Is the off road worth the price?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KDowns68, Jul 18, 2021.
  1. Jul 19, 2021 at 4:25 PM
    #61
    Spidicus
    Spidicus Well-Known Member
    Nevada
    19' DCSB TRDOR 4x4
    I bought the Offroad for the locker.. never used it.. i could have gone with sr5. But I'm glad I got the offriad since it has a nicer interior darker seat fabric and better radio. Every time I drive it I'm glad I chose the OR over the sr5 I was looking at
    stacksmasher likes this.
  2. Jul 19, 2021 at 4:37 PM
    #62
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Are you sure you can't get those same options on the SR5? The radio in my 2020 OR is the same as the radio in my 2016 SR5. The different seat covers I think same standard on the OR. I'm not 100% sure though. In any case, I don't personally think an upgraded radio and seat covers are worth $2-3k.
  3. Jul 19, 2021 at 4:39 PM
    #63
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Screenshot_20210719-193605_Google.jpgyou have been debating this for 4 years . Life is short , buy the Off Road and enjoy .
  4. Jul 19, 2021 at 4:43 PM
    #64
    Spidicus
    Nevada
    19' DCSB TRDOR 4x4
    +1 on what bleep100 said.
  5. Jul 19, 2021 at 4:55 PM
    #65
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    I went SR5. I Got a great deal on my Truck as the newer next year models were just coming out. I saved a lot of money and put it into mods. My truck now is more capable than any TRd off-road, or Pro for that matter that drives off the lot.
  6. Jul 19, 2021 at 5:01 PM
    #66
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Downside to the OR you can't get the 2.7. I don't know what the cilantro metter is, first time I've heard of it. You probably don't need it. If you can get a new TRD Pro, OTD for 48,000 get the Pro.
  7. Jul 19, 2021 at 5:07 PM
    #67
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Off-Road model has, as many said, the push button Locking Diff - only works in 4Lo and when you put it on you see the dash light up as the the VSC (vehicle stability control) engine management goes off (throttle ramp down) , ABS off causing firing on wheel slip along with traction control (TRAC) rear off. You get a separate button to turn traction control (A-Trac) for the front only back on. What's this do for you is allows you to get up steep rock faces or sandy/muddy hills without the Tacoma throttle ramping down or the ABS firing to slow spinning wheels. Good on slippery boat ramps and also helps in snow if stuck on steep hills, but again you would have to stop and go into 4Lo first. The Tacoma is a part-time 4x4 system as no autotrac/auto position on the selector (adds a differential in the transfer case) like you can get on a 4Runner. You run a Tacoma for long on a dry street in 4Hi or 4LO and parts will fail.
  8. Jul 19, 2021 at 5:15 PM
    #68
    Goatfrog
    Goatfrog Well-Known Member
    Bill
    Pittsburgh, PA
    2020 Red DCLB TRD Off Road
    If I’m being totally honest. I bought the Off Road because of the black fender flares.
    :anonymous:
  9. Jul 19, 2021 at 5:36 PM
    #69
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    I off-road my truck.
  10. Jul 19, 2021 at 5:39 PM
    #70
    eurowner
    eurowner Duke Sky
    Scoty
    For me, yes. The rear locker and Crawl Control are great.
    I do want the Sport hood since I sit so high in the truck and that is where I would put a led light bar.
  11. Jul 19, 2021 at 6:48 PM
    #71
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    It was to me…
  12. Jul 19, 2021 at 7:03 PM
    #72
    hammerofjustice
    hammerofjustice Well-Known Member
    2020 Black Tacoma OR MT
    that + manual transmission = sold!
    shakerhood and Goatfrog[QUOTED] like this.
