and got 3-4 mpg better fuel mileage. I guess everything is relative.
    Toyota tends to build trucks with moderate, yet acceptable performance. IMO that is why they have such a reputation for longevity. I can't comment on the 3.5, but after 17 years I'm still happy with my 4.0.
    Crash415 likes this.
  16. Jun 30, 2023 at 10:45 AM
    #56
    2wdSR52022
    2wdSR52022 Well-Known Member
    Jc
    Expensive SR5
    Yo do you, but i make sure I’m satisfied first and foremost with the drive train.
    HondaGM likes this.
  17. Jun 30, 2023 at 10:46 AM
    #57
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Post of The Day Right there...
    Chew and Just_A_Guy[QUOTED] like this.
  18. Jun 30, 2023 at 10:50 AM
    #58
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Just another crummy tune commercial.
    VB25, ToyoTaco25 and Chew like this.
  19. Jun 30, 2023 at 10:54 AM
    #59
    BLtheP
    Plano, TX
    I was happier with my Frontier drivetrain, but I couldn't live with that truck. I liked the Tacoma, and found the drivetrain to be adequate, but far less of a performer. So I bought the truck, knowing it was not as awesome to drive, but I liked everything else about the truck, making the drivetrain to be "it is what it is."
    2wdSR52022[QUOTED] likes this.
  20. Jun 30, 2023 at 10:56 AM
    #60
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Tacomas arent supposed to be Ford Raptors, they do what they do well, Tacos are a super versatile all-rounder. Not a race machine.
    Can't hate on them for what they aren't supposed to be.
