Is the gap on Denso plugs .032 in "inches" or is that "metric"
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1996_2.4, Nov 29, 2023.
  1. Nov 29, 2023 at 11:30 AM
    1996_2.4
    1996_2.4 [OP] Well-Known Member
    I've got 20,000 miles on Denso copper K16R-U plugs. How many miles can you get out of these copper plugs on the 1996 2.4?
    Is the .032 gap in inches, or is that metric? Dumb question, I know
  2. Nov 29, 2023 at 11:49 AM
    Svridge
    Svridge Well-Known Member
    Ventura, California
    '99 Tacoma Extended Cab, 3.4l Pre-Runner
    32 thousandths of an inch, .032". Spark plugs are generally good for much longer than 20k miles. Unless you're having ignition issues I wouldn't change them until 60-80k
    1996_2.4[OP] likes this.
  3. Nov 29, 2023 at 11:58 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Owner's manual has both mm and in.
    .032 (or more accurately .031) is in inches.
    1996_2.4[QUOTED][OP] likes this.
  4. Nov 29, 2023 at 11:59 AM
    1996_2.4
    Thanks for taking time out to answer. These are the stock style copper plugs they say are only good for 20,000 miles, and my car is shaking a little at idle. It starts fine and gets 23 MPG, so it runs good. So, even on the cheap copper plugs I can get 60,000 miles out of them?
  5. Nov 29, 2023 at 1:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Toyota's recommended interval is 30k for copper plugs: https://assets.sia.toyota.com/publications/en/omms-s/98ALLMS_MS0003/pdf/98ALLMS_MS003.pdf
    Are you reasonably certain your plugs are genuine Denso? I've had counterfeit Denso plugs fail (electrode worn down to nothing) in as little as 16k.
    Other possible causes for shaking include carbon tracking on the plug's ceramic insulation, crack in the boot, bad coil, or it could have nothing to do with the ignition system at all. :) Did you hook up an OBD2 dongle to check the misfire counter?
  6. Nov 29, 2023 at 5:48 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    I had my spark plug wires begin to interfere with each other due to some fancy electromagnetic wave stuff, I guess that's why you're supposed to space them out. Anyways that caused a slight miss at idle. Might be worth replacing when you do plugs.
  7. Nov 30, 2023 at 12:56 AM
    1996_2.4
    Hey thanks for all the replies. This website has saved me a lot of tears over the years
