Is the FUEL PUMP or something else??
Discussion in 'Technical Chat' started by 95TacoChick, Nov 21, 2011.
  1. Nov 21, 2011 at 2:52 PM
    95TacoChick
    95TacoChick [OP] Well-Known Member
    3" body lift with K&N Air filter...more to come
    95 Toyota Tacoma, with 269,600 miles.
    My truck has seemed to run fine the last few days besides when i start it, it acted like it was taking about 2 seconds longer to start, i was thinking it was my battery, but now it wont start unless i turn the key over and back on a few times, then it will just start fine. The last few months it has been spitting and spuddering once or twice a week then it will run fine for a few months...so it hasn't done that in awhile. It also will die down if i gun it real hard...and has hardly any power going up a hill or something. So im not sure if all of these are signs of the fuel pump or just my motor being tired??
    PLEASE HELP!!
    Thanks!!
  2. Nov 21, 2011 at 2:57 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I assume you have changed/checked the air filter recently?
  3. Nov 21, 2011 at 3:12 PM
    95TacoChick
    I have a K&N air filter/system that i clean regularly...
  4. Nov 21, 2011 at 3:27 PM
    Cr250jumper
    The moon
    50 shades of tan©
    So its the oiled one? Check/clean your mass air flow sensor. If you over oil the filter and get oil on the sensor it will cause many problems
  5. Nov 21, 2011 at 3:37 PM
    95TacoChick
    Yeah its the oiled one, but its been on there for atleast 2 years that i know of...never had sa problem with it.
  6. Nov 21, 2011 at 3:46 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    But if you clean it regularly, don't you have to oil it each time? Maybe there is oil build up on the MAF?
  7. Nov 22, 2011 at 9:14 AM
    Cr250jumper
    The moon
    50 shades of tan©
    ^Exactly. It can slowly buil up or if you oiled too much one time it will get on the MAF
  8. Nov 22, 2011 at 12:41 PM
    95TacoChick
    Ok i cleaned it and nothings changed. I can get it to start just fine when i turn the key on and off 3 times and then start it.
  9. Nov 22, 2011 at 1:02 PM
    95TacoChick
    We ruled the MAF sensor out because the hubby unplugged it and i couldnt get it to start at all, he plugged it in as i was turning it over and it started..
  10. Nov 22, 2011 at 2:12 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    When was the timing belt and idler last changed?
  11. Nov 22, 2011 at 7:23 PM
    95TacoChick
    Good question. I've only owned the truck since March. ...but i can ask the previous owner with no problem. But in my luck... if its anything like the shocks, and ball joints, they're probably factory.:confused:
  12. Nov 22, 2011 at 7:25 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Clogged Fuel Filter maybe.
  13. Nov 22, 2011 at 7:27 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    thats what i was thinking
  14. Nov 22, 2011 at 7:38 PM
    95TacoChick
    Ok i can check it out, before i go looking for it, do you guys know exactly where its at and if its one i can see through or the closed in one?
  15. Nov 22, 2011 at 7:52 PM
    97yota4wd
    Eric
    Mesa, AZ
    should be under the hood, driver side, by the intake manifold, right underneath it.
    you shouldnt be able to see in it, you should replace it anyways
  16. Nov 22, 2011 at 8:01 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Sounds likely, especially since they are hard to get at and it' possible it's been in there for 260K miles :eek:
  17. Nov 22, 2011 at 8:04 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Im betting on the fuel filter as well.
  18. Nov 22, 2011 at 8:08 PM
    95TacoChick
    It would explain why i call it a TURD... its soo slow, if i dont punch on it and let off at the right time it was hit the rev limiter or die down until i let off the accelerator :/
    When i bought the truck in March i think i should have gone for better quality than the looks of it. I got ripped off :(
  19. Nov 22, 2011 at 9:18 PM
    wolftree
    Rick
    Ohio
    95TacoChick,
    My 98 Tacoma had the fuel filter basically beneath the drivers feet, if it is not in engine compartment. Mine was a metal can. Replacing it is a good place to start anyway and cheapest. I would squirt the conections with something like PB Blaster just in case it is the original, you do not want to twist a fuel line. Put the timing belt on a to-do list.
  20. Nov 22, 2011 at 9:26 PM
    97yota4wd
    Eric
    Mesa, AZ
    what engine did your 98 have in it? i have the 2.7 and thats where it was for me. a black metal can as well.
