Is the headlamp outer lens cover removable?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Glenn54, May 4, 2014.
  1. May 4, 2014 at 8:38 PM
    Glenn54
    Glenn54 [OP] Active Member
    Glenn
    Upper Marlboro, Maryland
    SR5 4X4
    (2001 SR5 4x4) I see a lot of dust build up inside of my Headlights and was wondering if the lens cover can be removed to clean inside of them or are they self sealed?
  2. May 4, 2014 at 10:22 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    yes they can be removed. just a few bolts/screw/clips
  3. May 5, 2014 at 12:49 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    2001-2004 headlight assemblies can be removed with "just a few bolts/screw/clips", but I don't think they're designed to be disassembled (for internal cleaning). With the exception of the holes in which the bulbs are installed, I believe they're sealed units.
    For ~$30/ea (http://www.amazon.com/TYC-20-6074-00-Toyota-Headlight-Assembly/dp/B000H8U5YQ/ and http://www.amazon.com/TYC-20-6073-00-Passenger-Headlight-Assembly/dp/B000H8W16G/), however, you can simply replace them. I did several years ago, and I remain very pleased.
  4. May 5, 2014 at 12:51 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yup, the headlights themselves are completely sealed.
    Only way to remove the lens is by heating it up in an oven or with a heat gun.
    Like Steve said, might as well just replace them.
  5. May 5, 2014 at 7:13 AM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    I been thinking of getting my housings replaced.
    Thanks for the link.. now they are in my basket. :)
  6. May 5, 2014 at 9:00 AM
    Glenn54
    Glenn
    SR5 4X4
    Thanks guys. I saw what looked like metal retaining clips holding the lens cover on and hoped it would be possible. The Amazon one looks good :)
  7. May 6, 2014 at 4:43 AM
    Terminal4
    Terminal4 Well-Known Member
    South of the Sierras
    2022 DCLB 4WD
    Accutuned Fox suspension, Wildpeaks AT4, Batzmaru
    Preheat oven to 325. Put a few 2x4s in and set the headlights on top. Bake for 6 min.
