Is the 3rd gen 4 cylinder that slow?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Psychedman, Mar 10, 2023.
  1. Aug 27, 2023 at 4:38 AM
    #161
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Before I purchased my v6 I test drove a 4 cylinder . To me it was way underpowered.
    I would go to the v6 better towing capabilities and better acceleration. By no means is the v6 powerful or quick but it’s better than the 4 cylinder platform . If I was looking for something quick and powerful I would have not purchased a Tacoma . The v6 is great for my towing and off road needs . I would never purchase a 3rd gen 4 cylinder .
    Soonr1 likes this.
  2. Aug 27, 2023 at 4:39 AM
    #162
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I can tell you my 3.5 tacoma would smoke my 4.7 tundra v8 if the two were raced. If compared to a hellcat, or z06, yeah, it is slow.
    Soonr1 likes this.
  3. Aug 27, 2023 at 10:59 AM
    #163
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    Best advice would be to skip buying a Toyota truck/suv with a 3.0 and 3.5. All the other ones are good.
  4. Aug 27, 2023 at 11:01 AM
    #164
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it runs a lot better if you feed it 91 octane. it doesn't like 87, especially in the heat.
    BillyE likes this.
  5. Aug 27, 2023 at 11:03 AM
    #165
    4runnerToTacoma
    4runnerToTacoma Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    Same for my 2003 4runner, over 200K miles.. If there was no frame rust car did not have issues. That 4.0 L V6 was just running SMOOTH. Literally car had no issues , its insane because it was used for towing, harsh winters etc but engine was great and AC still worked.
    Tacoma V6 is not bad either. That almost identical engine is in Toyota's more expensive trims, it is trusted not to have issues.
  6. Aug 27, 2023 at 5:31 PM
    #166
    zoo truck
    None
    Thats just not true. These trucks run great on 87. I just asked a neighbor that bought a 2021 how theirs runs on 87 fuel...said its very responsive, no issues whatsoever.
    clownkillerloaf and LeakyAC like this.
  7. Aug 27, 2023 at 5:46 PM
    #167
    GatorBodine
    GatorBodine Well-Known Member
    Jay
    23' 4 cyl.
    What does, the 4 or the 6?
  8. Aug 27, 2023 at 8:18 PM
    #168
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    opposite of my experience. degraded performance with 87 with retarded timing
    the 4
    turkeyslayer66 likes this.
  9. Aug 28, 2023 at 4:29 AM
    #169
    zoo truck
    None
    Idk about the 4 cylinder running better with a higher octane, but the 6 cylinder will run fine on 87...in fact mine performs best on 87. Seems any octane more than 89, the truck doesn't run as sharp.
  10. Aug 28, 2023 at 6:54 AM
    #170
    BillyE
    BillyE Well-Known Member
    I've found the opposite to be true but my situation might be different. I live in a very hot region, low altitude, and I have the 1" Anderson Engineering spacer on my intake. In theory, that spacer should increase cylinder pressures slightly at low rpms. I had spark knock before the spacer but never tried higher octane. I can't say for sure that the spacer changed anything--but it might.
    cryptolime likes this.
  11. Aug 28, 2023 at 7:11 AM
    #171
    zoo truck
    None
    I'm mostly in cooler weather being here in new england, plus not a lot of big hills either....it's sea level to 3500' on average for me. All our fuel grades are E10, and very fresh.
  12. Aug 28, 2023 at 7:32 AM
    #172
    tarbal255
    tarbal255 Well-Known Member
    Dave
    19 Taco SR
    I'm assuming OP has bought his/her truck now (If so what'd you get?) but in my opinion if anyone is asking if the 4 cylinder is going to be slow... buy the V6.
    I love my I4 but I also don't drive remotely fast at all and love maxing mpg so it's perfect for me and I'm hoping to get 250k or more out of that motor as I keep my cars forever.
    Around town it's fine, highways and on-ramps or up large hills... you'll know you're in a 4000lb truck powered by 150 hp.
  13. Aug 28, 2023 at 7:36 AM
    #173
    SmoothTRD
    SmoothTRD Well-Known Member
    Get a 2nd gen with the v6, it's way better
    LeakyAC likes this.
  14. Aug 28, 2023 at 8:26 AM
    #174
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Spacer doesn't do anything and probably robs power some
  15. Aug 28, 2023 at 9:26 AM
    #175
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    who knows. i've never used one. but i'd imagine if there was a significant benefit toyota would have designed the throttle body longer.
  16. Aug 28, 2023 at 10:27 AM
    #176
    zoo truck
    None
    I never drove a 2nd gen tacoma v6 to compare, but I can't get it in my head they're way better than the 3rd gen v6. These 3rd gen's have outstanding performance for a 3.5 v6, plus get nearly 23 mpg cruising at our highway speeds here. Its just not like toyota to go backwards.
  17. Aug 28, 2023 at 4:01 PM
    #177
    SmoothTRD
    Night and day, turd gens are a downgrade
    LeakyAC likes this.
  18. Aug 29, 2023 at 4:40 AM
    #178
    WNYBill
    WNYBill Active Member
    Bill
    Tacoma SR
    Must be I am the only one worried about the constant shifting at highway cruising speeds, 60-75 mph. In our I-86 commute of 15 miles and an elevation change of maybe 300 feet. Cruise set at 74, it will change between 5th and 6th at least 10 times and on the one hill it sometimes shifts all the way down to 3rd. In 15K miles that's 10,000 transmission shifts.
  19. Aug 29, 2023 at 4:59 AM
    #179
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    nope
  20. Aug 29, 2023 at 4:59 AM
    #180
    turkeyslayer66
    mike
    22 AG Trd Sport
    sell it
