Is the icon stage x worth it?
Discussion in 'Suspension' started by Paint pig, Aug 30, 2017.
  1. Aug 30, 2017 at 5:43 PM
    Paint pig
    Paint pig [OP] Well-Known Member
    2013 trd off road 4x4, mag grey
    yes I know. Yes I have searched.
    Just want some first hand reports. About to pull trigger but just want to make sure what I hear is accurate:
    Worth the price tag?
    Better than standard 5100s
    Ride better than stock?
    What are the negatives? If any besides price
    Any other thoughts and advice such as wish I went up a stage or got this done at that time. I want to hear it all
  2. Aug 30, 2017 at 8:18 PM
    Trev7
    Trev7 Well-Known Member
    Trevor
    Lehi, UT
    2001 2.7l prerunner Orange Xtra cab
    Icon 2.5 ext travel street valve, Icon 2.0 resi, rebuilt leaf springs, built right UCA's, single stage ppg Orange paint.
    https://www.youtube.com/watch?v=eLK9aCN9Xes
    This should answer all your questions....
    but yes better than stock on and off road.
    In the video you can see the icons are stiffer than stock, therefore on the road you may feel more small bumps... I disconnected my anti-sway bar and felt a huge difference! Much more smooth!
    Pull the trigger, go off-road, and I promise you will smile!
    The truck will become smoother after the springs settle (5-10k miles).
  3. Aug 30, 2017 at 9:45 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    I hope they are! I just ordered stage 4 tubular UCA .
    I have a set on my JKU there flipping great !
  4. Aug 30, 2017 at 9:49 PM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    I've seen a lot of problems with newer Icon products. Seems their QA is going down the drain and they've started using inferior seals. I wouldn't buy their stuff for my rig until some of these issues are addressed. YMMV.
  5. Aug 30, 2017 at 9:56 PM
    Tacomamike mike
    Michael
    I'll let you know :) like the icons
  6. Aug 31, 2017 at 9:18 AM
    Paint pig
    these are the kind of things i am talking about.
  7. Sep 1, 2017 at 7:28 PM
    Trev7
    Trevor
    Lehi, UT
    This might be an issue now that you mention it... bought my 2.5 standard travel coilovers used with fresh rebuild from Icon. 5k miles later I had ORW take the spacer out of them to make them ext travel. ORW said it would cost an extra 50 for new seals and to have them installed, since there were only 5k miles on them I said no... ORW called and said there was a slight leak in one so I got the seals replaced...
  8. Nov 25, 2022 at 7:05 AM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    Any update on the quality of the icon seals? Really liking the stage 10 kit and for what it is I believe it’s the best kit for what I’m looking to do with the truck. The seal issue has me a bit concerned, hoping that there may be some newer voices to this with a better experience since this thread started 5 years ago.
  9. Nov 25, 2022 at 8:18 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Stage 8 here... no issues after 1 year and the ride is awesome both on and off road. Seems like the ride has got even better as the components break in. The only experience i've had with their customer service had been a few emails and they've always got back to me quick. Getting the whole set up as a package in my opinion is better than throwing things together from various companies.... seems it's designed well to work together as a unit from front to back. Added the protective coil wraps and shock boots... use Boeshield T-9 (less greasy and clear compared to Fluid Film) on the coils/shocks and leaf's. Rear leaf pack is at option 2. No complaints so far.... the truck rides and handles sooo much better.
  10. Nov 25, 2022 at 8:38 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I had an icon external reservoir kit on my 4Runner for quite some time. Forgot what stage, its been a while.
    There’s a significant improvement in ride quality off and on road.
  11. Nov 25, 2022 at 8:40 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Customer service is pretty much trash though
  12. Nov 25, 2022 at 8:45 AM
    MulletTaco
    Kevin
    Somewhere in AZ
    Looks good! Thanks for the input
    OffroadToy[QUOTED] likes this.
