Is the ECGS bearing still an issue on '19 Tacomas with 2" or less lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SteelerJim, Aug 4, 2019.
  1. Aug 4, 2019 at 10:12 PM
    SteelerJim
    SteelerJim [OP] Well-Known Member
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    ARE Overland Topper, WeatherTech Mudflaps
    I had a '17 Tacoma Off Road and lifted it with a 1"(yielded 2" of lift) spacer on top of the coil spring and I immediately noticed the vibration/buzz due the ECGS bearing issue. Now I have a '19 TRD Off Road and thinking going with the 1/2" spacer from Headstrong(yields 1" lift) on the front. Will I get that same vibration or did Toyota finally remedy this?
  2. Aug 4, 2019 at 10:13 PM
    ninernation
    ninernation Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
    Ome lift on my 18 with no issues
    SteelerJim[OP] likes this.
  3. Aug 4, 2019 at 10:16 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    Why is it that the spacer lifts are all that affect the ECGS bushing?
    emonomics likes this.
  4. Aug 4, 2019 at 10:18 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    If you do the work yourself just do it later if it becomes a problem.
    emonomics and SteelerJim[OP] like this.
  5. Aug 4, 2019 at 10:18 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Have you spoken with Marie at Headstrong about lifts? She’s really knowledgeable about them and can help you out regarding your questions about this.
  6. Aug 4, 2019 at 10:19 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    The lift install is not issue for me. Not sure what's involved with the bushing...
  7. Aug 4, 2019 at 10:22 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    When I lifted my '17 I talked with her. Was just hoping that simply a 1/2"spacer giving just 1" of lift would not cause the ECGS issue I had with the lift I put on my '17. I'm thinking that the 1" front lift together with a set of Falken Wildpeak AT3Ws in 265/75-16 will give it a real nice stance...
    Yoda_Trooper likes this.
  8. Aug 4, 2019 at 10:30 PM
    OnHartung'sRoad
    I bought 5100’s and a single Dakar AAL from them to lift my ‘17 about 1.75”. No issues with it even after 25k miles.
    That ECGS issue seems to appear randomly to trucks with smaller lifts less than 2 inches.
  9. Aug 4, 2019 at 10:37 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Spacer lifts or coil lifts will cause this issue on some trucks. It has to do with CV angles. The drivers side has a single needle bearing that both supports and aligns the drivers-side inboard CV joint. With stock CV angles (dead flat), the thrust on this bearing is directly in line with rotation. As CV angles increase, the thrust on this bearing becomes oblique and it may start to vibrate due to resonance with the CV joint. The bushing effectively eliminates the needle bearing and tightens up the whole assembly so vibrations are less like to develop. The passenger side has a short axle-shaft supported by more than one bearing, so there is no issue there.
    Toyota uses this system due to very limited space between the drivers side CV and the differential itself. It is not an issue on stock trucks so they have never bothered to address it.
    I have a 2017 lifted 1.5” on 5100s and have no vibes and did not do the ECGS bushing.
    BRFab, wahoobie, swoly and 6 others like this.
  10. Aug 4, 2019 at 10:40 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    Finally I understand what it does and why there 'can' be an issue in certain circumstances. Best explanation yet. Thank you...!
    Stocklocker[QUOTED] likes this.
  11. Aug 4, 2019 at 10:43 PM
    Stocklocker
    17TRDORDCSBAT
    You are welcome. It would be better if Toyota went away from the needle bearing, but they’ve used the same style of diff housing since the 2nd Gen Tacos, or maybe even before that, so they don’t seem to feel it’s a problem. My buddy with a 2G Taco had the vibes and it would for sure drive you nuts. I got to drive his truck with the issue happening and I understand why guys want that gone. He was lifted about 4 inches on 35’s.
  12. Aug 4, 2019 at 10:47 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    With my '17 I would get this pulse every few seconds of vibration or buzz you'd feel in the steering wheel and the gas pedal. It was slight but definitely there. And yes...drove me nuts!
  13. Aug 4, 2019 at 10:51 PM
    Stocklocker
    17TRDORDCSBAT
    Yeah.....that’s exactly what I felt. I am so glad I didn’t get that on my truck. I might want to lift a little higher still so :fingerscrossed:
  14. Aug 5, 2019 at 1:10 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I'm lifted on 5100s and did it, because if it was going to happen it would happen to me. It was worth the money.
    shane100700 likes this.
  15. Aug 5, 2019 at 1:56 AM
    longspur
    longspur Well-Known Member
    Tim
    Western Ky.
    2015 extended cab 4x4 4cyl 5 speed
    Have a 17 SR 4cyl 5speed 4x4 and it's stock and had to replace with the bushing. Just luck of the draw.
  16. Aug 5, 2019 at 3:02 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    So why does the Pro does not have this issue if it is lifted? How much is it? 1 inch? So I would think that 1inch lift would be safe because of pros being lifted.. but I do not get it... all pros should have issues with needle bearing and I haven’t heard about it...
  17. Aug 5, 2019 at 3:37 AM
    Rparker017
    Rparker017 Well-Known Member
    2018 Tacoma TRD Pro
    ShiftSense Pro
    If you can install suspension components you can do the ECGS bushing job. ECGS sells a needle bearing removal tool. You’ll also need a large socket for the axle nut (35mm or 36mm maybe). A hub puller isn’t critical but makes the job a lot easier.
  18. Aug 5, 2019 at 4:38 AM
    bocna
    bocna Active Member
    nocal.
    2017 offroad
    2017 OR SB mgm fox 2.5 dsc front 2.o dsc rear , ome medium leafs ray10 brushed bronze on Nitto RG 285 70 17 Prinsu waterport bed divider pro grill yellow tint fogs Raptor lights Xtreme led 38"
    I assumed on both my 2nd (2 inch lift 5100s ) and 3rd gen (2 inch lift fox ) that I wouldn't need it. I was wrong both times. don't skimp out on it . eventually the needle bearings will wear prematurely, just get it done.
  19. Aug 5, 2019 at 5:30 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I recently (past two weeks) replaced the front shocks on my 2015 Sport 4x4 with Toytec Boss shocks and the 600 pound springs. It rides really great though it is stock height at the moment.
    The installers did not follow my directions and raise it 1” to level it.
    If I raise it the 1” I want, will it introduce the issue you describe?
  20. Aug 5, 2019 at 5:32 AM
    Rparker017
    2018 Tacoma TRD Pro
    ShiftSense Pro
    +1. It’s an easier job with the coil over out of the truck. Next time I lift a Toyota I’m doing the ECGS bushing at the same time the front suspension goes in. The time savings would be greater than the cost of the part.
    (I’ve been 50/50 on lifting FJ cruisers. One was fine without it. The other needed the bushing.)
