Is the fuel gauge removable from the instrument cluster?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fullboogie, Mar 21, 2022.
  1. Mar 21, 2022 at 3:38 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Dm93 likes this.
  2. Mar 21, 2022 at 3:40 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    perhaps take the cluster apart and see if there’s something mechanically binding the needle, and very the resistance while energizing the cluster. The problem could be with the wiring between the tank and the gauge cluster so buying a new cluster might not fix your issue. I’d start off to take an ohm reading right at the instrument cluster connectors that connect to the back of the cluster and verify it’s correct.
    Dm93 likes this.
  3. Mar 21, 2022 at 3:59 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Because as we see here there are numerous parts of the gauge that can fail warranting a full cluster replacement. To me it makes more sense that the mileage is stored somewhere else, like in the ecu, and is simply displayed on the cluster.
    6 gearT444E[QUOTED] likes this.
  4. Mar 21, 2022 at 4:06 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    i guess so, mileage before digital were all stored on the gauge cluster though and relatively complicated compared to other functions, granted they are adding more functions into the clusters as time goes on. There are companies that rebuild gauge clusters for a small fee. I sent mine off to get rebuilt on my ford to avoid buying a used one and the mileage be off. The same argument could be made for the ECM if it was stored there, lots to go wrong probably even more so than the gauge cluster.
    Dm93 and EatSleepTacos[QUOTED] like this.
  5. Mar 21, 2022 at 4:16 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Dm93 likes this.
  6. Mar 21, 2022 at 5:33 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Many vehicles only store the mileage in the cluster, it's not a huge deal you just have to document it when the cluster is replaced so it can be programmed to the new one.
    With the proper scan tool you can verify gauge movement by commanding it to various positions.
  7. Mar 21, 2022 at 5:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    OP, have you checked resistance at the cluster?
    I mean, it can’t hurt since you are already pulling it anyways?
    Maybe you have a wire/connection?
  8. Mar 21, 2022 at 6:07 PM
    Lambo9418
    Lambo9418 Well-Known Member
    JP
    Black 2019 TRD Pro
    The problem MIGHT be with the stepper motor that drives the fuel gage pointer (perhaps a damaged gear tooth on the output gear that prevents it from rotating past a certain spot?)
    That said, it could be very difficult to find a replacement motor... but not necessarily impossible. You might try finding an old cluster and removing one from it, or if you know anyone who works at Denzo, they might be able to scrounge one for you.
    Of course, once you have a replacement motor, you need to be able to disassemble the cluster, remove the bad motor without cracking the PCB, and then putting the new motor in, then reassemble the cluster... Good luck.
    6 gearT444E likes this.
  9. Mar 21, 2022 at 6:53 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Thats exactly what I do with my 84 CJ7! Being a Jeep of course the fuel sending unit is bad.
  10. Mar 22, 2022 at 5:57 AM
    Fullboogie
    Fullboogie [OP] Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Yes, in my first post I say that it was checked at the cluster. Thanks.
    TnShooter[QUOTED] likes this.
  11. Mar 22, 2022 at 7:38 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I thought the same until I started hanging around on here. To be honest I think people brick ECUs one way or another about as often as real issues with the cluster pop up, so its kind of a 50/50 either way.
    I know that Ive seen a thread on here where folks take the cluster apart like @Larzzzz mentioned, might have been for 1st gens though. Might be worth starting there. You could get lucky and have some sort of mechanical issue or jam as someone else said. Or you might be able to pull some part number off of the servo motor itself once in there.
    If all else fails how much would it cost to have a new cluster programmed at the dealer?
    EatSleepTacos[QUOTED] likes this.
  12. Mar 22, 2022 at 10:17 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @SR-71A omfg....I can see it in my head! An 8 pin chip that was hit with a purple sharpie or something. The guy swapped it and his milage shown was correct for the truck after.
    It was a while ago and my post history doesn't go back far enough.
    SR-71A likes this.
  13. Mar 22, 2022 at 2:37 PM
    TnShooter
    Deogee
    STOCK
  14. Mar 22, 2022 at 2:50 PM
    Fullboogie
    Dave
    Houston
    Unfortunately new clusters are not available. An "all dealer" search from two sources said they are obsolete. We're trying to work with another used unit.
    SR-71A[QUOTED] likes this.
  15. Mar 22, 2022 at 4:47 PM
    #35
    Larzzzz
    Larry
    MA
  16. Jan 1, 2024 at 7:34 AM
    #36
    Hughes03
    Hughes03 New Member
    I was wondering if some one has came up with a solution to the fuel gage issue. I have an 05 tacoma (367,000 miles). My gage stops at 1/4 tank. I have dropped the tank and put in a new pump/sending unit thought it was fixed. Wrong. Dropped it again and checked the sending unit ohms and all checks good. I have pretty much ruled its in the dash. I did see where you can take the cluster out and send to a place to repair it and i was wondering if anyone has done it themselves?? or send it off and got it back and it fixed the issue. Thanks
