Is the dealer lying or just stupid?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cwdog, Jun 5, 2019.
  1. Jun 5, 2019 at 11:54 AM
    cwdog
    cwdog [OP] Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    Sitting in my 17 Limited and the 20k service message just popped up. I called a local dealer to schedule the service and asked an advisor how long I should expect to wait for a physical check of the transmission fluid as I understand the temperature of the vehicle is critical. I was told that "There is no way to physically check the fluid level as the unit is sealed and that I should just wait for the 100k mile flush."
    Now I read these forums and I know some of you guys know your shit and many of you are simply full of shit, but I have read that some Tacomas come with low transmission fluid and I want some piece of mind knowing I'm ok on transmission fluid.
    Someone who knows their shit, please weigh in on this for me, please?
  2. Jun 5, 2019 at 11:58 AM
    CRCs Reality
    CRCs Reality Well-Known Member
    Pittsburgh-Ish
    2017 DCSB TRD Sport (OVTuned)
    I had mine check the transmission fluid at 5000 miles and they found it a quart low. Seems like that couldn't have happened if it was a sealed unit and couldn't be checked ;)
  3. Jun 5, 2019 at 11:59 AM
    tcjacado
    tcjacado Well-Known Member
    There is a way to check the fluid level... need to the remove the overflow/ fill plug and and stick your finger in. If there is fluid then it's good. If you have to angle your finger down to feel fluid, it needs topped off.
    Edit keep reading... proper procedure below.
    Flash1034, JCOOR and BassAckwards like this.
  4. Jun 5, 2019 at 12:00 PM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    It is easy to check yourself. I did mine in my garage in under 30 min. from start to finish. Mine was 1/4 of quart low. There is a procedure posted somewhere on here. In a nut shell, you have to put the truck into the transmission temp display mode, overfill the tranny via fill plug, wait until it reaches oper. temp., open overflow plug and let the excess drain out. When it's down to dripping reinstall the plug and you're done!
    BassAckwards likes this.
  5. Jun 5, 2019 at 12:00 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I’d be calling them on that. I’d tell them they can pull the fill plug on the transmission to see if the fluid is at least up to the fill plug. If it’s not, then your truck more than likely has low trans fluid.
    I don’t know if there is a TSB on it but hopefully someone does and can chime in with the info.
    whatstcp and JCOOR like this.
  6. Jun 5, 2019 at 12:01 PM
    ryan760
    ryan760 Well-Known Member
    Personally, I would leave it be and have faith they put the right amount in. I imagine the likelihood of having low fluid from factory is miniscule, unless its leaking somewhere.
  7. Jun 5, 2019 at 12:03 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I would call them out on this just for the fact that the service dude is an asshole!
  8. Jun 5, 2019 at 12:05 PM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Or they sold you a quart of oil and the trans wans't low in the first place. Theres a reason we call them stealerships. Some places will charge people for shit that was never done.
    SandyTaco4x4 and mynewtoy like this.
  9. Jun 5, 2019 at 12:06 PM
    ryan760
    Aldo98229 likes this.
  10. Jun 5, 2019 at 12:07 PM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    Yeah engine needs to be running, trans needa to be at temp and you pull the spill plug to see if anything comes out. If it drips you have enough oil.
  11. Jun 5, 2019 at 12:08 PM
    NotUrTaco
    NotUrTaco Well-Known Member
    Richmond, VA
    2008 Silver 4x4 Access Cab
    Didn't 3rd gens have an issue with low A/T fluid from the factory? Not all, but some? Maybe I'm just remembering that wrong. Either way, there is absolutely a way to check to see if you have enough...it's just a PITA and they likely don't want to go to the trouble.
  12. Jun 5, 2019 at 12:09 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    "Is the dealer lying or just stupid?"
    Yes
  13. Jun 5, 2019 at 12:09 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    I didn’t read anything but the title.
    I don’t need to read anymore to answer the question
    The answer is both
  14. Jun 5, 2019 at 12:12 PM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    They did. Mine was .75 quart low. I know this because I checked it myself. There is a procedure. It is a PITA compared to pulling a dipstick, but it's not overly complicated. As someone else stated, can be done in your garage with no special tools or software in about 30 minutes, give or take. Half of that time is waiting for the tranny temp to get up to check temp if it's been sitting overnight.
  15. Jun 5, 2019 at 12:12 PM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    Jester243, Aldo98229 and tonered like this.
  16. Jun 5, 2019 at 12:13 PM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    TheDevilYouLove likes this.
  17. Jun 5, 2019 at 12:13 PM
    ryan760
    Possibly, I'm not sure.
    Doesn't the check engine light come on with low tranny fluid?
  18. Jun 5, 2019 at 12:20 PM
    ryan760
    Here we go:
    https://www.obd-codes.com/p070f
    Not sure if the Tacoma has a TFL sensor.
  19. Jun 5, 2019 at 12:21 PM
    Tacospike
    Two Trucks
    Depends. Did they tell you they can update your truck with Android Auto and Apple Car play?
    daddy_o, tcjacado and TailHook like this.
  20. Jun 5, 2019 at 12:27 PM
    FN-2199
    FN-2199 Well-Known Member
    Drew
    Canada
    Ok so I was in at the dealer yesterday because my trans was shifting hard from 2-1 when slowing to a stop. My guess was the fluid was low so I had them check the fluid level. They came back and told me that the trans had an update that needed to be done, and what I was feeling on that shift was the motors atkinson cycle... What?
    So the trans was updated, fluid level on my '17 was deemed correct, my trans still shifts weird from 2-1, and dealers are definitely stupid.
