Is the Diff lock a "must have" for 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by riverballer, Oct 21, 2012.
  1. Oct 21, 2012 at 10:56 PM
    riverballer
    riverballer [OP] Member
    Corona, CA
    http://orangecounty.craigslist.org/cto/3349083157.html
    I was thinking of getting this Tacoma and noticed it doesn't have the diff lock button on the left side of the steering wheel. Is that option necessary or can I do without since it is 4x4? Sorry for the noob question. I'm just getting into this stuff :)
  2. Oct 21, 2012 at 10:58 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Not a necessity but can be nice. Can always add one later.
  3. Oct 21, 2012 at 10:59 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    this. i have never “needed” it i do go to a gravel road and put it in some times just to make sure it stays working right.
  4. Oct 21, 2012 at 11:00 PM
    riverballer
    Corona, CA
    What is its purpose? How much would it be to add on later?
  5. Oct 21, 2012 at 11:06 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    purpose is when you have like off camber or. one rear tire off the ground/in the air and one tire on the ground. a lot of times(ok like every time) when you don’t have a locker, the tire in the air will want to spin and the tire on the ground wont want to do anything so you kinda become stuck.
  6. Oct 21, 2012 at 11:07 PM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    PWC, VA
    2016 MGM TRD OR 4X4 DCSB
    Tint
    Depending on the type of diff, it can be from 1k to 2k with installation.
    A locking diff locks your differential, making both tires with traction get power.. If you plan on Off roading a bit i would get it.
  7. Oct 21, 2012 at 11:08 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    In a ordinary open differential the wheels can turn at different rates around a corner. This is good.
    When going down an even road with even traction an "open" differential can then apply even power to both wheels.
    When off road however one wheel may have less traction than the other. The power will transfer to the wheel easiest to turn, less traction.
    Imagine you had one side of your truck on the road, exclude the front for now, and the other side was on ice. Even though you have a wheel on the road with great traction, it's easier to turn the wheel on the ice and so you go no where.
    That's a simplistic view.
    A locker will LOCK both wheels together, so they turn at the same rate, and with the same power, regardless of conditions. This also means that taking a turn your tires can't spin at different speeds and so your tires will "hop".
    Heres a video.
    https://www.youtube.com/watch?v=-dh0VQxprJA
    4x4 open/open can go a lot of places without lockers though. I wouldn't worry about it unless you find yourself wheeling a lot.
    fitting an ARB air locker to our trucks will run you probably 1400???
  8. Oct 21, 2012 at 11:09 PM
    the.sight.picture
    Nick
    PWC, VA
    Tint
  9. Oct 21, 2012 at 11:11 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
  10. Oct 21, 2012 at 11:13 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    that is a bad deal for 19k dollars any way you slice it.
  11. Oct 21, 2012 at 11:18 PM
    the.sight.picture
    Nick
    PWC, VA
    Tint
    I think that is even over KBB. I would pay 14k or 13k for that.
  12. Oct 21, 2012 at 11:20 PM
    Beast Mode
    Beast Mode Well-Known Member
    PDX
    12 DCSB Sport 4x4
    RCD lift, Pro Comp, 285/70/17 Destination AT, LR UCA, magnaflow muffler, LEER 180, Flyzeye, Clazzio covers, N-Fab steps
    So true! That truck has 150k miles and they want $19k? Yikes.
