Is the clutch cover supposed to be flat against the flywheel?
Discussion in '1st Gen. Tacomas (1995-2004)' started by AviateGW, Dec 9, 2015.
  1. Dec 9, 2015 at 12:35 PM
    AviateGW
    AviateGW [OP] Well-Known Member
    Glenn
    Atlanta area
    Black '99 3.4 SR5 4x4. OME/Dakar
    16x8 KONIG Countersteer Offroads from FN, OME/881s in front, OME shocks/Dakar leafs in back. K&N CAI, and last, but not least, TRD Shift knob.
    I'm changing my clutch and something doesn't look right. When I align my clutch disk between my flywheel and the clutch cover, my clutch cover doesn't sit flush with the flywheel:
    I can bolt the clutch cover to the flywheel (and keep the clutch disk lined-up), but it doesn't quite look right. It seems like the clutch cover should be flush with the flywheel at the points where the cover comes into contact with the flywheel; otherwise, it seems like there will be an excessive amount of stress on the bolts as they will be subjected to a shear stress they would not have to withstand if the outside edge of the clutch cover was flush with the flywheel.
    FWIW, I've triple checked that the disk is lined up with the side that's stamped 'T/M Side' towards the transmission. I've also triple checked that I bought the right kit, AISIN CKT-040.
    I did have my flywheel machined. There is still a very slight difference between the height of the inner and outer portion of the flywheel, but, I don't think this is enough to cause my problem.
    Thoughts? Help? Advice?
  2. Dec 9, 2015 at 12:46 PM
    AviateGW
    Glenn
    Atlanta area
    Rock, thanks for the reply. I've triple checked with the disk both directions under the cover: It simply doesn't fit either way. I'm beginning to wonder if the machine shop did something weird to my flywheel.
    I'm also kinda concerned about the differences between the old disk and the new disk:
    The old disk has more metal around the springs and is build differently.
  3. Dec 9, 2015 at 12:49 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    You can run a straight edge across the flywheel to be sure, my thinking is that the pressure plate / clutch
    is either warped or the wrong one.
  4. Dec 9, 2015 at 12:54 PM
    AviateGW
    Glenn
    Atlanta area
    FWIW, here is a picture of my flywheel.
  5. Dec 9, 2015 at 2:12 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Quite possible you have parts boxed wrong if the correct number was on all the paper work and box
    Are your dowel pins on the flywheel lining up correct on the clutch plate
    The clutch plate should set flush against the flywheel .
  6. Dec 9, 2015 at 2:20 PM
    Dirty Pool
    Dirty Pool I WAS DRIVING THAT MODEL A
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    You should have to "draw" the p plate up to the flywheel with the p plate bolts assuming the disk is in place. That is the clamping force preventing slippage.
    Some aftermarket plates come with the plastic spring retainers and some folks don't care for them.
    The step between the mounting and friction surfaces is normal and should be maintained for correct clamping pressure. An equal amount of material should be removed from both surfaces to maintain a step height of .5mm.
  7. Dec 9, 2015 at 2:20 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    This^
  8. Dec 9, 2015 at 2:41 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Yup. If the pressure plate sat flush against the flywheel before you even started to tighten it down, your clutch would slip like mad.
    And there is a rotational torque sequence you should follow. It's not like bolting on a wheel, nor is it in a circular pattern. From memory, you should bolt at 12 oclock, then 4 oclock, then 8 oclock, then 2, 6,10 then whatever is left
  9. Dec 9, 2015 at 7:03 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    yep. everything these guys said. there really isn't much pressure on the bolts once you put the tranny back on. since the throwout bearing pushes very slightly on the springs, relieving some of the tension off the bolts.
    also, it looks like you got your flywheel resurfaced. they probably did it, but be aware that they had to resurface your flywheel in 2 places. the outer 3/4 inches of the rim, and the actual surface area where the clutch pad makes contact. there's about a .035-.050 inch (.5 - .75 mm) difference between the 2 surfaces. the fact that the outer rim sits "lower" than the pad surface, means that there's even more tension being added to the clutch pad. AND also why the mounting surfaces looks the way it does. So at rest, there's full tension at all times. if there was no step (completely flat all the way through) the mounting surface would sit flush and that gap would be filled in by the outer rim of the flywheel.
    IF IN THE CASE YOUR CLUTCH FEELS LOOSE OR LIKE IT'S GOING TO BE SLIPPING EASILY AND A LOT. you may have to take the flywheel back and have them cut down the outer surface a tad bit more. If the machinist knows what he's doing (has done more than 5 2-step clutches) then he got it right. So, no worries but be aware.
  10. Dec 10, 2015 at 7:08 AM
    AviateGW
    Glenn
    Atlanta area
    Thanks, guys. :cheers: The Beers are on me!
    My first clutch job that wasn't a motorcycle; noob buffoonery.
    And, TacomaWorld is awesome.
